Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 17, 2020 at 5:06 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    if the mechanic fucked up, you shouldn't have to pay for that o_O
    but other than that - how the fuck do you screw up 4 times?
    gabbo2112, Norilsk and llamasmurf like this.
  2. Jun 17, 2020 at 5:07 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    pssst he is the mechanic, sshhh
  3. Jun 17, 2020 at 5:12 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    this, still waiting for my refund...
  4. Jun 17, 2020 at 5:17 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I'm actually an idiot
  5. Jun 17, 2020 at 5:37 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Tundra rack... tundra tre's...
    Its obvious I dont know what I'm taking about.because it can't be that easy.
  6. Jun 17, 2020 at 5:40 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Great question....4 times is a lot eh.
    :rofl:
    If only stupidity had a return policy.....
    Well atleast it was only once, not 4 times.
  7. Jun 17, 2020 at 5:41 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Tundra rack has to be machined so the stroke of the cylinder matches the tacoma. So custom rack. Then you have to modify the frame so it accepts the tundra rack. Requires cutting old mounts and welding new ones. Think you have to modify the steering linkage too. Not sure if the fittings are direct bolt on.
    more details here
    https://www.tacomaworld.com/threads/tundra-steering-rack-upgrade.574655/page-2#post-21785020
    llamasmurf and tgelata like this.
  8. Jun 17, 2020 at 5:46 PM
    Windigo
    Farook
    '14 Acess Cab
    Thanks. Not.worth the work.
    How are other guys not destroying their racks?
    There has got to be a better solution.
    tacoma16[QUOTED][OP] likes this.
  9. Jun 17, 2020 at 5:54 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    People replace with stock ones up to this point. Have heard a rack a year for some.
    Really only a few total options:
    -tundra rack upgrade. (Baskibiker on the site, solo motorsports, and marlin crawler offer upgraded racks)
    -replace yearly and hope for the best
    -there is a “truss” kit coming to brace the rack to keep it from flexing which is the presumed cause of the issues (mainly for long travel go fast guys, but the rock drawer guys are having issues). this does require modification as well and may be apart of a larger engine/diff cradle.
  10. Jun 17, 2020 at 6:06 PM
    Windigo
    Farook
    '14 Acess Cab
    Dont knowing seals will hold up but I have always used psc steering pumps.
    More pressure easier steering.
    Or some sort of hydro steel cylinder to help the rack along.
    I don't know. There are guys out there alot smarter than me and if they can't come up with a solution there might not be one.
    :frusty::frusty:
    llamasmurf, tgelata and tacoma16[OP] like this.
  11. Jun 17, 2020 at 6:10 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    So the “truss” kit in the works has the ability to run a hydro assist.
    some have converted to a full hydro setup which is technically only ideal for trail use only. more details here https://www.tacomaworld.com/threads...nk-and-37s-build.342018/page-53#post-22855474
    @tgelata had a good idea about converting it to an older style steering that gets rid of the rack and uses a box with a pitman arm setup (I’m screwing up the terminology I’m sure), which is another idea.
    tgelata likes this.
  12. Jun 17, 2020 at 6:31 PM
    Windigo
    Farook
    '14 Acess Cab
    Thanks for the link. From a point of reliability for a "overland" type of truck its too much.
    For a pure "toy" to drive to trails and back its ok
    but the best of both worlds I can see a sas would make more sense
    maybe put a tacoma body on a LandCruiser frame and running gear. Solid axles, No rack and strong.....
    I hope I never get to the rack bridge....untill then I'll just have to be rally careful If i ever get to go wheeling......
    tacoma16[OP] likes this.
  13. Jun 17, 2020 at 6:45 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Plenty of solid axle converted Tacoma’s. A upgraded rack isn’t anything compared to, just the availability of parts is the issue. Nice to go to a parts store for a bearing or hub for your One ton front axle from a F250.
    Windigo[QUOTED] likes this.
  14. Jun 17, 2020 at 7:59 PM
    Windigo
    Farook
    '14 Acess Cab
    I knew irs short notice but anyone up forna ride tomarrow?
    Atlas86, Manfred and tacoma16[OP] like this.
  15. Jun 17, 2020 at 8:23 PM
    Norilsk
    Eugene
    Most owners take dirt roads and Subaru friendly trails (Subaru Forester did Minden Hydro line, that's like 3/5 aka 33" tire Tacoma level).
    People that destroy racks usually do plain carnage, it hurts to watch more than participate in it for many.
    You should come with me on a trails one day, you'll experience first hand how things fail and stop asking those questions :D
  16. Jun 18, 2020 at 2:50 AM
    Windigo
    Farook
    '14 Acess Cab
    I'm good luck. Your truck will run perfect with me there. No carnage.
  17. Jun 18, 2020 at 3:18 AM
    Windigo
    Farook
    '14 Acess Cab
    I hope I still remember how to wheel
  18. Jun 18, 2020 at 5:49 AM
    Norilsk
    Eugene
    I remember my tercel going though similar rocks :duh:
    Atlas86 likes this.
  19. Jun 18, 2020 at 5:56 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  20. Jun 18, 2020 at 6:00 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    But you had bigger tires on the Tercel than what you have now !
