Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jul 12, 2020 at 8:00 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
  2. Jul 12, 2020 at 8:09 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Norilsk likes this.
  3. Jul 12, 2020 at 9:18 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
  4. Jul 12, 2020 at 9:25 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Can’t wait to see the tears after you run that fucker into a tree.
    taczilla, Snail81 and Shveet like this.
  5. Jul 12, 2020 at 9:33 AM
    Norilsk
    Eugene
    Can't wait to see your truck on trails, not at the malls :)
    taczilla, Snail81 and llamasmurf like this.
  6. Jul 12, 2020 at 9:37 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    FRP hood prep and paint. Changed wipers to Bosch Icon and relocated the washer nozzles to the wiper arms:
    I used Dorman P/N 47280. Waiting on more 4mm tubing to clean up the routing on the cowl cover.
    Atlas86, Snail81, Tridet167 and 5 others like this.
  7. Jul 12, 2020 at 9:42 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    You did last weekend....
    Shveet likes this.
  8. Jul 12, 2020 at 9:47 AM
    Norilsk
    Eugene
    3 weekends ago*
  9. Jul 12, 2020 at 10:47 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    >attacks him with a "mall crawl" joke
    >is also the person who set up a mall crawl event
  10. Jul 12, 2020 at 10:50 AM
    Norilsk
    Eugene
    :rofl::anonymous:
    You guys think I am due new brakes?
    Rotors have 105K on them and still measure thickness same as the new one :eek: Not warped or anything, but i'll change them for sake of mind.
    That's the quality!
  11. Jul 12, 2020 at 10:50 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    also, anyone know how the Cabin air is routed?
    i got friggen leaves inside my filter o_O
  12. Jul 12, 2020 at 10:51 AM
    Norilsk
    Eugene
    Through your cowl, that sucks it from top and side where wheel well is
    Shveet[QUOTED] likes this.
  13. Jul 12, 2020 at 3:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    https://www.tacomaworld.com/threads/mouse-in-cabin-air-filter.292806/#post-12982266
    I don't advocate putting a mesh over the opening, though, because leaves can still collect on top of the mesh. Cleaning the cabin filter is easier. I usually replace my cabin filter every December, after all the leaves have fallen.
    Atlas86 and Tridet167 like this.
  14. Jul 12, 2020 at 3:32 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i forgot to hit enter for my original plan saying;
    i'll slap on some chicken wire somewhere to catch it then or i'll just pick up another filter on monday, wont kill me since i drive with the windows down.
    but thanks for the link though, looks like a bit more of a pain to clean off the leaves from the mesh o_O but with the amount that.
    maybe building a system with a range hood wire mesh filter could work.
  15. Jul 12, 2020 at 3:45 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Stock rotors?
    TeecoTaco and Norilsk[QUOTED] like this.
  16. Jul 12, 2020 at 3:46 PM
    Norilsk
    Eugene
    They are, more than sufficient for me. Stops every time. :boink:
    TeecoTaco and Tridet167[QUOTED] like this.
  17. Jul 12, 2020 at 4:38 PM
    Tridet167
    Tony
    Toronto, Canada
    My original rotors lasted a long time too.
  18. Jul 12, 2020 at 4:58 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Mine were same at 100K ...very good condition, swapped anyway.
    Stock to stock
    tacoma16[OP] likes this.
  19. Jul 13, 2020 at 4:44 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    OK. So did a lift and getting some vibes on the driveshaft.:mad:Did double CB drop, didn't fix it.:mad::mad: Did Toytec 3 degree axle shim-now it's way better but the vibe is still there.:annoyed: After shims there's a hum/wind noise in the back.:annoyed::annoyed: Here are the questions:
    1. What else can be done to further decrease/eliminate those vibes?
    2. On another thread a question was raised about differential oil level/lubrication efficiency after shim install. Is it a valid concern?
    :help:
    Any input greatly appreciated.
  20. Jul 13, 2020 at 4:55 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Have you measured the driveline angle prior to anything? I know you can’t go back, but atleast if you had a reference of angle it could help.
    adjusting the cb drop is the easiest. You may find removing it completely and just using the axle shin on its own may help. Maybe the double cb drop was too much/little.
    some have fixed it with solid driveshafts but you are getting into some mulla there.
    I would keep playing with the cb drop and try and use an angle finder on the driveshaft to figure it out. Magnetic ones work very well and can be had pretty cheap.
    Snail81[QUOTED] likes this.
