Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jul 13, 2020 at 8:39 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    llamasmurf likes this.
  2. Jul 13, 2020 at 8:39 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i can only say you're half way there
    :rasta:
    anyways, good luck on the vibrations. i need to check in with the stealership and see if i can get my hands on a tech to look into my rear diff. I have a persistent light grinding noise coming from the rear and i assume it's the tail shaft bearing that goes into the rear diff..
  3. Jul 13, 2020 at 8:44 AM
    Snail81
    Igor
    Right here, Ontario
    I have a similar sound ever since I got the truck. Stealership superguy said it's normal....
  4. Jul 13, 2020 at 8:45 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    do you hear it when you have the rear window open only? i've not heard it until some point this year
  5. Jul 13, 2020 at 8:46 AM
    Snail81
    Igor
    Right here, Ontario
    Yep. Have to open the rear window to hear it...
    Shveet likes this.
  6. Jul 13, 2020 at 9:55 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
  7. Jul 13, 2020 at 10:31 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    In theory the CB drop should be helping IF vibes relates to rear pinion angle.
    BUT it adds more angle at the front prop shaft which can introduce vibes also on the Tacoma.
    From what I read the CB drop helps for fine tuning but if it's a major angle then you have to drop it too far, it introduces front prop vibes.
    Since you tried adding more CB drop and it did not seem to change anything,
    might as well try without it and see what happens.... might be informative to see where the vibration changes to...
    without looking at what your angles are, and since acceleration seems to decrease vibes,
    I would look at increasing your axle shim angle another 2 deg. (but am open to challenges from people with more experience).
    (if vibes happens on deceleration then it's too much angle).
    Also I've heard that the front and rear prop shafts are balanced together, so if you pull the rear prop shaft right out you have to put it in the same orientation with the front shaft. (no idea if that's true though.... )
    Snail81[QUOTED] likes this.
  8. Jul 13, 2020 at 11:45 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    From what I am seeing the angle your rear diff is sitting is different from mine, mine angled and not sitting like that.
  9. Jul 13, 2020 at 1:01 PM
    Snail81
    Igor
    Right here, Ontario
    I've seen this truck somewhere. This somewhere being the exact place the picture was taken.
    My pinion is looking up because of 3 degree shims on the axle. ( did them with Naz on saturday )
  10. Jul 13, 2020 at 1:20 PM
    Norilsk
    Eugene
    I don't have those shims, if that helps...
  11. Jul 13, 2020 at 2:39 PM
    Snail81
    Igor
    Right here, Ontario
    Removed the CB drop entirely and... up till 80km/h I can't tell if there's any vibes. Can sense it around 100km/h
    I think it's a move towards a solution.
    Anyways, will try and put some of you peoples in on sunday...
    llamasmurf and daks like this.
  12. Jul 13, 2020 at 3:30 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Bumped into this, it's a pretty comprehensive list (don't think it's all of them, but certainly a bunch i've not seen yet) of the available roof racks for the Tacomas.. WITH IMAGES.
    https://trail tacoma.com/2020/04/06/2nd-3rd-gen-tacoma-roof-rack-options/
    (note; delete space between "trail" and "tacoma")
    Then stop by for lunch next time you're there, i'm just around the corner. :thumbsup:
  13. Jul 13, 2020 at 3:33 PM
    Snail81
    Igor
    Right here, Ontario
    Now you're talking!!
  14. Jul 13, 2020 at 3:46 PM
    Norilsk
    Eugene
    I assume we all invited now :hungry:
    Snail81 and TeecoTaco like this.
  15. Jul 13, 2020 at 3:46 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Where were you at 1:30pm today?
    Norilsk[QUOTED] likes this.
  16. Jul 13, 2020 at 3:46 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i know a shwarma place not far from there that has a pretty large parking lot
    Norilsk[QUOTED] and TeecoTaco like this.
  17. Jul 13, 2020 at 3:48 PM
    TeecoTaco
    SW Ontario
    It must suck, cuz it's spleled Shawarma...fvcking Hamtown hicks
    Norilsk and Joe23 like this.
  18. Jul 13, 2020 at 3:49 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i'm busy injecting 16 different drugs while smoking 7. I'm sorry.
    we'll go to the $1 pizza slice place that's another 5 minute drive from there then.
  19. Jul 13, 2020 at 4:06 PM
    Norilsk
    Eugene
    at work :pout:
    was it a rhetorical question?
    TeecoTaco[QUOTED] and Shveet like this.
  20. Jul 13, 2020 at 4:22 PM
    TeecoTaco
    SW Ontario
    Naw, saw a doppelgänger out of the corner of my eye whilst on the 401 in Milton.
    Had big fat tires AC white Turd gen in opposite direction.
