Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 27, 2020 at 6:20 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    the ultimate tacoma truck
    Manfred and RoamingGnome like this.
  2. Aug 27, 2020 at 7:22 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Wrong, here is the ultimate one
  3. Aug 27, 2020 at 7:29 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    :drool:
    Unimog
    :drool:
    Windigo, Norilsk[QUOTED] and Shveet like this.
  4. Aug 27, 2020 at 7:38 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    but sherp....
  5. Aug 27, 2020 at 7:49 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    would be cool to turn one of these into a ramp style truck with a sleeping setup. I know they did it on a extreme 4x4.
    https://youtu.be/VK76zDtJjaw
  6. Aug 27, 2020 at 8:27 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    In IFS we trust
    Tridet167, RoamingGnome, uurx and 4 others like this.
  7. Aug 27, 2020 at 8:45 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    what model is this? The Beach or something?
    RoamingGnome likes this.
  8. Aug 27, 2020 at 9:02 AM
    Windigo
    Farook
    '14 Acess Cab
    Thank you they look great.
    RoamingGnome, 3JOH22A, Shveet and 2 others like this.
  9. Aug 27, 2020 at 9:10 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    @Taco1992
  10. Aug 27, 2020 at 9:20 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Looks to be the BXD10 variant of the Mega Cruiser, with some hood trimming to clear larger tires than the 37s that came stock.
    tacoma16[QUOTED][OP] likes this.
  11. Aug 27, 2020 at 10:02 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Ginger taco likes this.
  12. Aug 27, 2020 at 10:11 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They don't look very promising.
    Shveet likes this.
  13. Aug 27, 2020 at 10:13 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    as much as i have a dislike to tacomabeast, the new fronts that ignore that little cutout in the corners look pretty good, if that's the style you're after
    ' https://tacomabeast.com/collections...r-headlights-w-led-drl?variant=29432617435238
    but i still prefer the Anzo ones https://www.lmperformance.com/90775...s-w-plank-style-design-black-amber-w-drl.html
  14. Aug 27, 2020 at 11:04 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Mega cruiser! Name escaped me there for a bit.
    3JOH22A[QUOTED] likes this.
  15. Aug 27, 2020 at 12:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Thanks for your input. Which 2005-2011 headlight type produced the photo, as Alpharex makes 3 types?
    [​IMG] [​IMG] [​IMG]
    Did you test the headlights, or was it from another user?
  16. Aug 27, 2020 at 1:23 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    None of them, but my comment was specifically referring to the Nova series LED headlights. I have not personally tested them. But based on all the pictures and video reviews and comparisons to Morimotos I could find, they all show the beam intensity is far too low in the pattern, creating significant amounts of bright foreground light. Nearly all the reviewers are impressed with how bright they are and completely miss that headlights are not supposed to create bright foreground light. Yes it initially looks impressive, but it is harmful to distance night vision and makes you think you can see a lot better than you actually can. That isn't how a headlight is supposed to work. The light peak intensity should be up at the cut off for proper distance projection and the headlight should have a smooth uniform blend of light up to the peak intensity at the top of the cut off. There is a lot more engineering that goes into headlight pattern design than just a bright with a cut off.
  17. Aug 27, 2020 at 1:59 PM
    Windigo
    Farook
    '14 Acess Cab
    So now that I'm inside I can make a proper post.
    Thank you @Taco1992 for the decals.
    the 808 and the Labrador flag blacked out are both custom made. You can't buy them you can't find them for sale.
    Both of those adventures were very life learning for me and you made the decals perfect. Thank you. If all goes as planned next year I will request Yukon stickers:) custom of course, thanks again.
  18. Aug 27, 2020 at 6:56 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    anyone have a 6 lug rear end i can borrow indefinitely?........fml
    TeecoTaco likes this.
  19. Aug 27, 2020 at 7:07 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    No! What did you do!
    car-part.com
  20. Aug 27, 2020 at 7:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Oh damn what happened?
