Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 27, 2020 at 7:08 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    fucked if i know.....it goes clunk clank clunk whenever i make a turn
  2. Aug 27, 2020 at 7:09 PM
    Taco1992
    Taco1992 Member
    Karoline
    2010 Tacoma
    You’re so welcome! Thanks for the shoutout :)
    Steves104x4 and Windigo[QUOTED] like this.
  3. Aug 27, 2020 at 7:12 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Hmmmm. May just need a third member/diff, but have you ever hit the rear end, say whole drifting or something? Possible bent axle.....either way super shitty.
    Junkyards from car-part may ship to you.
    I may have a spare rear diff but you’ll need gears/bearings for it.
  4. Aug 27, 2020 at 7:16 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I was Towing around a trailer, not too much weight about 200 brick and a couple of blocks. unloaded everything at a job site . Everything was fine, at this point. went to a local pub had a beer to celebrate a very productive day. When I left about halfway home I felt a clunk and Clank whenever I would make a turn. I was hoping it was just the trailer that had not been moved for about a month... Got home disconnected the trailer on the immediate first turn I made it was definitively the rear axle. Put it up on the jack as I turn the wheel I can feel the gear somewhat engage and then completely slip out. After the disengagement I can spin the wheel freely without affecting the other wheel... So... Yeah... Fml.
    Manfred likes this.
  5. Aug 27, 2020 at 7:17 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'm thinking if it might be worth it to just upgrade to a Ford 9-inch and what's involved
    Shveet likes this.
  6. Aug 27, 2020 at 7:18 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    :pout:
    Let us know if you need Tw express for shit.
    Shveet and TeecoTaco like this.
  7. Aug 27, 2020 at 7:18 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    In
    Shveet likes this.
  8. Aug 27, 2020 at 7:20 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    thanks guys ....will do
    Shveet, TeecoTaco and tacoma16[OP] like this.
  9. Aug 27, 2020 at 7:20 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    So for axle swaps the biggest thing is speed sensors, driveshaft hook ups and brakes.
    I was planning on a 14 bolt rear axle. Can go full float so easy to change axles shafts if need. Fj case allows me to get the speed sensor and abs shit there instead of the wheels.
    other thing to look for is wheel mounting surface (wms). Believe stock is 65”. Then wheel lug. Most one tons are 8 lug so machined rotors to use stock wheels. Would be cheaper to get a new third.
    Thyces[QUOTED] likes this.
  10. Aug 27, 2020 at 7:24 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    My first search tomorrow morning is a complete rear from a scrap yard
  11. Aug 27, 2020 at 7:46 PM
    TeecoTaco
    SW Ontario
    You know my digits if you need a mule...aint turning a wrench for ya to get it to ya...got some good :rasta:tho
  12. Aug 27, 2020 at 8:14 PM
    Emanresu
    Emanresu Well-Known Member
    Anyone using a mobile/permanent mount GMRS radio?
  13. Aug 27, 2020 at 8:42 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    This is getting interesting! The year is not over and we got total carnage at the beginning of a new decade here.:bananadead:
    I am going to make an award for that...
    neverminded my bent spindle which is gusseted AF
  14. Aug 27, 2020 at 9:36 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Time to pony up for RCLT? Available next month. All the uniball and heim joint maintenance will be a bitch though.
    Manfred likes this.
  15. Aug 27, 2020 at 9:41 PM
    Norilsk
    Eugene
    3JOH22A[QUOTED] likes this.
  16. Aug 27, 2020 at 9:45 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    my guess is this is a 10k kit
    would love it but for 10k..... SAS
    Manfred likes this.
  17. Aug 27, 2020 at 10:17 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Snail81 and Norilsk[QUOTED] like this.
  18. Aug 28, 2020 at 6:16 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I found a rear end with 50k on it for $1000....what do you guys think?
  19. Aug 28, 2020 at 6:36 AM
    Windigo
    Farook
    '14 Acess Cab
    Don't know enough to help. But good luck with it and please post pics. Thanks.
    Snail81 likes this.
  20. Aug 28, 2020 at 6:40 AM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    I'd do it. You'll waste a lot of time searching for another just to shave off a hundred bucks at the most.
    Tridet167, RoamingGnome and Shveet like this.
