Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 30, 2020 at 8:11 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Pics or it didnt happen :gossip:
    All I see is a stuck taco that never made it. :infantry:
  2. Aug 30, 2020 at 8:12 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Tested the AliExpress compressor today on my 265/75-16 (32") Duratracs. Each took 45 sec to be inflated from 15 psi to 32 psi.
    TsnI3tj-BmVLJFvwq3PTVOMKDnp2Z1MvbUPEtU3f_ed7b3c92c03386d2fa7b619da94bb8832ee492c1.jpg
    The whole kit with carrying bag weighs 22 lb. Gallon-sized washer fluid jug for scale:
    Ldti1blaj14RjufGMwxAm3JNUsN-aMTnoG6E__gY_2e164f77d847741f202c12f9ca11dafd35fc5cd5.jpg
    Total cost to my door was $360 CAD including UPS shipping and brokerage fees.
    Source: https://www.aliexpress.com/item/32844083327.html According to the seller, be sure to select UPS Express shipping option to avoid the parcel getting backed up at port (thanks corona...). It arrived 11 days after ordering.
    Atlas86, Tridet167, Snail81 and 2 others like this.
  3. Aug 30, 2020 at 8:13 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    The next pic I posted was after the fist pass
    llamasmurf[QUOTED] likes this.
  4. Aug 30, 2020 at 8:14 AM
    llamasmurf
    Wes
    Northern Ontario
    Great air up time on that unit for sure.
    Now we see how long it lasts. How does the quality of the unit feel? Last a few years or just like cnd tire cheapies?
  5. Aug 30, 2020 at 8:17 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Why did you choose to go this route over some of the more popular/field-tested options? It doesn't seem to be any cheaper
  6. Aug 30, 2020 at 8:23 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    highly recommend looking into new lowers or ensuring you have new bushings ready to go in. Just did a siniliar mod for @Manfred and the old cams had to be cut out. We replaced with all new lowers but can get new bushings for your existing LCA’s. The white line bushings on Amazon are $180 and have some good reviews on tw.
    Windigo[QUOTED] likes this.
  7. Aug 30, 2020 at 8:30 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Not the same. 2nd gens have a different bolt size, but Bison makes a kit too: http://www.bisonoffroad.com/toyota-tacoma-05-15-camkit/
    llamasmurf likes this.
  8. Aug 30, 2020 at 8:37 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Can also check poly’s kit too. Only has 3 positions and is more expensive. Always good to have options though.
    Didn’t know if the bison kit when I bought, but would be interesting to compare the thickness of the cams.
  9. Aug 30, 2020 at 8:44 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Way better than the Cdn Tire cheapies. All-metal construction except the handle. Considering the short run time (~3 minutes per wheeling trip) it should last a few years :laugh: Have you ever tried the Smittybilt 2781? This is basically the twin-piston version of that, probably built in the same Chinese labor camp.
    According to the Australians, it's slightly faster than the $1000 ARB twin (go to 24:19):
    https://youtu.be/oceVHPxtWyE?t=1459
    llamasmurf[QUOTED] and Snail81 like this.
  10. Aug 30, 2020 at 8:48 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Its too bad no one makes a kit for a belt driven compressor for the tacoma.
    I think you did good with that buy.
    But like a wise man said... let's see longevity of it and only time will tell that.
    llamasmurf and Snail81 like this.
  11. Aug 30, 2020 at 8:56 AM
    Emanresu
    Emanresu Well-Known Member
    In
    Snail81 likes this.
  12. Aug 30, 2020 at 9:00 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    This looks odly familiar
    3JOH22A likes this.
  13. Aug 30, 2020 at 9:08 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    But @19Canuck had the foresight to dunk the driver's side, leaving the air intake above water.
  14. Aug 30, 2020 at 9:10 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    what does this even do? replace the rounded alignment tabs with straight cut ones?
    i'm assuming it "locks" the alignment in place by forcing us to be set to presets on each side, while the frame tabs hold it in place - but what happens if we need to fine tune it? are we shit out of luck?
    would we also need to concern ourselves with a failure point in one links to the upper control arm or something? since there is no give down at the bottom - i assume the UCA might see some more loading?
    Snail81 likes this.
  15. Aug 30, 2020 at 9:15 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Well... Welcome to the TDC!
    Tacoma Diving Experience
    The list of members as of August 2020:
    @Thyces "It's a NO GO HOLE for a reason"
    @Norilsk "Gonna go to the right and... water noises in the radio"
    @Emanresu "Let me show you what a truck on 33s can do, where 35s bailed out"
    @honkonbobo "bypass? nah..."
    @OrangeTaco101 "Doesn't look that deep"
    @19Canuck ”I did it first time!”
    added,
    so far three - 3rd gen kits and three - 2nd gen kits.
    once I get shipping estimate I am going to message those that are in.
  16. Aug 30, 2020 at 9:16 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Once you get adjustable UCA's it won't matter. It will hold the LCA settings in place though. Or I don't understand something... Anyways, a cool thing to have even on mall crawl....:rofl:
  17. Aug 30, 2020 at 9:20 AM
    llamasmurf
    Wes
    Northern Ontario
    Add me for a 2nd gen kit. I should get this. :rolleyes:
    tacoma16[OP] and Norilsk[QUOTED] like this.
  18. Aug 30, 2020 at 9:27 AM
    Norilsk
    Eugene
    Added :thumbsup:
  19. Aug 30, 2020 at 9:28 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Yep. You end up with effectively 3 positions per cam bolt. If you plan to run these, you should have SPC/Mevotech UCAs to be able to make fine adjustments from the upper ball joint.
    The UCA sees lower loads because it's much higher on the spindle, so it has more leverage relative to the tire contact patch. No issues there unless you jump the truck often, in which case Total Chaos sells double-shear kits.
    ontarioyota, tacoma16[OP] and Snail81 like this.
  20. Aug 30, 2020 at 9:39 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    So because i have nothing adjustable up top yet - i have no reason to get this then from the sounds of things. COnceptually sounds great, but i won't do me any good until i start looking at suspension upgrades again..
