Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Sep 7, 2020 at 5:39 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Looks like @llamasmurf is having more fun recording than the guys driving...:rofl:
    Seems like a cool trip though
  2. Sep 7, 2020 at 5:51 AM
    Emanresu
    Emanresu Well-Known Member
    Ya came with. Tiny little thing, maybe 3” high.
    Shveet[QUOTED] likes this.
  3. Sep 7, 2020 at 6:48 AM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Where did you get it?
    Shveet likes this.
  4. Sep 7, 2020 at 7:11 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Yea I get a little excited sometimes :cookiemonster:
    Snail81[QUOTED] and Shveet like this.
  5. Sep 7, 2020 at 7:21 AM
    Emanresu
    BuyTwoWayRadios.com
    Also got picked up a good handheld.
  6. Sep 7, 2020 at 8:07 AM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    What did you use to mount the tablet and other gear? Any idea on the range your getting with the Midland? I like your snorkel.
  7. Sep 7, 2020 at 8:15 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Just need @tacoma16 to add it to the front page :D
    But looks like i missed a bunch of fun. But i got the tires corrcted so i'll have that fun at Ardbeg
  8. Sep 7, 2020 at 8:16 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I have a file stiched up by @honkonbobo on hand but its on the desktop i can send it your way when i get back from the cottage
  9. Sep 7, 2020 at 8:18 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Perfect. Been looking for a unit like that, that way i dont need to worry about it getting ripped off as much as the full size antennas
    RoamingGnome likes this.
  10. Sep 7, 2020 at 8:20 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Also was fun with a cars and coffee this morning with the only other one showing up being @Manfred
    I swear it wasn"t an arranged date
    Manfred, Tridet167 and Snail81 like this.
  11. Sep 7, 2020 at 8:33 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I figured since mine is all apart, I should look into a replacement. But when mine goes eventually, Ill throw an OEM rack. Cant fork that out right meow with all the other parts to buy.
    Didn't even know this was happening.....
  12. Sep 7, 2020 at 9:18 AM
    Emanresu
    The Midland and mics are mounted on . Mics are on Ram mounts w/ expedition Essentials mic bracket. The Midland radio is mounted w/ the supplied bracket and some PTFE spacers. Uniden CB is mounted in the cubby above the Qi charger w/ spacers and fender washers. The iPad is mounted to the pass seat bolt with Ram Mount Vehicle Mount.
    As far as range, I still need to give it a proper test. But definitely better than anything I've used in the past. After install just messed around quick... Handed the wife the handheld, she was bathing our son so was in washroom indoors. I went for a quick ride aprox 6km's before turning back. There were plenty of apartment, condo and commercial buildings between us. Little to no static and sound/clarity was mint. This was the mobile unit to a handheld, can only imagine how good it would be mobile to mobile!
  13. Sep 7, 2020 at 9:23 AM
    Emanresu
    Definitely a sturdy little antenna.
  14. Sep 7, 2020 at 9:44 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    It was an impromtu meet up :cookiemonster:
    He was in the area so figured to hang out for an hour
    @Snail81 was suppose to show up but something came up
    @ODSC1 bailed last minute and said hed show up next week
    :stirthepot:
    Just pulling your legs guys, i got to relax for the weekend so i'm glad about that. We'll group up another time, not sure the first weekend of October since that's Ardbeg
  15. Sep 7, 2020 at 9:54 AM
    ODSC1
    London ON
    2017 DCSB Sport MT
    I like that RAM vehicle mount. That wasn't something I was aware of for the tablet. How do you have all that stuff powered? The little USB adapter I have seems to struggle powering a lot of equipment.
    Shveet likes this.
  16. Sep 7, 2020 at 10:17 AM
    Emanresu
    The mount is good. The "tower" is a aluminum rod which you bend to conform how you like. There are some who say it vibrates and comes loose over time being the Al compresses in the clamps. Others seems to not have an issue. Once Im happy with the placement, I will remove and bend a steel rod to the same shape to avoid any problems. However, so far seems fine.
    Power... iPad for now is using the factory USB. I will likely, eventually conceal and power this independently. Radios are powered from fuse panel through a ignition circuit to only have power when vehicle is on to avoid forgetting and having a power drain and grounded to chassis. Both radios have memory setting to resume to same state once power is supplied ie; start truck and radios turn on or stay off depending how you left them last time you turned the vehicle off.
  17. Sep 7, 2020 at 10:34 AM
    llamasmurf
    Wes
    Northern Ontario
    Sweet setup man, your truck looks awesome now. As well as way more functional.
    It has changed fast :eek:
  18. Sep 7, 2020 at 10:43 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Is an oem rack that much better?
  19. Sep 7, 2020 at 10:55 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Well, I have heard of aftermarket racks leaking prematurely. Just thinking that the OEM rack is only a couple hundred more than a Napa new one, and mine had lasted over 200k (100k in 33’s and about 30kish on 35’s). See how it goes.
    Thyces[QUOTED] and llamasmurf like this.
  20. Sep 7, 2020 at 1:09 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    I found out friday night myself lol
