Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Sep 22, 2017 at 5:00 AM
    #3201
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    20170922_075535.jpg 20170922_075601.jpg 20170922_075618.jpg 20170922_075632_HDR.jpg 20170922_075546.jpg
    This morning
    Bocsy44, Kemosabe, llamasmurf and 2 others like this.
  2. Sep 22, 2017 at 5:13 AM
    #3202
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Saweet!!!! I guess you are limited by your shocks now.
    curious how the shackles handle the weight over time. Btw what length did you go with for extended brake lines? Another question, how are you dealing with the parking brake? That bugger must be super tight.
  3. Sep 22, 2017 at 5:23 AM
    #3203
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Lines are from Wheeler's.... Whatever their longest ones were. Parking brake hasn't been an issue since I removed originals and made my own brackets, actually still have some slack at full droop. Did that before Ardbeg.
    Shocks are retardedly long so it seems they may be ok (29.82"extended 17.49" collapsed) still worried about bottoming out at full compression though. I decided I'm going to make a spacer to go under the bumpstop or weld to the top plate.
    tacoma16[QUOTED][OP] likes this.
  4. Sep 22, 2017 at 5:41 AM
    #3204
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Noted. By the way I don't know if I sent you this, but Ill leave this here for ya :D
    https://www.tacomaworld.com/threads/a-different-approach-to-rear-shock-relocation.461500/
    Just in case you need to make that rear a little more interesting! Also they have some measurements there that may help.
  5. Sep 22, 2017 at 5:43 AM
    #3205
    Thyces
    Ontario
    2009 DCLB TRD Sport
  6. Sep 22, 2017 at 6:47 AM
    #3206
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Looks good! How does it feel on pavement when cornering? I have read the shackle flip makes the rear end squirrelly.
  7. Sep 22, 2017 at 6:49 AM
    #3207
    Thyces
    Ontario
    2009 DCLB TRD Sport
    There is definitely more lean. Nothing to make me feel unsafe though....and I don't slow down too much when cornering...
    :burnrubber:
    tacoma16[OP] likes this.
  8. Sep 22, 2017 at 6:50 AM
    #3208
    KenLyns
    Belly of the Beast
    Alternatively run a U-bolt flip kit. The U-bolt clamp plate acts as a 1/2" spacer for the bumpstops.
  9. Sep 22, 2017 at 6:52 AM
    #3209
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Good idea but an expensive 1/2". I'm considering cutting a 1/4" off a hockey puck and using the 3/4.
    tacoma16[OP] and Kemosabe like this.
  10. Sep 22, 2017 at 6:55 AM
    #3210
    KenLyns
    Belly of the Beast
    ^U-bolt flip is more for gaining a little bit more clearance under the axle.
  11. Sep 22, 2017 at 7:13 AM
    #3211
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Yup. Only need the bumpstop height though.
  12. Sep 22, 2017 at 10:40 AM
    #3212
    Theicemedic
    Theicemedic Well-Known Member
    Eric
    2007 TRD Off-Road short bed
    Bilstein 5100's pelfrybilt front bumper. relentless fab hi-clearance rear. front runner slimline 2 Rigid industires light bar, pods and ditch lights. Smittybilt 9.5k winch
    School got crazy this week, I have been absent on here sadly. I'll make sure to get it to you tonight
  13. Sep 22, 2017 at 10:47 AM
    #3213
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Curious how many would be down for a day run tomorrow at Minden hydroline
  14. Sep 22, 2017 at 10:52 AM
    #3214
    Joe23
    I've got dakars and Fox extended length just waiting to go in. Should gain a decent amount from that
  15. Sep 22, 2017 at 10:59 AM
    #3215
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I am only down to go on the full weekends now. Too lazy to change shoes just for a day :)
    Joe23[QUOTED] likes this.
  16. Sep 22, 2017 at 11:19 AM
    #3216
    Taco-Can
    Taco-Can Well-Known Member
    Glenn
    Port Hope, Ontario, Canada
    2015 TRD Off Road Access Cab
    I ran the trail right from the trailhead to the end during Camp NL this past August.
    It's s fun one. But, I would not consider this an easy trail for the Tacomas. It is correcly rates as a 3+. Below is the OF4WD brief description of the trail.
    The water just adds to the degree of difficulty. Hope this helps
    G
    tacoma16[OP] and Joe23[QUOTED] like this.
  17. Sep 22, 2017 at 11:47 AM
    #3217
    Joe23
    You suck.
    I'd do whole weekend but grandfather's birthday is Sunday
  18. Sep 22, 2017 at 11:54 AM
    #3218
    Taco-Can
    Glenn
    I'm going to pass for this weekend, but I'm down with a run after Thanksgiving.
    I'd prefer to do a Bobcaygeon trail (concession lake, old logging road or crystal lake), but my arm can be twisted...
  19. Sep 22, 2017 at 11:55 AM
    #3219
    Taco-Can
    Glenn
    When you installing this fine hardware?
  20. Sep 22, 2017 at 12:00 PM
    #3220
    Joe23
    It's only an additional 30 min to go to Minden don't be difficult Glenn lol.
    If old logging out Crystal Lake are doable relatively stock I'm down though.
    Taco-Can[QUOTED] likes this.
