Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Nov 8, 2020 at 4:53 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Skidnplates..... noooooo.
    You need this
    https://youtu.be/z7_t_uyGG88
    gabbo2112, Shveet and Tridet167 like this.
  2. Nov 8, 2020 at 4:54 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I have 3/16 steel and it takes hits random times. Certain parts of the skids have bent. Sliders are also steel bars and have hit and been dragged but still good. I would stay away from aluminum if you plan on doing any wheeling. You will always hit something when you least expect it.
    3JOH22A and llamasmurf like this.
  3. Nov 8, 2020 at 4:55 PM
    Tridet167
    Tony
    Toronto, Canada
  4. Nov 8, 2020 at 5:04 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I need the flour tortilla skid plates 86074B80-D330-4ACD-B1B8-167CF2077992.jpg
  5. Nov 8, 2020 at 5:11 PM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
    Snail81, gabbo2112, Shveet and 6 others like this.
  6. Nov 8, 2020 at 5:39 PM
    Tridet167
    Tony
    Toronto, Canada
  7. Nov 8, 2020 at 5:42 PM
    Tridet167
    Tony
    Toronto, Canada
  8. Nov 8, 2020 at 6:36 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Shveet and llamasmurf like this.
  9. Nov 8, 2020 at 6:41 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    They look the same as the Amazon ones I bought at literally half that price earlier this year...
  10. Nov 8, 2020 at 6:47 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    They all look pretty similar. Not sure if this is one of those things that can be lowest price wins or not. I suppose use once and destroy is fine if you only need it once but multiple uses would be nice. I definitely can't justify $300-500 though. I'd also probably be more likely to use in winter (without breaking) but most don't list that capability.
    llamasmurf likes this.
  11. Nov 8, 2020 at 6:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Comparing against @llamasmurf's MaxTrax clones, the Chineseium boards have half the material thickness. They'll probably last a few uses, but not the 50+ uses Wes put his through...
  12. Nov 8, 2020 at 7:03 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Compare the roof height relative to Greg. He kept the truck surprisingly low while packing 43" tires and Dynatrac 80 axles under it.
    Windigo[QUOTED] likes this.
  13. Nov 9, 2020 at 5:25 AM
    CanadianJay
    CanadianJay Member
    2017 Tacoma DCLB Limited
    Basically stock... ya its stock!
    Anyone know which TPMS sensors are for these rims? And perhaps where I can get a decent set without having to pay $60 each?
    I believe they are different from the ones on the OEM alloy rims. Those are the steelers from a second Gen I believe.
    Thanks
    Shveet likes this.
  14. Nov 9, 2020 at 7:54 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    To my understanding tpms are universal fit. But
    $60 each? The trd gen ones are like $25 at the stealership. Atleast thats what i paid for mine o_O
  15. Nov 9, 2020 at 8:05 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Question. About adjustable UCA and LCA. Any recommendations that would still work with the stock struts and spring but i can make room for a larger set like a billy 6112 or something?
    I might just do the adjustments and get it ready for a lift...
    But this is also me bored out of my mind at home waiting for the truck to have the recall dealt with
  16. Nov 9, 2020 at 8:08 AM
    CanadianJay
    CanadianJay Member
    Before I got the tires my mechanic mentioned how much OEM from Toyota TPMS sensors were and was like 60 each one!
    Even looking online, usually around 60 and per unit. Not a set..
    Also there are different ones for steel and alloy wheels, then there's ones with a different degree of angle...
    I may just run without at this point but I'd rather have them
    19Canuck likes this.
  17. Nov 9, 2020 at 8:59 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I would say for most people the chineseium boards would be ok. My cheap boards lasted me 2 seasons of pretty hard use, but they exploded on the 2nd winter season of true hard use.
    Id say I manged to get 12 or so recoveries out of my cheap boards.
    Ass sploded boards, all 4 of em.
    :boom:
    Shveet likes this.
  18. Nov 9, 2020 at 9:07 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    If you want to put 6112 or similar stock LCA is sufficient for that use. UCA any brand works as long as it has ball joint style, doesn’t matter really beyond that.
    It’s when you plan on mid travel or LT you better start looking into LCA. But again, I don’t see you running big tires on your truck :duh:
  19. Nov 9, 2020 at 9:10 AM
    JWFortin
    JWFortin Well-Known Member
    Jer
    Southern Ontario, Canada
    '17 Blazing Blue Double Cab Off-Road
    Every ME-SO mod but Bro Pro tails and 3rd brake - SCS SR8's with 255/85R16 ST Maxx - Prinsu Rack with Cali raised 42" slim light bar - TRD Pro grill - SDHQ dual behind the grille light mount with 2x 32" light bars - Cali Raised low profile ditch mounts with Cali pods - BakFlip MX4 Tonneau - WARN Semi-Hidden winch mount bumper - Bilstein 5100's all around with OME 887's - Anytime front/rear camera - Matte black EGR in-channel window visors - Matte Black Nox-Lux Overlay/Tailgate inserts - Interior Blackout kit (incl. black Highlander door handles and Sienna mirror control knob)/Blue door sill/glove box inserts Still wanting: Pelfreybilt or Mobtown Off-Road rear bumper
    When I did mine a year and a half ago, the place I went to got the sensors from the local stealership. They only cost me an extra $50 or $60 for the full set of 4 by them getting directly from Toyota.
  20. Nov 9, 2020 at 11:19 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    ooooh fair enough,
    so i'd just need UCAs if i also want to push caster forward so i can stop rubbing against my cab mounts
    Snail81 and Norilsk[QUOTED] like this.
