Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Nov 12, 2020 at 4:47 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    And no pushbutton start, proximity sensor, wireless charging, tpms and other things that really shouldn't be a factor as to MT/AT. A friend bought a 2020 mt and it has the same or fewer features than my 2017. Although I think it has adaptive cruise
  2. Nov 12, 2020 at 6:36 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    Yep exactly thats what I meant when I said "seems like there are some strange differences between the 2021 auto trans TRD OR trim level and the manual trans TRD OR"
  3. Nov 12, 2020 at 6:41 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    It costs more to put quality and reliable transmission for Toyota, so they have to sacrifice other gimmicks :D
    Anyone here got friends working for Mazda dealer? :anonymous:
  4. Nov 12, 2020 at 8:44 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    I got a couple working in the North Bay dealer, car shopping?
  5. Nov 12, 2020 at 8:48 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    He's looking to put 35" tires on his Mazda 3, and needs a few parts....
  6. Nov 12, 2020 at 8:58 AM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    I think I might have a set of rims from an '81 RX7 for that project!
  7. Nov 12, 2020 at 11:02 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Hmmmm. Possibly meet up and exchange leafs too lol
  8. Nov 12, 2020 at 11:04 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Our brakes use two. They are cheap at Napa. I may have some extras in the parts bin. Wouldn’t be worth your travels though based on the cost of a new one.
  9. Nov 12, 2020 at 11:56 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    anyone know a good place to get an secondary air injection pump
    Edit: just ordered one from Amazon.
  10. Nov 12, 2020 at 12:46 PM
    Norilsk
    Eugene
    Yeah, want base manual, need DD before SAS starts.
    :anonymous: This is after SAS
  11. Nov 12, 2020 at 12:53 PM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    Haha this sounds ideal.
    :annoyed: must put leafs into Taco. Hoping to git’r done before winter arrives, slowly but surely running out of time.
  12. Nov 12, 2020 at 1:02 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I still have the pin so it's a matter of bending it back. Problem solved.
  13. Nov 12, 2020 at 2:06 PM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Ask for Cody at the dealer and tell him Brent referred you. He's finance manager now but still sells a bit (applies to the rest of you I guess).
    I'll let him know I'm referring someone, maybe my name will get you something worth while, maybe not.
    If I can figure out the DM on this forum ill send you his number.
  14. Nov 12, 2020 at 2:36 PM
    Tridet167
    Tony
    Toronto, Canada
    I'll just straighten out the existing pin and re insert it.
  15. Nov 12, 2020 at 2:38 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    I know a Brent...hes a cunt.
    Are you a cunt?
    My name is Brent.
    Look over at the avie you want to have a chat with and click "Start a Conversation"
    Asshole
  16. Nov 12, 2020 at 4:38 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Toyota designed the pins to have a tight fit with the brake pads for some reason. If you straighten the existing pin, you'll want to drill out the holes on the pads slightly oversize to make sure they don't bind up on the pin (which would cause uneven pad wear). Lube the pin up with your favorite pumpkin spice caliper grease.
  17. Nov 12, 2020 at 5:15 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Story of my life. I got my diff in yesterday and driver side axle in today and torqued what I could. Tomorrow is passenger side axle, driveshaft and re-torque. Fluid Saturday and time for a drive! Only been like 3-4 months I think.
    could work. As mentioned they are snug fit.
  18. Nov 13, 2020 at 3:11 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Was playing around in Techstream reading all the different data files and snooping around,
    Hidden under the SR5/Airbag -> Utility there is a data file called "Vehicle Control History"
    from the first key turn to today it has a history of every time the brakes were hit hard, gas was stomped on, VSC/TCS events etc.
    Lol Shity picture... This gets stored in the Nav system some where... non erasable in Techstream...
    TCS/VSC events also stores the individual wheel speeds, vehicle speed, steering wheel angle, gas pedal position, brake pressure and if the brake pedal is pushed....
    This information is what is used for the driver's score in the 2020+ Tacoma. (as well as your trip data)
    Forget "Big Brother" even the '16-19's are like a little brother (gonna rat you out every time you have some fun!)
  19. Nov 13, 2020 at 3:18 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    @Norilsk good FYI for no reason....track driven only....
  20. Nov 13, 2020 at 3:29 PM
    TeecoTaco
    SW Ontario
    Dood! Nice find! I'm gonna export mine then. Analytics dream data
