Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Nov 20, 2020 at 6:08 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  2. Nov 20, 2020 at 6:20 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Unfortunately they aren't nearly as beefy as the Archive Garage skids I got for the rear sensors - no robust mounting points on the spindle. Slightly more protection from the odd tree branch.
  3. Nov 20, 2020 at 6:23 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Atlas86 and ontarioyota like this.
  4. Nov 20, 2020 at 6:27 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    If you get the $$$$ Camburg spindles, they move the ABS sensor to the top of the hub for extra protection.
    llamasmurf[QUOTED] likes this.
  5. Nov 20, 2020 at 6:34 PM
    llamasmurf
    Wes
    Northern Ontario
    Good to know, for future purchases :thumbsup:
  6. Nov 20, 2020 at 6:42 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    And I’m over here trying to delete the rear sensors and figure out how to delete the front for axle swaps. Will loose abs and the traction control stuff (unless I integrate into new axles) but for the rear speed sensors, that will be picked up at the tcase.
    ontarioyota and llamasmurf like this.
  7. Nov 21, 2020 at 7:01 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    If you can't integrate into the new axles... couldn't you give them the same signal as you do for the rear...? Won't help with the ABS and TC but would fool the computer for the most part.
  8. Nov 21, 2020 at 7:57 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    one ton axle swap is a drastic change to the vehicle drive train, as such other drastic changes might be in order.
    forget traction control
    forget abs
    and loose the bulbs in the dash
    eventually you'll have an atlas for for get the t case too..
    your going from a panther moving in the bush to an black rhino who moves the bush...
  9. Nov 21, 2020 at 10:11 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I orettt much expect an abs light. However are trucks depend on the speed sensor for the shift points in the tranny. Easy enough to do with some wiring.
  10. Nov 21, 2020 at 10:43 AM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    Manual transmission swap can fix that.
  11. Nov 21, 2020 at 10:48 AM
    Windigo
    Farook
    '14 Acess Cab
    I hear you man. please document everything, part #'s, install instructions and even homemade parts.
    that is something i wish i had done in the past and now im older i forgot it all.... lol.
    if you have a build thread of this please share
    tacoma16[QUOTED][OP] likes this.
  12. Nov 21, 2020 at 10:54 AM
    weight
    Kevin
    Ontario, Canada
    Entering the Red Zone. Lockdown preparations...
  13. Nov 21, 2020 at 10:55 AM
    Windigo
    Farook
    '14 Acess Cab
  14. Nov 21, 2020 at 2:19 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    So what are you gonna drink after the weekend?
  15. Nov 21, 2020 at 2:24 PM
    weight
    Kevin
    Ontario, Canada
    I’ll worry about that Monday morning.
  16. Nov 21, 2020 at 2:25 PM
    Windigo
    Farook
    '14 Acess Cab
    at least save one for breakfast..lol
    ontarioyota, gabbo2112 and daks like this.
  17. Nov 21, 2020 at 3:11 PM
    llamasmurf
    Wes
    Northern Ontario
    Could not stop thinking about this trail being a mess. Had to go back and get it all cleaned up.
    Got rid of the widow maker.
    Got some firewood, its not hardwood but it will burn so meh.
  18. Nov 21, 2020 at 4:56 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’m a bad driver as it is. Auto for the win lol.
    I will let you know.
    Right now I (and you) can use a manual speed sensor that goies into tcase. Allows you to get rid of the speed sensors and keeps everything toyota. I’ll be documenting this the best I can.
    llamasmurf likes this.
  19. Nov 21, 2020 at 4:58 PM
    Windigo
    Farook
    '14 Acess Cab
    Appricated because I'm a monkey see monkey do kind of guy. :):)
    tacoma16[QUOTED][OP] and Snail81 like this.
  20. Nov 21, 2020 at 5:50 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Picked up this milwaukee inverter today. It uses any of their 18v batteries and you can use USB-A or USB-C or 175w inverter. Playing around a bit with it this afternoon, I was able to power the camp fridge with a 5amp battery for a little over 4hrs. I'm impressed.
    Shveet, 3JOH22A, gabbo2112 and 8 others like this.
