Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 9, 2021 at 6:54 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Well If I were to do it again..... Right now I have 17x9 with a -6 offset and for me its a little to close to the calipers about a finger tip and it rubs oh so slightly on the uca's at full lock. Thats with a 315 70 17 tire though.
    If I were to do it again.... 17x9 with a -12 offset.
    19Canuck likes this.
  2. Jan 9, 2021 at 6:57 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Im thinking that to fit the tire I want I will also have to with a negative offset rather than a zero.
    tacoma16[OP] likes this.
  3. Jan 9, 2021 at 6:57 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    8.5 or 9 doesn’t make a huge difference. In relation to back spacing and offset though it does as @Windigo has mentioned.
    I’m running -38 offset with 3.5” of backspacing. All that is on a 9” wide rim. This is again for 315’s. I would recommend using a rim fitment calculator to make sure the poke and fitment is to your liking.
    19Canuck[QUOTED] and Windigo like this.
  4. Jan 9, 2021 at 7:01 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    I just want to make sure I don't have to chop anything. I don't mind trimming a little plastic or removing the flaps but I want to avoid any major cutting.
  5. Jan 9, 2021 at 7:01 AM
    Windigo
    Farook
    '14 Acess Cab
    Good advise, I have a set of rims sitting in the garage because I did not do my homework and they hit the calipers when bolted on. So yes do the homework, mind you I could of used them with spacers but the "poke" would be too much
  6. Jan 9, 2021 at 7:14 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    285’s you are most likely going to to have to do a cab mount chop. All depends on your alignment as well. With a Max caster pushing the wheel forward, you can help it. Biggest thing is you want the tire off things you can’t cut off like the upper control arm or the spindle.
  7. Jan 9, 2021 at 7:22 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    WE have a shop here in town that has done a zillion trucks, so they know the numbers as far as offset and tire size goes.
    I'm also looking for wheel and tire suggestions...I'm a sucker for a five spoke...lol.
    tacoma16[QUOTED][OP] and Snail81 like this.
  8. Jan 9, 2021 at 7:25 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    F5s end of discussion for the rims
    tires anything you desire, there is no right answer. I run ATs that look more like hwy tire than off-road. Gets me everywhere.
    Snail81 and 19Canuck[QUOTED] like this.
  9. Jan 9, 2021 at 7:29 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Oh yes I do like the Stealth...:thumbsup:
    Norilsk[QUOTED] and tacoma16[OP] like this.
  10. Jan 9, 2021 at 7:32 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Me too
  11. Jan 9, 2021 at 7:33 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Are your trucks "making out"?
    I'm kinda concerned about you two.
  12. Jan 9, 2021 at 7:42 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Obviously the trucks are making out. The real question is: where are they?
    Norilsk likes this.
  13. Jan 9, 2021 at 7:43 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    I don't think anyone wants to go there.
    Norilsk and Snail81[QUOTED] like this.
  14. Jan 9, 2021 at 7:52 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    i thought this was a safe place!
    it was all for the gram! picture was taken in Ardbeg.
  15. Jan 9, 2021 at 8:10 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Nothing is safe here...
    tacoma16[QUOTED][OP] and Norilsk like this.
  16. Jan 9, 2021 at 8:12 AM
    Norilsk
    Eugene
    You are next then! After you get the F5s :canada:
  17. Jan 9, 2021 at 8:17 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    yeah, especially our wallets!
    hurray!
    Norilsk[QUOTED] and Snail81 like this.
  18. Jan 9, 2021 at 8:18 AM
    Snail81
    Igor
    Right here, Ontario
  19. Jan 9, 2021 at 8:25 AM
    Norilsk
    Eugene
    We can have 3some:boink::bananadead::anonymous:
  20. Jan 9, 2021 at 8:30 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    I didn't see it going this far.
    Norilsk[QUOTED] likes this.
