Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 22, 2021 at 10:47 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    How much does it cost to print this? I see black ABS filament is just under $40 for a 2-lb spool on Amazon, so something that weighs half a pound would be about $10 in materials, plus other consumables and machine time?
  2. Jan 22, 2021 at 10:49 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Walmart rubber sheet :stirthepot:
    OJQmkWu_lO8kufIkWgjMgM_iHCaAdxsEPXFYk1bu_4e92ef6cfc3cfd465c4c59d6d16c4a6d90fd50ca.jpg 1O8FwPlAAhDNUB827d6Chz1j8LJiyAQG1Dt06C9d_fe61fe8643db06ccb18175334de26243c9bca7f7.jpg
  3. Jan 22, 2021 at 11:25 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    I print with pla, 2lbs is about 30 bucks. You're pretty accurate there. This tray probably cost me 2-3 bucks to print. used 100 grams of material, and took 20ish hours, most of it off peak hours so probably half of that was electricity.
    Shveet likes this.
  4. Jan 22, 2021 at 11:26 AM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    I did the same thing going to Attawapiskat last March. I took 80 litres with me. There was gas available but it sure is pricey compared to Southern Ontario.
    Intrepid, Shveet and Windigo[QUOTED] like this.
  5. Jan 22, 2021 at 11:28 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    20L of fuel is about 33 lbs, already cumbersome to juggle at shoulder-height to pour into the vehicle without spillage. I'd hate to add another 10 lbs with a metal jerrycan.
    Metal jerrycans don't balloon as much under the hot sun. That's the only real benefit IMO.
    Tridet167 and Shveet like this.
  6. Jan 22, 2021 at 11:30 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    pfft dont hold anything anywhere, just put it in the bed. Put this bad boy in. Listen for gurgle when done.
    https://www.canadiantire.ca/en/pdp/shaker-siphon-hose-0283109p.html
    I have 2, one for water, and one for gas.
  7. Jan 22, 2021 at 11:30 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Cool. Do you have experience with PLA parts in vehicle interiors? From what I've read, PLA is biodegradable and has a narrow temperature range.
  8. Jan 22, 2021 at 11:31 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    I have on on my keychain, and have never had an issue. I guess we'll see. My friend has one as a hood ornament and never had an issue either.
    3JOH22A[QUOTED] likes this.
  9. Jan 22, 2021 at 12:18 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Yes sir they sure are. They came with the cabin when I bought it 20 years ago and are certainly antiques. I also have two double sets....... they work good for hanging a big Tom turkey from his spurs
  10. Jan 22, 2021 at 12:21 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Ouch! I did the same thing Splitting some kindling and hit my left index finger between the knuckle in the first joint and broke it. I had a good leather glove on and it saved a lot of tissue damage.
  11. Jan 22, 2021 at 12:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Didn't know the existence of this tool! Watched a couple of Youtube and it seems easy to use. Ordered! :spending:
  12. Jan 22, 2021 at 12:53 PM
    llamasmurf
    Wes
    Northern Ontario
    When I found it at cnd tire I was like 'No way this is a thing'
    They work so good, never have to get gas in your mouth again.
  13. Jan 22, 2021 at 1:45 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Have had one for about 3 yrs now...work well
  14. Jan 22, 2021 at 1:48 PM
    vonclicas
    vonclicas Well-Known Member
    Filipe
    Lx470
    33” mud tires
  15. Jan 22, 2021 at 2:02 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    and i use this whenever I'm feeling lazy. leaks gas all over my hands after about the first 10 uses
  16. Jan 22, 2021 at 4:20 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The item was ready for curbside pickup just 50 minutes after ordering. Canadian Tire got its act together:
    SIkIrfcP6JoJ3kwN9MV6oeazrn383-zL4FitYP7R_afdd743053a969c0f342c9f5a9fa4f830124358f.jpg
    Interesting to see how it's built - to prevent backflow, there's a weak check valve consisting of a spring-loaded glass ball that opens with shaking to allow the tube to be filled. Very simple construction, but if you were to design one from scratch, getting the right spring rate and ball weight would take much trial-and-error.
    Intrepid, ontarioyota, weight and 2 others like this.
  17. Jan 22, 2021 at 6:11 PM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    Glad Canadian Tire got the curbside pick up sorted out. I’m still waiting on gloves from March/April. Last time I tried to get them was June and they said they may have been stolen. I never would have thought Mechanix gloves were such a rare item.
    llamasmurf and Shveet like this.
  18. Jan 22, 2021 at 6:49 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Were they at a big discount? Why don't you just cancel the order and re-order?
  19. Jan 22, 2021 at 9:37 PM
    weight
    Kevin
    Ontario, Canada
    1/2 price. They haven’t got new inventory in stock since.
    3JOH22A[QUOTED] and llamasmurf like this.
  20. Jan 23, 2021 at 6:15 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    The spring is probably only there as a “safety.”
    Could get away with no spring the back pressure would pull the ball back into place. Would only have to slow the flow backwards enough that the gas stays in the tube.
    *edit* might also be the slightest bit more efficient for initial start with the spring in though, but could also restrict flow a bit when going.
    3JOH22A[QUOTED] and ontarioyota like this.
