Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 24, 2021 at 11:29 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    40" lightbar, I run the single row and @Manfred runs the fancier dual row version of it. Picked it up on sale for $100 but i don't seem to see it anymore. might have been just a clearance thing.
    https://speeddemonlights.ca/collections/lightbars
    pod lights; i grabbed the "white flood" version, it's more of a Spot flood combo than a flood.
    the spot beam one is a true spot from the looks of things.
    https://www.amazon.ca/gp/product/B086HBSH24/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    flood;
    spot;
    Manfred likes this.
  2. Jan 24, 2021 at 11:39 AM
    TRDTaco420
    TRDTaco420 Chum is Fum
    The Bear
    Tacoville - Canada Eh!
    2019 Mid. Blk. Met. ACLB TRD Off-Road
    Kewl shizz
    The only thing is I wish, is that it was warmer to do more stuff.
  3. Jan 24, 2021 at 11:41 AM
    TRDTaco420
    The Bear
    Kewl shizz
    Thanks for shining a light on things.
    ontarioyota and 3JOH22A like this.
  4. Jan 24, 2021 at 11:42 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    When curbside pickup first started after Christmas, they included a $10 off coupon (min. $20 purchase) when I picked up the order. I promptly used the coupon on a subsequent order. Of course they gave another coupon when I picked that up. Talk about feeding an addiction. :bananadead:
    LandoFernano and ontarioyota like this.
  5. Jan 24, 2021 at 11:46 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Take that tree strap back. It is not for use with a truck.
    My tree saver is rated for 30K lbs and truck use.
    What if you go to help someone with a full size F250 that has a small to medium load in the back or something and use that? Nothing with an ATV rating should be in a recovery kit for a truck.
    Tridet167, Slick Taco and Shveet like this.
  6. Jan 24, 2021 at 12:15 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Why do you say that? 2021 F250 fully loaded to GVWR is about 10,000 lbs, which this strap can pull up a 50% grade buried to the hubs (1.5x weight multiplier). And that's with the strap looped thru itself in a "noose" config. If it's wrapped around an axle with both ends connected to the rope, then the capacity doubles. There will be no safety margin at that point, but it's a contrived situation. Nobody we wheel with is approaching anywhere near 10,000 lbs.
    honkonbobo likes this.
  7. Jan 24, 2021 at 12:26 PM
    vonclicas
    vonclicas Well-Known Member
    Filipe
    Lx470
    33” mud tires
    You see? They keep on tricking you! :angrygirl:
  8. Jan 24, 2021 at 12:31 PM
    vonclicas
    Filipe
    Lx470
    33” mud tires
    I think we normally have to at least double it or even triple.
    My truck is 5000lb, I use 20k lbs + rated stuff. Which should be a 10000lb min, etc...
    But I am sure there is guys here that can explain better.
  9. Jan 24, 2021 at 12:33 PM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    Alright. Reviews look pretty good and the price is right. Item is no longer in my cart. Haven't been given a delivery date but I can wait. Won't be installing until the weather is warmer anyway.
    ontarioyota and 3JOH22A[QUOTED] like this.
  10. Jan 24, 2021 at 12:33 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    I only have a 3 inch.
  11. Jan 24, 2021 at 12:36 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Ya I'd be interested to see what you backspace/offset is.
  12. Jan 24, 2021 at 12:48 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    If you're buried to the top of your tire, the extraction force will be roughly double the weight of your rig (10,000 lb). Add additional derating factors for inclines and mechanical breakages (collapsed suspension, tire off bead, etc.). So yes, 20,000 lb equipment is therefore a comfortable number even in the worst situations. But this 15,000 lb strap will still do the job.
    Erickson's page for this particular strap P/N 09506 says 7500 lb max vehicle weight: https://ericksonmfg.com/product/4-x-6-15000-lb-tree-saver-tow-straps/ And it's a company based in southern Ontario (i.e. subject to Canadian lawsuits, etc.) not like some untraceable vendor on AliExpress.
    19Canuck and Snail81 like this.
  13. Jan 24, 2021 at 1:46 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    If anyone wants something from Ericksons pm me...I have a connection.
  14. Jan 24, 2021 at 1:47 PM
    TRDTaco420
    The Bear
    Kewl shizz
    Is it easy to access the tail running lights from the cubby beside the outlet? Anybody got a pic?
    Quick Charge 3.0 USB Charger Socket, SunnyTrip 18W 12V/24V USB Power Outlet Adapter Waterproof Car Charger with LED Voltmeter & On Off Switch for Car https://www.amazon.ca/dp/B07PZZ9C3N/ref=cm_sw_r_cp_apip_NZ2W2llJfjrFM
  15. Jan 24, 2021 at 2:00 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The cubby pulls out after removing the 6 torx bolts.
    Route the wires while looking at it underneath the truck.
    Remove the tail light (two bolts and two plastic clips) to access the wiring.
  16. Jan 24, 2021 at 2:07 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Used this tree saver few times, no issues. Pretty sure I push things to the limits, it passed my tests.:notsure:
    3JOH22A[QUOTED] likes this.
  17. Jan 24, 2021 at 3:39 PM
    Intrepid
    Intrepid Well-Known Member
    Jeff
    Toronto, Ontario CANADA
    2018 Tacoma TRD Sport double cab short box manual transmission cement grey
    ARE canopy with sliding screened windoors and rhino roof track, Warn semi-hidden winch mount with VR 10 winch, nightrider 28" single row LED lightbar, Hood scoop light bar, Anytime front and rear cameras. anytime Navigation switch, plug-in oil pan heater, plug-in block heater, plug-in battery blanket. WINTER: Snow Sport plow with back-drag modification, Bridgestone Blizzak DM V2 on steelies 265-70-17.
    There is a light at inside my scoop
  18. Jan 24, 2021 at 4:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Here he goes...
    At 04:48 he just zips off the center grille support with a portable bandsaw with no drama. :laugh:
  19. Jan 24, 2021 at 4:39 PM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
  20. Jan 24, 2021 at 4:43 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
