Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 2, 2021 at 6:10 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Good wheels, WheelsCo? The set I mentioned they had?
  2. Feb 2, 2021 at 6:17 PM
    cwisema
    cwisema Well-Known Member
    Acton, Ont.
    2017 MGM DCSB TRD Sport
    Yes, and yes. Thanks for the heads up.
    17x8.5 -10
  3. Feb 2, 2021 at 6:22 PM
    cwisema
    Acton, Ont.
    Thanks everyone. I guess I'll need to pick up some lug nuts with the extended threads. I guess I can use the ones the shop gave me for my snow tires. They're on steel rims.
  4. Feb 2, 2021 at 6:39 PM
    Norilsk
    Eugene
    I've got the same lugs you got, no issues there :notsure:
    cwisema[QUOTED] likes this.
  5. Feb 2, 2021 at 6:54 PM
    cwisema
    Acton, Ont.
    Thanks, I guess I'll test fit the rims and see how much threads I have showing. If it's not enough I'll get the ET lug nuts.
    llamasmurf and Norilsk[QUOTED] like this.
  6. Feb 2, 2021 at 7:08 PM
    vonclicas
    vonclicas Well-Known Member
    Filipe
    Lx470
    33” mud tires
    Hi guys,
    2 questions,
    my battery works flawlessly , as long i run the truck at least once every 2 weeks. It also dies if the engine is off and the doors open for half an hour.
    I was told this means the battery is not holding charge , plus can be damaging the alternator? when the engine is running, i see the batter level always at the same point.
    If you advise me to replace the battery to save the alternator, would this one be a good option ? or what else would you suggest?
    https://www.canadiantire.ca/en/pdp/...up-size-27-dual-purpose-battery-0102799p.html
    I believe biggest battery size for my truck is 27 without modifications
    thanks in advance
  7. Feb 2, 2021 at 7:25 PM
    Norilsk
    Eugene
    Start by checking your grounds, may be rusty. At what charge is your battery when your mom-van is running? At what charge is your battery when in ACC mode? Do you have aftermarket accessories that may cause battery drain?
    Realistically any AGM battery that's got warranty which you can use to exchange/ get refund is good, I have cheap Kirkland battery from Costco in group 24 size and it blasts music all night long, starts the truck next morning and holds the winch and much more. Check what's OEM size and pick the same size AGM battery.
    Batteries | Costco
    llamasmurf and ontarioyota like this.
  8. Feb 3, 2021 at 5:11 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    you rally should write poetry dude... that is funny:headbang:
    the guys at work refer to my tacoma as my van because its got a cap, so i get it:turtleride:
  9. Feb 3, 2021 at 5:25 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    All righty...now I get to pick your brain.
    Seeing as your at a -10 offset, what size tire did you get?
    Lift?
    Rub?
  10. Feb 3, 2021 at 5:52 AM
    vonclicas
    Filipe
    Lx470
    33” mud tires
    I will check those soon.
    It shows out of stock. What is the price for that group 24?
  11. Feb 3, 2021 at 6:20 AM
    cwisema
    Acton, Ont.
    I went with 255/80R17 tires. I do have a 2" lift (Fox 2.0 coilovers) but when I put my skid plates and sliders on I'm sure it's sagging by at least an inch, so maybe a net of 1" lift. I'm also still running the stock UCA.
    I haven't put the wheels on yet so I'm not sure where they will rub but I'm expecting to have to flatten the pinch weld and remove a little plastic from the mud flaps. There will be some heat gun manipulation of the fender liner as well I'm sure. A good alignment will also be required.
    I was originally looking for 0 offset wheels to ensure I didn't need the CMC, but I got a deal on these wheels and am still hoping to avoid the CMC since I'm using the 255 tires. If I have to do it, it's not the end of the world as long as t's done right. I won't be doing it myself.
    Hope this helps.
  12. Feb 3, 2021 at 6:35 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    I am also hoping to avoid the CMC...but I want to go a 285 with a zero offset. I might have to pull my horns in and go with a 265/70 instead.
    I'm running a 3 inch lift and I also am probably going to have to loose the flaps and perform some sort of heat gun surgery...for sure if I go a 285.
    Let me know how you like those Toyo's as I'm absolutely up in the air as far as tires go.
  13. Feb 3, 2021 at 7:55 AM
    416HDJ80
    416HDJ80 Member
    Ofir
    1995 HDJ80
    Is it still available for sale? can I connect it to my rear number swing arm?
    ontarioyota and llamasmurf like this.
  14. Feb 3, 2021 at 8:00 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    with a welder, anything is possible!
  15. Feb 3, 2021 at 8:28 AM
    Norilsk
    Eugene
    Yours came with Group 27F, replace with the same group 27F in AGM specs.
    Can’t remember Costco battery price, I know it was cheap under $150.
  16. Feb 3, 2021 at 8:31 AM
    Norilsk
    Eugene
    285s+ you have to cut, just accept it. It’s a tiny modification on a big scale. Those that say they don’t need to cut or trim aren’t being honest.
  17. Feb 3, 2021 at 9:02 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    I forgot to respond to you with my wheel offsets
    heres the 4wp link https://www.4wheelparts.com/p/pro-c...ter_PQMS=17+Inches&Construction_PQMS=Aluminum
    Shveet and ontarioyota like this.
  18. Feb 3, 2021 at 9:57 AM
    TRDTaco420
    TRDTaco420 Chum is Fum
    The Bear
    Tacoville - Canada Eh!
    2019 Mid. Blk. Met. ACLB TRD Off-Road
    Kewl shizz
  19. Feb 3, 2021 at 9:59 AM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
    we sell them but not with the lettering:confused:
    TRDTaco420 and Shveet like this.
  20. Feb 3, 2021 at 10:00 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
