Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 12, 2021 at 9:32 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    thats the cheap and easy part... and thanks for the reminder to grab a carrier bearing drop kit before my suspension gets here. forgot that.
    Shveet[QUOTED] and llamasmurf like this.
  2. Feb 12, 2021 at 9:58 AM
    Ginger taco
    Ginger taco Well-Known Member
    Ontario
    07 Tacoma
    @Shveet I put the Icon 3leaf aal in in the summer I don't really wheel like some people here but i have fun occasionally and mostly just haul a dirt bike or 2 around on weekends if i was to do it again i'd get a full leaf pack.
    Shveet likes this.
  3. Feb 12, 2021 at 10:05 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    It can be as cheap or as expensive as you want. It is all about what you want. :rolleyes:
  4. Feb 12, 2021 at 10:06 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
  5. Feb 12, 2021 at 10:10 AM
    llamasmurf
    Wes
    Northern Ontario
    o_O
    DESIGNED FOR: 2005-2021 TOYOTA TACOMA DOUBLE CAB
    19Canuck[QUOTED] and Shveet like this.
  6. Feb 12, 2021 at 10:21 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    :pccoffee:
    Brb ordering OEM roof rack
    llamasmurf[QUOTED] likes this.
  7. Feb 12, 2021 at 11:49 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Nope. Swapped them for my viair compressor right after Ardbeg.
    Shveet[QUOTED] likes this.
  8. Feb 12, 2021 at 12:09 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    You better off measuring your driveline angles after you put in the lift then determine IF you need to add any shims at all.
    Tacoma's sometimes respond better to pinion/axle shims before dropping the carrier bearing.
    (Mark the carrier bearing so you put it back in the same spot if you do mess with it)
    General rule of thumb is 1deg of axle shim per inch of lift.
    You may find that your factory leaf packs have a 1-2 deg shim in them.
    I alot of people don't need to use shims if they go with a full leaf pack (I didn't with my RXT pack and it was just under 2")
    Slotted pinion shims are easy to install after the leaf pack is already in...
  9. Feb 12, 2021 at 1:54 PM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    I always read that the batteries sucked in the tacos
    maybe its just the 5 days of sitting in -25
    Shveet, llamasmurf and ontarioyota like this.
  10. Feb 12, 2021 at 2:45 PM
    llamasmurf
    Wes
    Northern Ontario
    Mine sat for that time, started no issue.
    I have a cnd tire battery though.
    I killed the stock one.
    Go get one from cnd tire with the 3 year warranty, or battery battery those guys are legit.
    Damn though has it been cold latey eh Brent. Just a constant cold.
    Brrrrr
  11. Feb 12, 2021 at 2:52 PM
    Ares
    Ares Well-Known Member
    Darek
    Hamilton , ON
    2015 LTD DCLB
    almost 5 years on OEM and still going strong but I check the acid level every year
    over60, llamasmurf and ontarioyota like this.
  12. Feb 12, 2021 at 3:13 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    My 1st GEN tundra had a great stock Toyota battery… I replaced it with a Canadian Tire battery at 9 years old just as a precaution.
    My V6 RAV4 is a 2012 and still running on the stock battery. I had my Toyota dealer load test it on my last service and they said it was fine. I do all my own service on my taco and put a mid range Canadian tire group 24 in it many years ago and it’s a good battery.
    So my experience is that stock Toyota batteries are high-quality however my tundra and my RAV4 were/are very low mileage vehicles.
    Extreme heat like Texas kills batteries and extreme cold like northern Ontario or Winnipeg would obviously lower the life as well.
    over60, Sloweburn and Snail81 like this.
  13. Feb 12, 2021 at 3:24 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Its been experience that after 5 years your on borrowed time when it comes to automotive batteries.
    My 14 tacoma battery was changed 2 years ago.
    We have a 15 Corolla it got a new battery last year
    I'm still young :D so still learnimg.....
    ontarioyota, Snail81 and llamasmurf like this.
  14. Feb 12, 2021 at 3:28 PM
    llamasmurf
    Wes
    Northern Ontario
    :rofl:
    :thumbsup:
  15. Feb 12, 2021 at 3:32 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    I totally agree with you on that statement regarding five years.
    I was quite surprised that stock Toyota batteries are great with my experiences
    Windigo[QUOTED] likes this.
  16. Feb 12, 2021 at 3:42 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    AAL is less work IMO, since the stock leaf pack stays in the truck. Unscrewing the center pin is easier than unbolting the 100-lb leaf pack from the frame. As you expect AALs are potentially stiffer than replacement leaf packs depending on which brand you go with.
    Icon leaf packs come with rubber bushings bonded in. OME leaf packs come with urethane bushings packaged separately if I remember correctly with @Snail81's build - you just grease them up and press them in with carpenter clamps, channel-locks, whatever.
    With a replacement leaf pack, there's also small stuff like drilling a hole on the retainer to bolt in the E-brake cable bracket.
    I'm lifted full 4 inches in the rear and haven't needed any shims or carrier bearing drop. :notsure: You can always add those later if needed.
    Sloweburn, Snail81 and llamasmurf like this.
  17. Feb 12, 2021 at 3:44 PM
    Windigo
    Farook
    '14 Acess Cab
    I need naps, I need a cookie.every now and then, there's velcro on my running shoes,
    I get cranky if I don't sleep enough, and I don't want to go to bed at night........
    Yep still young.. :):):)
    Sloweburn, TacooSaucee, ODSC1 and 4 others like this.
  18. Feb 12, 2021 at 3:50 PM
    Snail81
    Igor
    Right here, Ontario
    Your memory serves you well. Mine came in by hand after greasing.
    You have no vibrations as well as @daks (now that's funny AH). My assumption is it's because you run high shelf leaf packs. It might be caused by the way they are designed.
    ontarioyota and llamasmurf like this.
  19. Feb 12, 2021 at 3:53 PM
    llamasmurf
    Wes
    Northern Ontario
    RoamingGnome and ontarioyota like this.
  20. Feb 12, 2021 at 3:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Is that pronounced "smurf diagnostic command"? :p
    Snail81 and llamasmurf[QUOTED] like this.
