Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 19, 2021 at 5:57 AM
    vonclicas
    vonclicas Well-Known Member
    Filipe
    Lx470
    33” mud tires
  2. Feb 19, 2021 at 6:00 AM
    philth
    philth .
    LOL I keep looking for ‘em on various places, but they’re hard to come by. Especially MY20 onward.
    I don’t plan on lifting the truck or doing any ridiculous off roading so the stock bils are fine; BUT, if I can slap on the pro fox set-up, I’d be all about it.
    ipartner and Shveet[QUOTED] like this.
  3. Feb 19, 2021 at 6:04 AM
    philth
    philth .
    Make sure your VIN isn’t visible from the exterior and invest in an OBD port locker.
    Exactly the same method a locksmith would use.
  4. Feb 19, 2021 at 7:12 AM
    crumbsXcountry
    crumbsXcountry Well-Known Member
    Chuck
    Vancouver, BC, Canada
    2020 DC Tacoma Sport MT
    17x7 TRD Pro Wheels Cooper AT3 4s 255/75/17 tires Frontrunner slimline II bedrack Curt hitch shackle Treeline Tamarack RTT Front air dam delete 1/3 rear seat delete
    I wonder - are manual transmission Tacomas without a start button immune from this kind of theft?
    bigmw likes this.
  5. Feb 19, 2021 at 7:23 AM
    philth
    philth .
    No.
    Keys still need to be programmed to the ECU to start the ignition. Metal blanks will not start the truck.
    What they do is take a pic of the VIN - cut a key - open the door - plug into the OBD, program the key - drive away.
    You can [basically] program any blank FOB to the ECU.
    As an example.. I’m using a honda style flip key for mine, just put a Toyota sticker on the blank.
    ontarioyota, Shveet and llamasmurf like this.
  6. Feb 19, 2021 at 7:38 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    so do what homer did with the check engine light?
    put a piece of black electrical tape over the one in the widow?
    philth[QUOTED] and ontarioyota like this.
  7. Feb 19, 2021 at 7:43 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    TuRD gen problems
    :duh:
    I have to violate my poor old truck with a key to start it.
    You dont know how many times I have pushed the 4x4 selector to try and start it.:anonymous: I am so used to push start now with the wife's CR-V
  8. Feb 19, 2021 at 7:45 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    philth likes this.
  9. Feb 19, 2021 at 7:49 AM
    philth
    philth .
    Yup! If they can’t see it, they can’t cut a key for it.
    Theft is a routine. Your best line of defence is adding time and hurdles to their routine. They might see no VIN and move on, cause your neighbours will be exposed.
    In the case where they get into the truck..
    OBD locker..
    Now, if they REALLY want the vehicle, they’ll get it one way or another (tow truck).
    Personally, if they got my truck, they can have it, let insurance handle the rest. I’ll do my best to protect against the theft though.
  10. Feb 19, 2021 at 8:03 AM
    ipartner
    ipartner Member
    2020 trd pro - super white
    I have the stock tires in the garage and currently running toyo at 2’s
    looking to put ko2s on. Stock suspension stays.
  11. Feb 19, 2021 at 8:10 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I believe the best way is a ignition kill switch. Can do a inline switch to the fuse panel for the ignition (atleast for 2nd gens).
    it’s just a deterrent like you said. If the thief's want it they’ll take it. If my truck was stolen I would be loosing out on a lot. Would suck.
  12. Feb 19, 2021 at 8:25 AM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    You beat me to it!
    philth[QUOTED] likes this.
  13. Feb 19, 2021 at 8:40 AM
    vonclicas
    Filipe
    Lx470
    33” mud tires
    @Norilsk , could you please check this battery and see if its compatible with trucks? my battery does not charge anymore, costco does not have marine in stock.
    PS: i am also choosing a group 31 too because sometimes they still fit on my truck with or without changes.
    https://www.canadiantire.ca/en/pdp/motomaster-nautilus-agm-group-size-31-battery-0103190p.html#srp
    or this one? this one is dual, the other is not dual. I have no idea what dual means...
    https://www.canadiantire.ca/en/pdp/...ize-27-dual-purpose-battery-0102799p.html#srp
  14. Feb 19, 2021 at 9:35 AM
    ipartner
    ipartner Member
    Not planning to lift it very much. Planning to put 285/75/16s on it for work around home. I expect there’s a ton of discussion to be had on whether those tires will rub.
    philth likes this.
  15. Feb 19, 2021 at 9:48 AM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Try and stay away from lift kits with spacers. I have 4 inch and front end is stiff. I feel a lot of bumps at high speed city driving. If I was doing it over, I wouldn't go that route. Do the lift through suspension is me 2 cents.
  16. Feb 19, 2021 at 10:07 AM
    llamasmurf
    Wes
    Northern Ontario
    This man knows what he is talking about! He has had the dirty dirty lift, and knows it is not the best way. :spy:
    :thumbsup:
    :dancingbacon::broccoli::jellydance::kona::bananadance::taco:
    I agree with Tony, only way to lift taco for greatness is with suspension. Then some other small things when you attempt 37's:welder: :sawzall:
    Tridet167[QUOTED] likes this.
  17. Feb 19, 2021 at 10:13 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    This is what I got, no complains.
    Snail81 and Shveet like this.
  18. Feb 19, 2021 at 10:23 AM
    vonclicas
    Filipe
    Lx470
    33” mud tires
    Yeah, problem is Costco is closed, they don't have stock, don't have their website access.. Etc..
  19. Feb 19, 2021 at 10:35 AM
    Norilsk
    Eugene
    Drive outside of the grey zone, problem solved :) sure Costco open outside of GTA
    vonclicas[QUOTED] likes this.
  20. Feb 19, 2021 at 10:43 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    no, stay the fuck out of Hamilton. Burlington Costco is closer so go there, no one gives a shit about Burlington - it's just old people
    :boink:
