Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 20, 2021 at 10:01 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
  2. Feb 21, 2021 at 3:56 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    All the wood got moved from the back of my yard to under my parents back deck yesturday.
    Those new 5160's put in a little work, took 2 full trips to get it all.
    I made a little log skidder :rolleyes:
    TacooSaucee, daks, Shveet and 3 others like this.
  3. Feb 21, 2021 at 4:16 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  4. Feb 21, 2021 at 4:47 AM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Thanks for the compliment @Saturnine :hattip:
    It’s mini and mighty and does everything I ask of it. Lots of OEM and aftermarket support to keep it going and simple to work on with minimal electronics.
    Shveet likes this.
  5. Feb 21, 2021 at 4:54 AM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    That log skidder works!
    Your trucks not squatting much with that load and that’s a good size load. It actually looks quite level!
  6. Feb 21, 2021 at 5:15 AM
    jordi992
    jordi992 Skidplates reduce clearance
    Jordan
    Burlington, ON
    Red truck
    Light bars, no lockers
    i went into the store. They offered me a pro rated amount back. not a replacement.
  7. Feb 21, 2021 at 5:22 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Yep figured they still did that, which is bullshit. Not that I have needed many batteries in my lifetime, but when I do, I go to Costco.
    Intrepid likes this.
  8. Feb 21, 2021 at 5:58 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That's the minimum to be fair.
    Did you verify they had a replacement battery of the same model in the store? The CT website shows stock level in each store.
  9. Feb 21, 2021 at 6:50 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    what's the current verdict on the best LCA cam bolts to replace stock and hold alignment? are people happy with the Bison cam stop kit?
    I like the poly performance taco tabs (i think @tacoma16 has?) but not currently available for 3rd gen.
    tacoma16[OP] likes this.
  10. Feb 21, 2021 at 7:01 AM
    Windigo
    Farook
    '14 Acess Cab
    Keep what you have stock. Just replace the bolts with greeasable ones.
    I installed the bison kit. Sloppy and don't recommend it. But I might of got a bad batch or something. I only replaced them because my one of my stock ones moved.
    ontarioyota likes this.
  11. Feb 21, 2021 at 7:09 AM
    honkonbobo
    Eric
    SW Ontario
    my 2nd gen didnt hold alignment well with the stock bolts.
    i should add that i have a TC cam tab gusset kit. could use it or go for the marlin one.
    Windigo likes this.
  12. Feb 21, 2021 at 7:28 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    My OEM cam bolts also have about 1/16" slop at the "happy" max-caster positions. The problem is when you hit a rock off-road, the OEM round cam rotates, and that throws out alignment a lot more than 1/16".
    If you use the Bison kit, why don't you put a weld bead on the inside of the cam tabs to take up the slop?
  13. Feb 21, 2021 at 7:29 AM
    Windigo
    Farook
    '14 Acess Cab
    If it happens again I will tack weld then cams.
    But so far all is good.
    Snail81 likes this.
  14. Feb 21, 2021 at 7:31 AM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    What a cute picture of that sleeping deer!
  15. Feb 21, 2021 at 7:42 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    He's even waving at you in his sleep!
  16. Feb 21, 2021 at 7:54 AM
    Windigo
    Farook
    '14 Acess Cab
    Dose anyone have one of these at home. I have the female air couplers that came from this machine and need to find out which male couplers will fit. the gold colored pieces
  17. Feb 21, 2021 at 7:58 AM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Oh my gosh I have the exact same Unit and absolutely love it… I will go out to the shop and see if I can figure it out for you
  18. Feb 21, 2021 at 7:59 AM
    Windigo
    Farook
    '14 Acess Cab
    much appricated I dont have the machine just the air couplers.
    thank you.
  19. Feb 21, 2021 at 8:08 AM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    I hope this helps
    Shveet likes this.
  20. Feb 21, 2021 at 8:13 AM
    Windigo
    Farook
    '14 Acess Cab
    that dose help a lot. thank you.
    now i can match up that with what's on the net.
    I have a compressor at home and the fitting will not go into it
    thanks again.
    ontarioyota[QUOTED] likes this.
