Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 22, 2021 at 6:19 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    Where'd you order the metal housing from? I've been eyeing it on Amazon for whenever my first oil change comes around, it's been hovering around the 35-40$ mark which seems like a cheap piece of mind.
  2. Feb 22, 2021 at 6:32 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Toyota sells it as an OEM part and the Amazoon one you probably see is their front.
    just eat the cost? It was around $40 or something. unless you're not working, that's anywhere between an hour or 3 of work.
    :notsure:
  3. Feb 22, 2021 at 6:39 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Okay, just wanted to see if the costs we're similar between dealer-online. The Subaru tweeters were 100-150$ more to buy online so you never know.
    Fortunately I am still employed, so :spending:
  4. Feb 22, 2021 at 6:39 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Toyota went from the aluminum filter cap to plastic because aluminum-on-aluminum results in galling. Be sure to thoroughly lather the threads with oil if you go that route.
    gabbo2112, over60, daks and 2 others like this.
  5. Feb 22, 2021 at 6:40 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    how thef are they $100-$150 more online?
    literally just walk into any Subi dealer and pick them up for apparently $150 now (i paid $100 when i got the truck)
  6. Feb 22, 2021 at 6:42 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    well there is enough used oil in the oil pan. since i lube up the o-rings with that anyways, i'll just cover the threads as well
    gabbo2112 likes this.
  7. Feb 22, 2021 at 6:44 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Yeah I got them for 150 at the subi dealer, but they were 300 on Amazon at the time. There was other alternatives on ebay but I wasnt into the USD converting and shipping/border stuff.
    Shveet[QUOTED] likes this.
  8. Feb 22, 2021 at 6:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Yep. The filter cap is probably installed dry at the factory (they fill the oil after the whole engine is assembled). I think the galling was only a problem at the first oil change, which is at a lengthy 16,000 km after purchase.
    And whoever at Toyota that signed off on the cartridge filters made the decision over 12 years ago. The dual-VVTi 4.0L in the 2010 4Runner/FJ already had it.
  9. Feb 22, 2021 at 6:57 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    imagine not changing the oil before 8,000 km.
    :rofl:
    let the system wear itself in for shorter than what the oil is intended for and then change it. anything past that your only helping the engine, New oil will never hurt an engine.
    Unless you have a 700k engine that you've changed the oil 5 times on it but still runs mint, at which point the internals are worn in to accommodate the theoretically thicker oil and new oil would be too thin and can cause damage.
  10. Feb 22, 2021 at 7:56 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    It's OK. Living in the GTA with road salt, the engine even with negligent maintenance will outlast the frame.
    The parking lot at my work is next to a road salt storage dome. I park in this for 3 months in a normal year:
  11. Feb 22, 2021 at 8:40 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    I'm assuming using 17 year old lube techs has finally caught up with them.
  12. Feb 22, 2021 at 9:16 AM
    Tacotim0321
    Tacotim0321 Well-Known Member
    Tim
    Southwestern ontario
    Red 06 access cab trd off road
    Roof top tent 33s on American racing wheels 3 inch lift
    You guys are talking about oil filter cartridges... am I missing something? My oil filter is on top on the left. Did they change them on the 3rd gens?
    gabbo2112, llamasmurf and Shveet like this.
  13. Feb 22, 2021 at 9:32 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Ah, I see you finally tasted the luxury of owning high end vehicle /s
  14. Feb 22, 2021 at 9:37 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    the future is now Old man
    :pccoffee:
    (jokes aside, yeah the 3rd gen now has the filter/cartridge at the bottom of the engine in the new design, the location is not the issue, it's the idiotic 2 piece design of the container that i've had plenty of issues with the plastic cracking on me)
    Oh boy i can't wait to spend $42,000 on new tires!
    or getting engine work done for $53,000!
    :cookiemonster:
  15. Feb 22, 2021 at 9:54 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    That's going to be a feature in 4th gen, when Toyota switches to electric power steering :devil:
  16. Feb 22, 2021 at 10:03 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Toyota changed to canister-type oil filter starting with the 4.0L 1GR-FE in 2010 in the 4Runner/FJ:
    The Tacoma got it in 2016 with the 3.5L.
  17. Feb 22, 2021 at 10:34 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    it violently shakes your steering in an a attempt to claim it as "simulated rumble strips" when crossing over the yellow line on the road and continues the deafening beeping, for the next version of TSS and the next step in automotive safety.
    Snail81 likes this.
  18. Feb 22, 2021 at 11:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    They'll probably go to full lane-keep assist and steer the truck for you.
    Some engineer at Toyota is probably thinking: the rack can't leak if it doesn't use fluid :cookiemonster:
    Shveet[QUOTED] and Snail81 like this.
  19. Feb 22, 2021 at 11:47 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Someone in here will be happy for it...
  20. Feb 22, 2021 at 12:01 PM
    Tacotim0321
    Tim
    Think I'll stick to my truck then lol. What year did they switch? 2016?
