Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 20, 2021 at 7:36 AM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    words of a Prophet.
    19Canuck[QUOTED] likes this.
  2. Mar 20, 2021 at 7:50 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Get it sprayed now and what it will slow or stop what is already rusting, never too late!
    Well in some cases it is.
    Not here.
    Sloweburn, Shveet and jordi992 like this.
  3. Mar 20, 2021 at 8:06 AM
    jordi992
    jordi992 Skidplates reduce clearance
    Jordan
    Burlington, ON
    Red truck
    Light bars, no lockers
    I know it looks really bad. The truck is actually coated.
    Last summer I did some rust restoration on the front 1/2 of the truck this summer I will do the back.
  4. Mar 20, 2021 at 9:51 AM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    I read your new build thread this morning and I enjoyed it! Thanks for your efforts.
    jordi992[QUOTED] likes this.
  5. Mar 20, 2021 at 9:56 AM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    My buddy sent me this picture from where he lives on Southern Lake Winnipeg from yesterday.
    I thought they only do this sort of stuff on Lake Simcoe when they are ice fishing....Lol
    It looks like a Tacoma, Also looks like they squared up the ice for a recovery and I know in Ontario insurance won’t cover that not sure about Manitoba.
  6. Mar 20, 2021 at 10:16 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Kinda looks like he’s breakin’ trail for returnin’ Mallards & Canada’s right there.
  7. Mar 20, 2021 at 10:24 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Back in the day... I had been sent to work in a "northern" ontario community.
    Friday night sitting in the local bar havin a "few" beers, and someone comes into the bar and yells out,
    "Hey how do you know if the ice is safe to go out on"
    Yelled reply from somewhere in the crowd,
    "When the tourists stop falling through"
    Now being new to the area I thought it was a smartass answer.... and a good chuckle...
    lol nope , it was all part of the normal routine... wait for the tourists to test the ice.
  8. Mar 20, 2021 at 12:28 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    We all know she'll still run!!
  9. Mar 20, 2021 at 6:40 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Today I learned the stock plastic bumper with hitch weighs 74 lb :facepalm:
  10. Mar 20, 2021 at 7:12 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    55 lbs of that is probably the hitch...
    So whatcha' puttin' on there?
  11. Mar 20, 2021 at 7:19 PM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    Swapping out the winter tires today I noticed a lot of play in the drivers side tie rod end. It looks like an easy enough job to change. Should I stick with an OEM part or is there a better replacement? And will I need an alignment afterwards?
  12. Mar 20, 2021 at 7:32 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    if you can repeat exact amount of turns you may be close, but not perfect, alignment always recommended after any steering/suspension work. Tie rod end bj should have some play if you wiggle with hand. 555 brand is what you need, it's Toyota OEM supplier.
    Sloweburn and ODSC1[QUOTED] like this.
  13. Mar 20, 2021 at 7:51 PM
    ODSC1
    London ON
    2017 DCSB Sport MT
    I'll double check the other side tomorrow for comparison but it feels like there is too much play in the ball joint.
  14. Mar 20, 2021 at 8:04 PM
    Norilsk
    Eugene
    Lift up that corner, enough to get the tire off the ground. Then grab the wheel at the 3 and 9 positions and shake it (but don't push it). If you feel any sort of popping or knocking kind of sensation, then shop for a tie rod end. :)
  15. Mar 20, 2021 at 8:27 PM
    ODSC1
    London ON
    2017 DCSB Sport MT
    I'll check that tomorrow!
    Norilsk[QUOTED] and Shveet like this.
  16. Mar 20, 2021 at 10:13 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    FYI OEM is only $50 at the dealer parts counter.
    Do you have an impact wrench? The joint stud likes to spin when you loosen or tighten the castle nut with hand tools.
    ODSC1[QUOTED] and Sloweburn like this.
  17. Mar 21, 2021 at 6:47 AM
    Intrepid
    Intrepid Well-Known Member
    Jeff
    Toronto, Ontario CANADA
    2018 Tacoma TRD Sport double cab short box manual transmission cement grey
    ARE canopy with sliding screened windoors and rhino roof track, Warn semi-hidden winch mount with VR 10 winch, nightrider 28" single row LED lightbar, Hood scoop light bar, Anytime front and rear cameras. anytime Navigation switch, plug-in oil pan heater, plug-in block heater, plug-in battery blanket. WINTER: Snow Sport plow with back-drag modification, Bridgestone Blizzak DM V2 on steelies 265-70-17.
  18. Mar 21, 2021 at 6:51 AM
    ODSC1
    London ON
    2017 DCSB Sport MT
    Good tip! Yes, I do have an impact. Thanks!
    ontarioyota likes this.
  19. Mar 21, 2021 at 7:08 AM
    Norilsk
    Eugene
    Grab a torch as well for the tie rod nut, it’ll be seized very well. :sawzall:
    daks, jordi992 and ODSC1[QUOTED] like this.
  20. Mar 21, 2021 at 9:35 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Washed the underside for the first time since the rally :bananadead:
