Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 30, 2021 at 3:47 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    what's that?
    an offshoot of BDSM?
  2. Mar 30, 2021 at 3:51 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    I left the sensors in the original bumper and put it in the aftermarket box that the new bumper came in.
    Used techstream to have the body control module do a relearn so it "forgot" about the BSM modules ever being there.
    Sloweburn, Shveet and 3JOH22A like this.
  3. Mar 30, 2021 at 4:02 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    It’s the thing that Beeps when you back up.
    ontarioyota likes this.
  4. Mar 30, 2021 at 4:10 PM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    I only feel a hit and it stops. no beeping....
  5. Mar 30, 2021 at 4:12 PM
    FastEddy59
    Eddie
    Works like a charm then. :)
    Shveet and Snail81[QUOTED] like this.
  6. Mar 30, 2021 at 4:19 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Which one do you idiots think looks better?IMG_20210330_191128.jpg IMG_20210330_191137.jpg IMG_20210330_191401~2.jpg
  7. Mar 30, 2021 at 4:20 PM
    Snail81
    Igor
    Right here, Ontario
    The clean one
    :thumbsup:
    FastEddy59 and llamasmurf like this.
  8. Mar 30, 2021 at 4:34 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    +1 for the clean one
  9. Mar 30, 2021 at 4:38 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Pic 3.
    Black rim red TRD
    zuknewbie and ontarioyota like this.
  10. Mar 30, 2021 at 4:39 PM
    Tacotim0321
    Tacotim0321 Well-Known Member
    Tim
    Southwestern ontario
    Red 06 access cab trd off road
    Roof top tent 33s on American racing wheels 3 inch lift
    I agree
  11. Mar 30, 2021 at 4:56 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    TRD ones, I had exact the same on my rims before :thumbsup:
  12. Mar 30, 2021 at 4:57 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    This! X2
    ontarioyota and Shveet like this.
  13. Mar 30, 2021 at 5:42 PM
    ToronoTaco
    ToronoTaco Well-Known Member
    Gabriel
    THE BUSH
    4WD prerunner on 33s and a BJ42 Land Cruiser in pieces
    2inch lift bilstien 5125s, JBA ucas, icon add a leaf, lockrite locker in the rear, diffdrop, swapped a 5vz and a r150f, frame swapped it after a bit, tundra brakes
    What's popping fiends, any one know of a decent set of shackles to lift the rear of an 02? Also my god I missed some shit.
  14. Mar 30, 2021 at 5:52 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I think OME and daystar makes some. If I remember correctly, I think you can run xj ones too. Think 1.5” to 2”. Out of my wheelhouse though. So take that for what it’s worth which isn’t a whole lot.
  15. Mar 30, 2021 at 5:53 PM
    ToronoTaco
    Gabriel
    THE BUSH
    Sounds good, a friend gave me some rear Billy steinny 5100s, instructions say they need at least a lift block.
    tacoma16[QUOTED][OP] likes this.
  16. Mar 30, 2021 at 5:56 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    if they are much longer then stock then most likely. Could also cheat and just run larger bunps and loose some uptravel. Not ideal. Think when I checked Amazon, they could be had for $200.
    could also make some but by the time you get bushings and what not it may not be worth it.
  17. Mar 30, 2021 at 6:14 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    @Saturnine This is a match made in TRD heaven
    your ACab rocks
    :101010:
    Toms2Yotas, tacoma16[OP] and Snail81 like this.
  18. Mar 30, 2021 at 6:28 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Not sure if this helps but I will chime in. I did a full OME suspension 10 years ago with 881 coils. These are the grease-able shackles that came with my kit.
    Second picture is a back up set of bushings I purchased at the same time and I will likely have to change them out at some point… Probably when I put my AAL’s back if my Dakar’s ever sag. Seems like my mini truck is pretty easy on suspension and I only really seriously wheel When I’m fetching up firewood or trying to get close to a deer I just killed.
  19. Mar 30, 2021 at 6:30 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Black trd
  20. Mar 30, 2021 at 8:20 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Those are parking sensors. Most aftermarket bumpers cater for these, just little circular holes on the bumper face for the sensors to snap into.
    KBOX was asking about blindspot monitoring, which are the sonars installed in the OEM bumper corners. The sonars can only work through non-metallic surfaces. Most aftermarket bumpers don't cater for these.
