Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. May 4, 2021 at 6:18 PM
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
    To clear your cab mounts it’s your castor you want pushed forward to at least +3
    Mine was set to ,
    0- toe
    0 -camber
    +3 castor
    cwisema[QUOTED] likes this.
  2. May 4, 2021 at 6:21 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
  3. May 4, 2021 at 6:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You may not be able to clear the cab mount with those -10 offset wheels even after playing with alignment - it means the tire swings on a 0.4" wider arc when steering.
  4. May 4, 2021 at 6:42 PM
    cwisema
    cwisema Well-Known Member
    Acton, Ont.
    2017 MGM DCSB TRD Sport
  5. May 4, 2021 at 6:47 PM
    cwisema
    Acton, Ont.
    Thanks, I mixed up camber and castor. My Toyota dealership couldn't get it to 0 for toe or camber and didn't even try castor. The sheet I got shows 2.3 on Driver side and 1.7 on the passenger side (both before and after).
  6. May 4, 2021 at 6:51 PM
    cwisema
    Acton, Ont.
    I have hope that I can clear the cab mount because one side clears it now. If it turns out I cannot, then I'll have to do some grinding on my mount. I don't rub enough to require the chop.
  7. May 4, 2021 at 7:34 PM
    cwisema
    Acton, Ont.
    It's odd that the side I rub the cab mount is the driver side, and that's the side that I have a castor of 2.3. The Left side on the alignment sheet is the driver side right? I would expect that the side with a castor of 1.7 would rub before the side with 2.3.
    tacoma16[OP] likes this.
  8. May 5, 2021 at 3:53 AM
    Tacotim0321
    Tacotim0321 Well-Known Member
    Tim
    Southwestern ontario
    Red 06 access cab trd off road
    Roof top tent 33s on American racing wheels 3 inch lift
    Has anyone switched the seats in their truck to power seats? Seems I cant drive 15 minutes without leg/hip pain. I've seen threads where its talked about. Just wondering if anyone knows what seats might be close to comparable? I'm not opposed to fabbing brackets to mount them.....
    Sloweburn and Windigo like this.
  9. May 5, 2021 at 4:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    2020+ Tacoma power seat will probably bolt right in.
    Another option is to try the riser brackets sold by a few vendors here on TW.
  10. May 5, 2021 at 4:23 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Is the passenger side clearing at ride height or fully stuffed?
  11. May 5, 2021 at 5:25 AM
    Tacotim0321
    Tim
    I've seen those risers. Have you heard any reviews? I'm considering them. I wondered if 4runner or highlander seats might be similar?
  12. May 5, 2021 at 5:25 AM
    Canadian Joe
    Joe
    Ontario
    Many Toyota dealers and alignment shops will not do an out of spec alignment, they don’t want to touch them. You need to find a shop that knows what they’re doing for lifted 4 x 4‘s ,I am not sure if you have adjustable UCA’s or not, which helps greatly on Camber ,
    All my parts ,mounted tires on rims , sat in my garage for a few months until I found somebody that I was confident would get it right the first time ,
    cwisema[QUOTED], Shveet and 3JOH22A like this.
  13. May 5, 2021 at 5:27 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    To see how it feels, you could always just take out the bolts, put some wood or scrap material underneath the mounts and see how it feels in the driveway (do not drive around like this)
  14. May 5, 2021 at 5:29 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    I paid for 2 alignments when I first put my tires on. Both made the truck pull. then I just did it my self. Its not perfect but i dont get tire wearing on edges or anything and the more I do it the better I'll get at it. Try its not that hard...
    I used this video and read about it on internet
    https://www.youtube.com/watch?v=V23H_TTFW6o
    Sloweburn, Snail81, cwisema and 2 others like this.
  15. May 5, 2021 at 5:37 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Bolt in but likely won't have the power hook up needed.
    Tacotim0321[QUOTED] likes this.
  16. May 5, 2021 at 5:41 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Indeed, will need to run 12V power to it with 30A fuse. Also the airbag and weight-classification sensor connectors will likely be different between 2006 and 2020.
  17. May 5, 2021 at 5:50 AM
    Windigo
    Farook
    '14 Acess Cab
    car-part.com you can look up a set of seats and try. when I have some time I'm going to change mine
    Sloweburn and Tacotim0321 like this.
  18. May 5, 2021 at 5:55 AM
    Windigo
    Farook
    '14 Acess Cab
    there is a thread for alignments and I'm planning to try this too
    https://www.tacomaworld.com/threads/how-to-do-an-alignment-at-home.252256/
  19. May 5, 2021 at 6:04 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I have them. Big change. You're welcome to try them out on a third gen if you'd like.
  20. May 5, 2021 at 7:15 AM
    Tacotim0321
    Tim
    Would you recommend them? They dont look that difficult to replicate. I'm sure I can make a pair and get some grade 8 bolts
