Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. May 23, 2021 at 8:01 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Unusual to have the light on with no codes. Is your scan tool capable of talking with the airbag ECU?
    llamasmurf[QUOTED] likes this.
  2. May 23, 2021 at 8:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    This was before corona caused all the office staff to work from home. Full disclosure - I never joined the coffee club. Instead I wasted my money at the three Tim Hortons onsite...
    llamasmurf and Tridet167 like this.
  3. May 23, 2021 at 9:15 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    @Snail81 and I were across the road (507) from you! Did the Gooderham Trail northbound. First 2/3 of the trail was easy. Last 1/3 was similar difficulty as Ardbeg North Trail. Of course the 35" Kenda commie tires rolled through it all with ease.
    ltHwPU0Z5k7zWiAtEJrD921grF-Mqro-6GoCN7xu_99dbd935fc31ab33b6296c331be5cbf21ade49bb.jpg 8f1KwJAGILJOYny1rJQ9jnpusMfNiq9AmM9tVyns_336323772c0863692718ab0da44f58b900992c21.jpg
    The twin-piston AliExpress compressor now takes about 60 sec to inflate a 35" tire from 15 to 30 psi. Previously it was 40 sec for 32" Duratracs.
    Atlas86, llamasmurf, ODSC1 and 9 others like this.
  4. May 23, 2021 at 9:38 PM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    25 Tacoma TRD Off Road
    Bone stock for now
    Precisely!
    tacoma16[OP] likes this.
  5. May 24, 2021 at 2:02 AM
    Tacotim0321
    Tacotim0321 Well-Known Member
    Tim
    Southwestern ontario
    Red 06 access cab trd off road
    Roof top tent 33s on American racing wheels 3 inch lift
    I wonder if you have to disconnect the battery for a few minutes to reset or is it a dealer that has to reset it? Just from my limited research on tw.
  6. May 24, 2021 at 2:10 AM
    Tacotim0321
    Tim
    I dont think that it is. It's just a cheap Amazon reader. I'll stop at t
    My buddy owns the local garage in town. Hes got the fancy snap on scanner. I'll get him to scan it today. Before I go ripping into it to check for continuity
  7. May 24, 2021 at 2:29 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    This has got nothin’ to do with that stability control RRSC or somethin like that, does it?
  8. May 24, 2021 at 4:55 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Didn't you disconnect the battery when replacing the clockspring?
    Tacotim0321[QUOTED] likes this.
  9. May 24, 2021 at 5:46 AM
    Tacotim0321
    Tim
    I haven't got into mine yet.... but I know I would disconnect the battery to change it
  10. May 24, 2021 at 5:50 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I am going to see what Tech stream says today, about the airbag.
    Was to busy the other day to check it when we refilled the transmission level. That is a hell of a job, the 1st time learning how to do it.
  11. May 24, 2021 at 7:09 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    You don't have to worry about temp check mode. Just give 'er some throttle (say 2000 rpm) and monitor the fluid temp PID. Once it's in range, open the check plug. Most dodgy part is getting under the truck while it's running, and avoiding touching the cats with your arm.
    Did the job in 2015 with a noname OBD2 dongle and Torque Pro on a tablet.
    llamasmurf[QUOTED] and Snail81 like this.
  12. May 24, 2021 at 9:44 AM
    llamasmurf
    Wes
    Northern Ontario
    Yea we did with the temp check mode.
    We also used my phone to see how close we were getting, with the FLIR on the bottom of the transmission pan.
    It helped us be confident we didnt over heat it and the mode was working. We just wanted to ensure we did it correctly.. So following a guide helps do that :rolleyes:
    Now that I have done it, I understand the entire process and it will be no problem next time. :thumbsup:
  13. May 24, 2021 at 3:23 PM
    llamasmurf
    Wes
    Northern Ontario
    Anyone would be in need of a few items maybe? :rolleyes:
    ADD
    ADD diff tube
    ADD diff tube shaft
    4WD ECU
    I pushed the delete key on all these. They still all work perfect!
    Going up in buy / sell / kijiji soon. Figured id toss it in here 1st.
    tacoma16[OP] and Shveet like this.
  14. May 24, 2021 at 4:06 PM
    Sloweburn
    Woodstock, ON
    Bone stock for now
    So how awesome is this. My woman did this - didn’t need my help at all! She wanted to power wash the salt stains off the carpet.
    Action shot of the rebuild:
  15. May 24, 2021 at 4:08 PM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Do you have an extra one?
  16. May 24, 2021 at 4:48 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    :bowdown:
    Sloweburn[QUOTED] likes this.
  17. May 24, 2021 at 4:50 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I’ll take 2. :anonymous:
  18. May 24, 2021 at 5:04 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Will I notice 5100s in the rear only on a basically stock truck with no weight and will it allow for a lift in the future with aal?
    TeecoTaco likes this.
  19. May 24, 2021 at 5:08 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    I've done exactly that...5100s rear replacing Sport Hitachis, and very noticeable in a positive way. I think you'll notice the apart from your 4100s. We have the same wheelbase.
    Can't help ya with the lift question tho
  20. May 24, 2021 at 5:37 PM
    llamasmurf
    Wes
    Northern Ontario
    @3JOH22A @Tacotim0321
    This is what Techsteam has to say about my air bag dash light.
    Looks like I need a new driver side seat position sensor.
    Tacotim0321 likes this.
