Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. May 31, 2021 at 9:47 AM
    blqchclt
    blqchclt Oh, that's what this is for
    2018 Quicksand DCSB
    Just did this -
    Wire brush, some gloves and steel wool to get ride of the surface rust
    Simple green to clean/degrease the area
    applied some good black flat rustoleum (or paint as others have mentioned)
    then sprayed the whole frame with multiple coats of CRC Corrosion inhibitor.
    Looks brand new, my paranoia is gone.....or just covered in paint, not sure.
    :itllbuffout:
  2. May 31, 2021 at 9:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Found out today the Toyota-branded Dexron III has been superseded by Mobil ATF D/M. Bought two 1L bottles today at the parts counter. Dealer SKU is C0PBS-ATFD3-1L. Still cheaper at the dealer ($7.65) than at Canadian Tire ($13). One bottle for power steering flush in the Subaru, and another bottle as a trail spare in the truck.
  3. May 31, 2021 at 10:05 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    @TacooSaucee Thanks for the list, Probably Mobil Delvac or Syn gear
    :bananadance:
    https://www.tacomaworld.com/threads/gear-differential-oil-spec-comparison-nerdy-data-stuff.717149/
    TacooSaucee and Canadian Joe like this.
  4. May 31, 2021 at 10:11 AM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    I did a touch up on my frame last fall where needed. Wire wheel and brush. Degreased and washed. Brushed on Metal Prep, brushed on POR-15, sprayed black Rust Check, then sprayed Fluid Film on the whole thing.
    I would add safety goggles and a dust mask to the PPE.
  5. May 31, 2021 at 10:40 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Snail81 and llamasmurf like this.
  6. May 31, 2021 at 10:43 AM
    blqchclt
    2018 Quicksand DCSB
    Oh yeah, def PPE. Spraying that CRC smells like death and suffocated your pretty quickly when you're under your vehicle haha.
    Good thing we all have an endless supply of masks
  7. May 31, 2021 at 11:48 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    :popcorn:
    When I did the rear diff 3 years ago it looks like I used 75W90
    So I will upgrade and do 75W140 tonight.
    :thumbsup:
    3JOH22A[QUOTED] likes this.
  8. May 31, 2021 at 3:42 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Wire brush/ brillo pad/wire wheel to get off any loose scale.
    Spray with brake cleaner.
    Tremclad or Rustoleum semi-gloss black with a paintbrush (spray can for areas not easily reached)
    Let dry a week.
    Spray with ATF or red-rust check, or the best ACF-50 (lubricates and neutralizes rust in nooks an cranny's)
    Wait 2-3 days
    Spray with Corrosion Free, or the best ones Corrosion-X HD or Cosmoiline RP-342 (you can get it in black)
    If you use Corrosion-x HD or RP 342, wear a face shield and hat. Soap and water will NOT take that stuff off, only naptha/varsol/mineral spirits will take it off.
    I've got all the spray guns and compressor if you need them.
    After you've cleaned off the rust you can also put Navel Gel (phosphoric acid) on the rusted areas, and it will totally neutralize the rust and turn it black, then wash off with soap and water, but I've found that the tremclad/rustoleum seems to hold up real well all on it's own. But you don't want that stuff dripping on you when you are working underneath something.
    Thyces, somebody, weight and 2 others like this.
  9. May 31, 2021 at 3:56 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Thanks for the insight everyone,
    thankfully i have a a bottle of Varsol and Gasoline for clean ups. my hands are permanently damaged by the stuff from years of use so it's just another day :cookiemonster:. installed glue-down Engineered hardwood, vinyl, and carpet with some nasty adhesives for a living so i'm familiar with the cleaning methods to remove shit from at least my hands, good times...
    Thyces likes this.
  10. May 31, 2021 at 4:26 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Lol Cosmoline is not something that will really clean off your skin/hair.
    It will soak in ,and then when you use the thinner to try and clean it off it will soak in more.
    So for a week or two afterwards you will have a greasy/waxy feel.
    It'll only come out of your hair when you cut it out.
    You can coat something with it and hit it with a concentrated soap power washer and it does not come off.
    Oh a tip if you want to keep your underside easier to clean the mud off, of after being off-road...
    Spray either Silicone spray or Mold Release spray all over your underside.
    Sloweburn, weight and Shveet[QUOTED] like this.
  11. May 31, 2021 at 6:53 PM
    llamasmurf
    Wes
    Northern Ontario
    :cookiemonster:
    Got a bunch done tonight.
    Rear diff drained and refilled with Lucas 75W140 :thumbsup:
    T-case breather, switched over to the barb and attached to the stock breather tube, thanks @TjAeCeOpMAmiah
    We decided on the location and mounted the toggle switches, could only get blurry pics of them for now :rofl: They will get hooked up and working soon enough.
    :bananadance:
    Tomorrow hopefully I will get all the skids back from powder coat, put em back on before Friday. Then actually get out and use the truck this weekend!
    1st time for wheeling with the new t-case, can not wait. :burnrubber:
  12. May 31, 2021 at 7:23 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Can the glovebox still come out for cabin filter replacement? :p
    Shveet and llamasmurf[QUOTED] like this.
  13. May 31, 2021 at 7:25 PM
    llamasmurf
    Wes
    Northern Ontario
    Yes if you look how we mounted them, it is to the plastic part above that was hiding the 4WD ECU.
    The glove box is still removable just like normal, for filter replacement.
  14. Jun 1, 2021 at 5:47 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Just remembered how much I hate grinding and cutting stuff while laying down…..
    Thyces, daks, ontarioyota and 7 others like this.
  15. Jun 1, 2021 at 6:01 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    What you're saying is you need a scissor lift in the driveway, so you can work on the frame while sitting in a chair, with no lift arms in the way?
  16. Jun 1, 2021 at 6:14 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Something. Either that or get in shape so I can endure the constant up and down, and sit-up holds while grinding. Hoist may be easier in the long run :p.
  17. Jun 1, 2021 at 7:19 AM
    RoamingGnome
    RoamingGnome Well-Known Member
    Gerry
    Ontario, Canada
    2017 Tacoma TRD OffRoad
    Mostly stock for now...
    WooHoo! Happy owner of 10 acres of Vacant Land / hardwood bush 20km from Calabogie - :bananadance:- Once it closes at the end of the month I can get me a container on site for storage and then start building me a home on top of the hill... Hmm... Quonset with window walls or SeaCan home? At the very least I have somewhere to go camping this summer ! :woot:
  18. Jun 1, 2021 at 7:22 AM
    Taruuk
    Taruuk Well-Known Member
    2017 Tacoma OR MT AC
  19. Jun 1, 2021 at 7:24 AM
    llamasmurf
    Wes
    Northern Ontario
  20. Jun 1, 2021 at 7:31 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I know where the next annual mall crawl overland expo may happen now :D
