Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 1, 2021 at 7:38 AM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Sea can home for sure!
  2. Jun 1, 2021 at 7:42 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    TacoEspecial likes this.
  3. Jun 1, 2021 at 7:46 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    May be easier to just use boots. Can be found for cheap and readily available.
  4. Jun 1, 2021 at 7:48 AM
    llamasmurf
    Wes
    Northern Ontario
    No, that will not be easier.
    I have them, and it will be a PITA. I dont want to use those. I dont really like the look of them. :argue:
    FastEddy59 likes this.
  5. Jun 1, 2021 at 7:54 AM
    llamasmurf
    Wes
    Northern Ontario
  6. Jun 1, 2021 at 8:02 AM
    Tridet167
    Tony
    Toronto, Canada
  7. Jun 1, 2021 at 8:12 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    You gotta get a NoS sticker for.the glove box
    Girl...... no you deh eint
  8. Jun 1, 2021 at 8:57 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    llamasmurf and Shveet[QUOTED] like this.
  9. Jun 1, 2021 at 9:15 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Fair enough. Does it have to be the broom stuff? Could you just use a rubber?
    llamasmurf[QUOTED] and Shveet like this.
  10. Jun 1, 2021 at 9:16 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  11. Jun 1, 2021 at 9:17 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Brush is one solution. The other popular one is two rubber sheet strips interleaved together, very common on aircraft (also replicated on PC flightsim hardware)
  12. Jun 1, 2021 at 10:18 AM
    Dye22
    Dye22 Well-Known Member
    Squamish
    '15 TRDOR ACLB
    JBA UCAs OME 2.5 in lift w/ heavy duty dakars. 33" ko2s tc bed stiffeners firestone airbags w/ ride rites cmc/pinchweld rear flushmount leds amazon ditch lights apex sliders 0 degree w/ kickout Coastal Offroad high clearance front bumper w/ full tubing Coastal Offroad high clearance rear bumper w/ tubing and dual swingout 100 AH LiFePO4 Aux battery blue sea fuse panel for aux battery rear diff mod breather Mountain Hatch tailgate insert Smittybilt x2O 10k winch Anytime Camera Mod Front and Rear GPS locator brick BAMF Hangers w/ custom crossbrace 2lo Mod by up2nogood yakima access cab roof bars thule hyper xl cargo box amazon roof basket ARB 1250 awning WaterPort Meso Dual Color Dome Light Durobump Front Bump stops
    strip brushes.
    https://www.bmw2002faq.com/forums/topic/260344-new-brushes-for-automatic-shift-cover/
    I've redone some of our farm vehicles with this method and it works well.
  13. Jun 1, 2021 at 10:30 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Switches for what?
    llamasmurf likes this.
  14. Jun 1, 2021 at 10:34 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Ejecto seato
    Thyces, Snail81 and llamasmurf like this.
  15. Jun 1, 2021 at 10:35 AM
    llamasmurf
    Wes
    Northern Ontario
    I deleted a few things, and the stuff it did was kinda important.
    :rolleyes:
    (1) is to disable the locker anytime mod. Engaging the locker on the highway, while attempting to toggle my fog lights is no bueno.
    (2) is to disable VSC in 4hi, cuz I had that stupid VSC crap
    These will make up for no longer having a 4WD ECU :cookiemonster:
  16. Jun 1, 2021 at 11:08 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’ll have to check the vsc stuff in 4hi. Don’t have any switches for my setup so we will see. May have missed something. Or maybe just a benefit of having an “sr5” lol
    llamasmurf[QUOTED] likes this.
  17. Jun 1, 2021 at 11:11 AM
    llamasmurf
    Wes
    Northern Ontario
    Yes that is correct.
    SR5 dont have all the options mine does, it is specifically for the off-road.
    VSC is for when you are spinning your tires and they are turned, it is trying to guess that you are not going the direction you want to be going. Tries to adjust using brakes, AND throttles the engine
    Best way to get stuck is allow the stupid truck to throttle the engine when you want to spin the tires. :bananadead:
  18. Jun 1, 2021 at 11:17 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Ah gotcha. I just have the traction control or what ever but I believe it kicks off under 20-40km/h in 4wd. Been a while since I have looked into this lol.
    I think that won’t be an issue down the road when the abs is deleted from the truck. Don’t think I’ll be able to integrate the Tacoma sensors in a gm axle. Haven’t looked into it yet though.
  19. Jun 1, 2021 at 11:19 AM
    llamasmurf
    Wes
    Northern Ontario
    Yea it is another level of traction control.
    When you pin it to spin the tires, you might not be moving at 40KM/h but your tires are. That is where the engine throttle BS comes in, and it tries to stop you from digging a hole.
    At least this is how I have convinced myself it works :notsure:
    Snail81 likes this.
  20. Jun 1, 2021 at 2:48 PM
    llamasmurf
    Wes
    Northern Ontario
    Pretty much been a kid in a candy store with the truck lately
    Wife asked, whats next? With a smile on her face.
    :bananadance:
