Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 9, 2021 at 8:50 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    @TacooSaucee we are all knowing, all seeing.
    i assume you decided against it since you realized they were nerf bars and not sliders?
    :anonymous:
    TacooSaucee likes this.
  2. Jun 9, 2021 at 8:58 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    Shhhhh.....
    I am actually still considering it, 1/6th the price is very tempting. I think they will help my flying-rocks dilemma and it's a relatively cheap option to try. I don't do heavy off-roading for it to matter much. As long as they are fairly tight to the cab and not old-man low.
    This picture from an Amazon review gives me hope
    tacoma16[OP] likes this.
  3. Jun 9, 2021 at 11:03 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Finally had a couple hours to myself... finally I think most of the parts I'll need are in...
    Got a little more done with the on-board air and horn system....
    mounted the manifold and finished and mounted the brackets to hold this beast of a horn...
    Now waiting for paint on some fittings to dry and to find my teflon tape... and I can start plumbing the hard lines...
    Then to figure out where to mount the air tank... and collect a couple more parts for the tire inflator hookup(s)
    gabbo2112, Sloweburn, ODSC1 and 8 others like this.
  4. Jun 9, 2021 at 11:43 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    I.cant.wait.to hear this !!!!
  5. Jun 9, 2021 at 11:45 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Where ever you mount the air tank be sure you have easy access to the fittings. Mine was mounted in my cap and the amount of corrosion from moisture build up in the tank was crazy. Changed fittings and what not because of it. Plus you want to be able to drain in consistently.
    I also always had the tank valve opened to drain it. Used a on/off valance to separate the tank from the lockers in case of issues. Could also cut off the air compressor if I needed to pressurize the tank to power the lockers (have a spare portable compressor on board for built in redundancies).
  6. Jun 9, 2021 at 11:48 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Marval Mystery Oil is your friend. Works well to stop freeze ups in Winter too. :)
    TeecoTaco likes this.
  7. Jun 9, 2021 at 1:25 PM
    RoamingGnome
    RoamingGnome Well-Known Member
    Gerry
    Ontario, Canada
    2017 Tacoma TRD OffRoad
    Mostly stock for now...
    Parts explosion in the shade tree garage today, enough stuff to keep me out of mischief for a couple of days... :spending:
    It would be nice if it was a little cooler and the grass in the back yard wasn't still wet :annoyed: - Filters for the Taco, SX4 and F350... and all the parts to replace steel brake lines and hoses on the 30yr old Ford...:fingerscrossed:
    Sloweburn, 19Canuck, Snail81 and 2 others like this.
  8. Jun 9, 2021 at 1:35 PM
    FastEddy59
    Eddie
    No knuckle bandages? Must have good work gloves then. :)
    RoamingGnome[QUOTED] likes this.
  9. Jun 9, 2021 at 1:42 PM
    RoamingGnome
    Gerry
    Ontario, Canada
    Yeah, Kinda used to spinning wrenches with gloves on at work... Construction equipment has a bit more space around things - I find I always expand my vocabulary when working on cars / trucks :notsure:
    ontarioyota and Snail81 like this.
  10. Jun 9, 2021 at 1:44 PM
    FastEddy59
    Eddie
    ….and fasteners aren’t made of butter.
  11. Jun 9, 2021 at 1:46 PM
    LandoFernano
    LandoFernano Well-Known Member
    Kyle
    Ontario, Burloak
    2020 TRD OR ACLB MT
    TRD skid-plate, Cali raised trail edition rock sliders, Diamondback HD cover, Cali raised bed stiffeners, 265/75/R16 BF KO2’s, extended rear diff breather mod, demon shackle mounts, factor 55 hitch receiver/recovery point,
    Got out last weekend and was able to run Ardbeg south all the way out to the power station and with some heavy use of my sliders and IFS skid I was able to complete the trail for the first time! Unfortunately after the trip my phone decided it was done with this world and crapped out so I lost a lot of photos:facepalm:
    The trail is really dry right now and only had one sketchy mud spot that required a bit of send. Even got to pull out my first Jeep! Definitely gonna want some more armour before I give it another go but man was it a blast!
    E8146C6E-90EF-4B68-9A65-CF8CC659F6B1.jpg D9D69CB6-EC9E-4885-8DFE-5DA5EEF7F91F.jpg DB1D3AB4-D21B-4F3D-AE85-01F97C71FD27.jpg
  12. Jun 9, 2021 at 2:44 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    Could always wrap that section of your exhaust with an exhaust wrap as extra insurance
    Shveet, ontarioyota and Snail81 like this.
  13. Jun 9, 2021 at 6:12 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    I'm looking for a 265/70/17 spare tire set up....I think a 265/75/16 will work as well. My stock spare is under the truck need a bigger one for my other set up. That'll learn me for not buying 5 tires! Especially at the price I got these M/T's for.
    @Saturnine be the smart man on that one!
  14. Jun 9, 2021 at 6:59 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Lol well I got enough of the hard lines done to test it out...
    Still have to wire in the solenoid to the SPOD controller....
    And trace down a minor air leak... mount the air tank ,regulator and fitting for the air chuck...
    Used a 9v battery to activate the solenoid... and gave it a quick Tap.
    Sweet Jesus my ears are ringing... just from 2 short quick blasts.
    Sounds like a Ship or VERY BIG truck.
  15. Jun 9, 2021 at 8:07 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    I got a Viar 1gal tank, it has 4 ports on it. Top/ bottom/front/back.
    Got that one specifically for all those ports in different directions to hopefully make it easier to find a mounting with one port facing down to drain. (fingers crossed)
    I was originally hoping to mount it where the manifold is now (I'll take pics tomorrow) and use the 4 ports from it instead of using a manifold.
    But I didn't find a "happy spot" for it either getting in the way of the horn, blocking too much of the rad, or would be a bitch to route lines to.
    May see if I can make another custom bracket to get it to sit nicely there we'll see.
    I may add a water separator after the first 40" of 3/8 copper hard tubing coming from the compressor.
    Still not 100% sure where I'm going to mount the tank yet, but I'm sure I'll need some more fittings and brackets to make...
    but I have a manual drain for it if it's easily accessible or another 12V solenoid if it's not.
    Man this would be so much quicker if I could just walk in to Princess Auto or a Supply house and just grab what I need when I need it.
    Cause you never know what you need 'till you don't have it.
    From testing today though I really don't need a 1 Gal tank if I just want a quick 2-3 second "come to Jesus" blast.
    The tank in theory will give the horn a 15-20 second "you better be wearing your brown pants" blast.
    Lol since I have another spare air solenoid I *could* set it up with the air horn connected with the regular horn so it would be a short blast when I hit the regular horn.
    But connect the tank from the another solenoid so when I hit the air horn button it activates the tank and air horn at a much higher and longer blast.
    Lol this is turning into more work than I thought it was gonna be. Still have to paint all the brass and copper fittings and lines black.
    Canadian Joe and ontarioyota like this.
  16. Jun 9, 2021 at 8:30 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
  17. Jun 9, 2021 at 9:20 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I actually had that license plate as my avatar for my first month, but people were getting confused thinking I was in Cali...
    camjamesj, FastEddy59, Shveet and 2 others like this.
  18. Jun 10, 2021 at 7:14 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Shveet likes this.
  19. Jun 10, 2021 at 8:07 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    It's the same engine as the LS500, actually 3.4L: https://en.wikipedia.org/wiki/Toyota_Dynamic_Force_engine#V35A-FTS
    (The 4.6L V8 in the LS460 in 2007-2017 was the same engine used in the Tundra and GX460, just without direct injection, so there's precedent there.)
    Meso installing LS500 injectors in his 3rd gen Taco as part of the OrangeVirus twin turbo kit: https://www.tacomaworld.com/threads...n-turbo-systems.566390/page-457#post-24100902
    Lumberjackcoma likes this.
  20. Jun 10, 2021 at 10:01 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    :rofl:
    It took me a moment as well...
