Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 13, 2021 at 2:36 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    But can you see Regina's vagina? Hmmmmm?
  2. Jun 13, 2021 at 2:38 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Gotta turn the pic upside down to see that.
    Snail81 and TeecoTaco[QUOTED] like this.
  3. Jun 13, 2021 at 3:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Knocked out the front brakes today. StopTech 126.47012SL / 126.47012SR slotted rotors and Advics AD1539 pads:
    xfBVfoCfIZby4edOMaf2jEUwX1xUjF07EQ_JEb6H_7ca791079d8322e1b937fd0dc15dd4c233f72008.jpg
    I also learned the Neutrogena sunblock hurts more in my eyes than brake cleaner :anonymous:
    Atlas86, gabbo2112, Snail81 and 9 others like this.
  4. Jun 13, 2021 at 4:28 PM
    TeecoTaco
    SW Ontario
    Shit's like cobra venom inserted into the eye surface via a Visine bottle dropper
    I has a decent Sun intolerance and that spray is best on market...you feel my pain, literally.
    I snicker in your general direction
  5. Jun 13, 2021 at 5:00 PM
    FastEddy59
    Eddie
    Anythin’ labeled OFF usually finds its way into the eyes. Deep Woods is my fav. :laser:
    TeecoTaco[QUOTED] likes this.
  6. Jun 13, 2021 at 5:06 PM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    I have a feeling you started second guessing your choices writing this list out :D
    The most obvious thing here is to ditch the rubber bed mat.
    My truck states 990lbs as my limit, and for a daily basis I have:
    Roof rack +60lbs
    Running boards +100lbs
    nonsense behind/under seats +20lbs
    My lanky self +165lbs
    llamasmurf and Tridet167 like this.
  7. Jun 13, 2021 at 5:31 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    :smack:
    the bed mat stays.
    i have a cooler that's the PERFECT size for it to fit under the tonneau cover to the point i dont need to strap it down
    :D
  8. Jun 13, 2021 at 6:08 PM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Strap it down?? Fill that cooler with some drinks and it would be heavy enough to act as a winch anchor
  9. Jun 13, 2021 at 7:55 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Got out for a rip today with @TjAeCeOpMAmiah
    He was leading and tried to go the way we have done many times with no problem.
    Today was a bit dry in the water holes, which made the mud real sticky.
    The bypass, has a bypass lol. I spent a good 2 minutes or more trying to not be stuck directly beside him :fingerscrossed:
    Fell off the line on a rocky climb, the gas tank skid putting in work on trip #1 :thumbsup:
  10. Jun 13, 2021 at 8:11 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    don't even need to do that, i got drinks in it yes but full or empty, mine is wedged into place and won't budge unless i pop the first panel up on the cover
    :cookiemonster:
  11. Jun 13, 2021 at 8:12 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Go on a diet. Get to the same weight as Manuel Ferrara in his prime, and you can add a rear plate bumper without affecting weight capacity. It also improves weight distribution and lowers center of gravity. :notsure:
    Shveet[QUOTED] likes this.
  12. Jun 13, 2021 at 8:20 PM
    FastEddy59
    Eddie
    I’m certainly changin’ the rear bumper. Could use a bit more weight especially in Winter but yeah, let’s not forget it’s not a full size Truck by any means.
    Shveet likes this.
  13. Jun 14, 2021 at 6:27 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    You forgot about the extra weight of bigger tires, the extra weight of mud in the frame, extra weight of more leaf springs, toggle switches more wiring for lights, more lights, dirt inside the cab, dirt in ur air filters, etc… should i keep going? :p
  14. Jun 14, 2021 at 7:10 AM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Just always assume you're over, which most often we are.
  15. Jun 14, 2021 at 8:11 AM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    The lighter wallet helps offset gvwr.
  16. Jun 14, 2021 at 8:18 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Is inflating the tires with helium an option?
    weight[QUOTED], Shveet and pete37 like this.
  17. Jun 14, 2021 at 8:32 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    with this logic, we can just build zeppelins that use our trucks as the control cab... we'd be lighter than a Miata...
  18. Jun 14, 2021 at 8:35 AM
    FastEddy59
    Eddie
    ….and here we thought Wildpeaks packed with Technology were the Shtick. :)
    RoamingGnome and Shveet[QUOTED] like this.
  19. Jun 14, 2021 at 11:35 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    gabbo2112, 3JOH22A, Windigo and 5 others like this.
  20. Jun 14, 2021 at 11:37 AM
    FastEddy59
    Eddie
    Did you get Hammer Hangers to match. :notsure:
    Shveet likes this.
