Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jul 16, 2021 at 3:02 PM
    blqchclt
    blqchclt Oh, that's what this is for
    2018 Quicksand DCSB
    Keep an eye on coastal...because if you can weld, all of these inevitable upgrades would be a bit cheaper for you! They don't do a Slider yet but I'd bug em for it to find out haha.
    https://www.coastaloffroad.com/product-category/toyota-tacoma/2016-2021-tacoma/
    Shveet likes this.
  2. Jul 16, 2021 at 3:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Shift knob indicates FJ or is it from a 4Runner Trail?
    llamasmurf likes this.
  3. Jul 16, 2021 at 3:45 PM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    You should post an after pic to go with the before pic.
  4. Jul 16, 2021 at 3:55 PM
    ODSC1
    London ON
    2017 DCSB Sport MT
    There is a guy in Quebec making bolt on sliders for $900 Cdn. And Overland Racks Ontario was supposed to start making them. Buying in Cdn $ and saving on shipping would be a substantial savings over ordering from the US.
    Also there are templates to convert weld on sliders to bolt on. https://www.tacomaworld.com/threads/diy-bolt-on-frame-plates-for-sliders.302192/ .
  5. Jul 16, 2021 at 3:59 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Here’s my before and after pictures with over 10 years in between:
    First picture is two weeks into ownership and the last two pictures are June 2021
    LandoFernano, Shveet, tgelata and 8 others like this.
  6. Jul 16, 2021 at 4:27 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    If 1st gen prices were reasonable I would 100% be driving one instead of my 3rd gen. However, when I'd be paying the same as what I did for my 3rd gen, I can't justify it.
  7. Jul 16, 2021 at 4:32 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Define reasonable...let's start with 2nd gen Tacoma prices for this and go up from there. We can negotiate!
  8. Jul 16, 2021 at 4:50 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
  9. Jul 16, 2021 at 4:52 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Shveet, Tridet167, Sloweburn and 3 others like this.
  10. Jul 16, 2021 at 5:03 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Perhaps I should post my before and after pictures with less than 25,000 kms in between :)
    But your cap has been surprisingly durable along with the rest of the truck.
    ODSC1 and ontarioyota[QUOTED] like this.
  11. Jul 16, 2021 at 5:21 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    You should we all love pictures! Your truck is an awesome build and you certainly have the knowledge!
    Lots of TLC over the years to keep it in good shape and the cap does have failing clearcoat on the roof And a sketchy hinge on the rear door but the side access of the cap is awesome. I’ve taken it off a few times but for the most part it stays on as it’s very functional for me.
    Without the cap it it seems so small because it is tiny but it’s mighty for its size.
    Shveet, Sloweburn, Snail81 and 2 others like this.
  12. Jul 16, 2021 at 6:04 PM
    cwisema
    cwisema Well-Known Member
    Acton, Ont.
    2017 MGM DCSB TRD Sport
    So I have my caster cam maxed out and I'm still rubbing my cab mount on the driver side. The alignment report says I have 4.6 driver and 4.5 passenger. I have my SPC UCA's in the D position. The shop couldn't move the camber cam. Would that have helped move the wheel farther forward?
  13. Jul 16, 2021 at 6:59 PM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    25 minutes into my drive to Collingwood and a partridge decided to run across the street and get his intestines wrapped around my control arm...
    Drone acquired as well, man, they are cool but hard to get used to!
    gabbo2112, Shveet, pete37 and 4 others like this.
  14. Jul 16, 2021 at 7:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Drone is good for recon ahead if you got a copilot, whether on the trail or in the city stuck in traffic :devil:
    4.5 is more than you need for good handling. (FSM spec is 1.2-2.8 deg caster)
    1. Reduce caster at the UCA to "F" to improve tire clearance.
    2. Rear cam all the way out.
    3. Front cam all the way in if not seized.
    4. Straighten toe (because that changes camber).
    5. Adjust camber with the UCA slot.
    6. Torque cam bolts.
    7. Lift vehicle by the frame and check ball joint clashing with coil spring at full droop.
  15. Jul 16, 2021 at 7:07 PM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Why they couldn't move front cam bolts? Are they seized?
    You could go to F to max forward the wheel but that'll require camber adjustment. I doubt you'll be able to do it with UCA joint
    (Follow the above instructions 3J0H22A provided)
    cwisema[QUOTED] likes this.
  16. Jul 16, 2021 at 7:45 PM
    TacoPandaTRD
    TacoPandaTRD Well-Known Member
    TacoPandaTRD
    Chilliwack, British Columbia, Canada
    2020 Toyota Tacoma TRD Off-Road
    Always looking to modify! Check out my Instagram @TacoPandaTRD
    I’ve been watching these on Facebook for a while now. Price just came down. Might be perfect for you 4125C5E2-0255-4357-B778-9B909CBF7A32.jpg
    Shveet and Tridet167 like this.
  17. Jul 16, 2021 at 8:04 PM
    ODSC1
    London ON
    2017 DCSB Sport MT
    These are ones I've been watching on FB,
    Shveet and TacoPandaTRD[QUOTED] like this.
  18. Jul 16, 2021 at 8:10 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Says won't fit a long bed. Never sure if that includes access cab or not because double-cabbers always forget about the access cab
  19. Jul 16, 2021 at 8:14 PM
    ODSC1
    London ON
    2017 DCSB Sport MT
    I think I saw another post from the guy, they will a DC shortbox or a AC longbox. Just not a DC longbox.
    Shveet and TacoPandaTRD like this.
  20. Jul 16, 2021 at 8:16 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    That's what I assumed but you see what I mean? Access cab is long box!
    One of them. One of them.
    TeecoTaco and ODSC1[QUOTED] like this.
