Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Sep 2, 2021 at 11:19 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
  2. Sep 2, 2021 at 11:36 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I don't remember placing a $2000 order with you last October? :p
    Snail81, Norilsk, Tridet167 and 2 others like this.
  3. Sep 2, 2021 at 11:39 AM
    honkonbobo
    Eric
    SW Ontario
    good one.
    llamasmurf and 3JOH22A[QUOTED] like this.
  4. Sep 2, 2021 at 11:41 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    We'll see what happens to RCV after my axle shafts get in. :pray:
  5. Sep 2, 2021 at 12:55 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    That's human nature. Things like armour requires a lot of R&D and that's time that if you don't charge for it, you lose. People see steel and think there's no way it should cost that much.
  6. Sep 2, 2021 at 1:09 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    That's the same with every business. Mobtown hasn't adapted to the supply chain fluctuations in the past couple of years as well as competitors like Victory 4x4 and C4 Fab.
    The other factor is the emergence of Chinesium armor from DV8, Hooke Road, 4WP Factory, etc. We used to complain Toyota parts cost a lot more than Jeep parts. This is how they reach parity.
  7. Sep 2, 2021 at 7:23 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Crush washer every oil change?
    llamasmurf[QUOTED] likes this.
  8. Sep 2, 2021 at 9:29 PM
    Tacocomamama
    Tacocomamama Success sometimes may be defined as a disaster
    Mississauga, Ontario
    2021 Tacoma TRD Off-Road
    Just got mine 2 weeks ago... always owned silver cars
  9. Sep 3, 2021 at 3:28 AM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    LandoFernano and somebody like this.
  10. Sep 3, 2021 at 4:14 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    FWIW I won't stress too much about crush washer reuse. I had probably 20 oil changes on a crush washer on my element, never a leak. Only got changed because the dealer happened to give one.
    The 3rd gens use a fiber washer (iirc comes with the filter). I would be more concerned about reuse of this as it may not be mechanically sound after it gets saturated.
  11. Sep 3, 2021 at 5:08 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Sorry I'm confused...are you talking about a gasket/washer for the oil filter cartridge?
  12. Sep 3, 2021 at 5:10 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
  13. Sep 3, 2021 at 5:14 AM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    I can’t comment on an element washer because I don’t have one however oil drain pan crush washer replacement is cheap insurance but I am certain they can be reused as long as they’re not damaged or gouged.
    edit>>I use this oil filter on my 2.7 L 4-banger because it fits but the actual stock one is a little bit shorter but I used to buy them by the case of 10 because this is also the stock filter for the 4.7 L V-8 when I had my Tundra and I was covered for both trucks!
    llamasmurf and 19Canuck like this.
  14. Sep 3, 2021 at 5:35 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    That never happens to me!! I never get that lucky. If I did I'd have to run right out and get a lottery ticket!!
    I'm with ya on the pan plug washer. I have converted my PITA cartridge style filters to spin on... https://baxterperformanceusa.com/product/ts-501-bk-cartridge-to-spin-on-adapter-universal/
    ontarioyota[QUOTED] likes this.
  15. Sep 3, 2021 at 5:36 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Yea this is exactly what I put in mine.
    These cheaper crush washers should be replaced each oil change. As they have plastic or something on each side, that separates when you pull the plug out.
    If you are using the nicer Dorman copper crush washer that @3JOH22A mentioned. They last much longer.
    ontarioyota[QUOTED] and 19Canuck like this.
  16. Sep 3, 2021 at 5:37 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    could bypass all of the crush washer stuff with a ball valve
    :stirthepot:
    Just crank that sucker down and don't need to worry about the crush washer leaking if the valve leaks instead!
    Jokes aside, i replace the crush washer every 2-3 changes since i forget to replace them every 2-3 changes.
  17. Sep 3, 2021 at 5:40 AM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Here is where my luck kicks in...I'd break it off for sure...zero oil left!:annoyed:
    ontarioyota and llamasmurf like this.
  18. Sep 3, 2021 at 5:41 AM
    llamasmurf
    Wes
    Northern Ontario
    I still dont understand putting that a valve on there. Tons of guys have done it.
    Is it that hard to undo a bolt?
    It would be amazing to be out in the bush, and a stick rams up in there and pushes the arm on the valve.
    @honkonbobo had a stick get up and diddle the back of his transfer case out on VMUTS. Unplugged shit so he could not engage / disengage 4wd.
    It can happen. :notsure:
  19. Sep 3, 2021 at 5:43 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    well there is this thing;
    6eee3c14-6905-4f1e-97f3-ce9ea6d70e63_1.513f57b639420b4404739cf23845c310.jpg 3561900.jpg
    Unless you run a stock car and do changes while on the track. i have no idea why people put valves...
    just being facetious
  20. Sep 3, 2021 at 5:44 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    I am referring to the oil pan drain plug washer/gasket
    ontarioyota and 19Canuck[QUOTED] like this.
