Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Sep 29, 2021 at 10:36 AM
    Zephranthes
    Zephranthes Blue Repellent
    Alex
    Mississauga
    96 Triumph Tiger 900 (red)
    21 Voodoo OR DCSB AT
    Checked and dust shields are not bent.
    I saw nothing in or around the brakes. There was some stuff in the brake pads hole that indicates how much is left. Cleaned that out a little but no change.
    Took it for a drive and swerved but there was no change at all to the noise. It literally sounds like something is unevenly rubbing around the rotor but I don't see any marks on the rotor.
    I believe for me, it's something with the rotor. Something is unevenly rubbing against it. Further past that, I have absolutely no clue.
  2. Sep 29, 2021 at 11:10 AM
    Trdtacosauce
    Trdtacosauce Well-Known Member
    Gonzo
    2020 Quicksand
    Hey guys! I installed an OME lift kit last weekend and im getting a bit of a bro lean, i went with 2886 OME springs and im thinking of switching them to get less front lift.
    Does anyone need the 886's? they'll be couple weeks old.
    Cheers!
  3. Sep 29, 2021 at 11:11 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I’m not sure if I could make a line to test the pressure.
    mone did too but it will do it now at random.
    1. got the right fluid
    2. I will check for mechanical binding. It does feel like it but I would assume it would occur more often and at the same turning pace. Not just randomly.
    thanks.
  4. Sep 29, 2021 at 11:16 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    You can use red transmission fluid, I’ve been using it on all my trucks. There is no such thing power steering fluid anymore really.
    Tridet167, Shveet and Windigo[QUOTED] like this.
  5. Sep 29, 2021 at 11:32 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    then you might have a warped rotor.
    i changed my breaks out but never changed my rotor as it was still good. Harsh/ sudden breaking can cause it to warp after a certain point - which i think is why i heard the sound on my truck.
    on a side note, i figured out a solution to mine.
    Just turned up the music :D
    Zephranthes[QUOTED] likes this.
  6. Sep 29, 2021 at 11:58 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    You want 885s?
    Trdtacosauce[QUOTED] likes this.
  7. Sep 29, 2021 at 12:18 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Believe it’s suppose to be atf. Based on the steering rack replacement thread.
  8. Sep 29, 2021 at 12:27 PM
    Zephranthes
    Alex
    Mississauga
    I have done some sudden and harsh braking recently...
    401 traffic is not kind.
    I always have the music turned up.
    It's when I turn the music down that I notice issues. :rofl:
    Shveet[QUOTED] likes this.
  9. Sep 29, 2021 at 1:01 PM
    Trdtacosauce
    Gonzo
    2020 Quicksand
    I think I will get the Eibach Pro springs (Higher spring rate but shorter)
    Tridet167 likes this.
  10. Sep 29, 2021 at 1:11 PM
    Norilsk
    Eugene
    Just a selfish self promotion here passing by
    IF somebody would like a hoodie, there is going to be another batch (quantity depending) for Christmas time.
    Message me here and you will be put on the next batch list.
    May do the hats too... :spending:
  11. Sep 29, 2021 at 3:01 PM
    Zephranthes
    Alex
    Mississauga
    But what about flags?
  12. Sep 29, 2021 at 5:44 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Got your Xmass lights up already eh, nice to see the younger generation not leaving things to the last minute 'cause they are busy eating avocado toast.
    :devil:
    What was on the front of the hoodie again?
  13. Sep 29, 2021 at 5:49 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    An avocado.
  14. Sep 29, 2021 at 6:18 PM
    cwisema
    cwisema Well-Known Member
    Acton, Ont.
    2017 MGM DCSB TRD Sport
    Hey guys, I've decided to get the Headstrong Add A Leaf and the extra 1/2 inch shims. I'm planning to also pick up a set of Bilstein shocks. Do I need to get the 5125's, or will the 5100's also work with the 2 inch lift of the AAL's?
  15. Sep 29, 2021 at 6:21 PM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    Well today was the day, after 8 months of searching, I finally moved in to my new house.
    It wasn't without incident as the old owners were not even moved out by the time I got here. Nor are they done moving at the time of writing.
    Anyways forget all that - the important part - I now have garage. (Still full of their junk)
  16. Sep 29, 2021 at 6:31 PM
    cwisema
    Acton, Ont.
    Congratz! I had a similar experience when I moved into my current house. The previous owners were still moving out long after we got the keys, and even the next day. Luckily we had a weeks overlap between getting the new house and giving up our old house so we weren't moving the bulk of our stuff for a few days.
  17. Sep 29, 2021 at 6:39 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Grats...don't ya mean YOUR NEW JUNK?
  18. Sep 29, 2021 at 6:43 PM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Thanks!
    Same thing here, I watched them all day and they are coming back tomorrow morning to collect a couple loads..it has delayed my plans but at least the old guy is giving me a few free items that I needed.
  19. Sep 29, 2021 at 6:50 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Who’s all going this weekend?
  20. Sep 29, 2021 at 6:51 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
