Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Oct 27, 2021 at 9:59 AM
    zuknewbie
    zuknewbie Well-Known Member
    2018 white off-road dcsb
    Tridet167 and llamasmurf like this.
  2. Oct 27, 2021 at 10:01 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    zuknewbie[QUOTED] likes this.
  3. Oct 27, 2021 at 10:08 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yeah Lasernut is a big contract fabrication company. My Pelfreybilt bumper was made by them. That particular buggy requires a tremendous amount of spatial awareness from the driver to use it to its full potential:
    honkonbobo and zuknewbie[QUOTED] like this.
  4. Oct 27, 2021 at 12:07 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I would love one of those.
  5. Oct 27, 2021 at 12:26 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Lol my thoughts exactly,
    well maybe a little more politically correct and optimistic than what was going though my mind but the same intent none the less.
    Add some dirt and salt or even one Russian and it won't last long.
    Norilsk and Snail81 like this.
  6. Oct 27, 2021 at 1:43 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Alright you fvckers...I said nothing last period as an experiment, and it went unmarked. He'll, @Shveet has been the mayor for the past near 1k posts and he didn't even know it.
    Sooooooo
    Heads up...new mayor territory approaching
    Carry on :rasta:
  7. Oct 27, 2021 at 2:29 PM
    cwisema
    cwisema Well-Known Member
    Acton, Ont.
    2017 MGM DCSB TRD Sport
    Thanks guys. I have purchased the Headstrong Add A Leaf with the 0.5" additional spacer. Headstrong calls this their 2" lift (1.5" for the AAL, and 0.5" for the spacer). So I should be getting about 2" of lift.
    Please correct me if I'm wrong, but the droop or down travel in the rear is more limited by the length of the shocks then the springs, correct? So what I need to pay attention to with regard to the length of the break lines is the extended length of the shocks, right? Am I correct in thinking that the lift is not much of a factor for droop? The compressed length and the lift of the added springs are factors for the new bumpstop length, correct?
    So if I'm thinking of going with a shock with extended length of 23.5-24.5" will that stress the rear break lines at full droop?
    Any suggestions for bumpstop length?
  8. Oct 27, 2021 at 3:52 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i thought we switched to every 10k posts
    :burp:
    but sweet!
  9. Oct 27, 2021 at 4:01 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Nice! that will suit you well, the truck needs a lift for certain.
    currently running Fox 2.0 shocks in the rear which are the same length as the Stock TRD OR (maybe half an inch longer) but yeah - right now the shock is the limiting factor for flex/droop, so in general I'm going to guess with your AAL will do the same.
    At the moment i dont have extended break lines but i did bypass the eyelet that holds it in place and i've not had issues with it as of yet so i would guess that extended travel shocks will eventually cause issues with length.
    in regards of the bumpstops. i just went with what other people figured out to use (GM Bumps) so i'm blindly trusting that it will work without issues.
    Snail81 and cwisema[QUOTED] like this.
  10. Oct 27, 2021 at 4:15 PM
    TeecoTaco
    SW Ontario
    No...you are unfit. Don't even know the rules....
    Consider yourself impeached and not worthy of governing.
    Lech Wałęsa you are not.
    Don't make me mock you yet a second time
  11. Oct 27, 2021 at 4:16 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    If you plan on extended travel shock like B110 then you would need to extend brake lines, remove parking brake cables mounts on the leaf's and unclip wire harness that is at the top off the diff to avoid wire stretching.
    Stock heights numbers :
    Collapsed - 14.02"
    Extended - 22.94"
    Travel - 8.92"
    B110 Bilstein height numbers :
    Collapsed- 16.34
    Extended - 27.28
    Travel - 10.94"
    Anything less of travel than B110 isn't required to have brake lines extended or other modifications from my past experience having different setups at the back.
    One thing you must remember, with lift comes the need for longer bump stops to avoid bottoming out.
    My previous seup was Icon AAL + Fox 2.0 rear shocks, worked pretty well, until it didn't :sadviolin:
  12. Oct 27, 2021 at 4:49 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    That’s what I meant. Same same but different.
    Shveet[QUOTED] likes this.
  13. Oct 27, 2021 at 4:49 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    @Norilsk 2017
    @Norilsk 2018
    @Norilsk 2019
    @Norilsk 2020
    @Norilsk 2021
    WHEELING, IT WORKS PRETTY WELL UNTIL IT DOESN'T ™
  14. Oct 27, 2021 at 6:25 PM
    Norilsk
    Eugene
    Missing 2015 and 2016:boink: it’s been that long since I started breaking exclusively Tacomas oh my…
  15. Oct 27, 2021 at 6:37 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I was guessing. They didn't look too destroyed from all I've seen. I'm still new here.
    Snail81, Shveet and Norilsk[QUOTED] like this.
  16. Oct 27, 2021 at 6:41 PM
    TeecoTaco
    SW Ontario
    What circa were the door ding guards ?
  17. Oct 27, 2021 at 6:46 PM
    Norilsk
    Eugene
    2015 to 2016 :anonymous:
    Shveet and TeecoTaco[QUOTED] like this.
  18. Oct 27, 2021 at 7:10 PM
    zuknewbie
  19. Oct 27, 2021 at 7:25 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Happiness > stock
    Tridet167 and Shveet like this.
  20. Oct 27, 2021 at 7:56 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    What is this I hear about a front drive shaft bearing replacement when lifting...drivers side? Enlighten me. I have some bonging and klunking going on
