Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Oct 15, 2017 at 6:34 PM
    #4481
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    as long as there's some trees around where we camp or someone with a bed rack can park close by and lend another anchor point haha.
    After this weekend I've decided fuck the ground tent, going back to hammock camping. So much easier to pack up and no need to worry about how the ground is.
    Going to anchor to my bed rack and a tree or two bed racks if someone lends a spot.
    Kemosabe, Norilsk and Bocsy44[QUOTED] like this.
  2. Oct 15, 2017 at 6:35 PM
    #4482
    Jake4848
    Jake4848 Well-Known Member
    Jake
    Petawawa, ON
    2017 Quicksand DCSB TRD Offroad
    6112/5160's,SPC UCA's,3 Leaf AAL, ECGS bushing, Extang Trifecta, 35% Tint, Rear diff breather mod, 285/75r16 K02, Clazzio's, RCI Sliders.
    I'm down for that big cluster in the middle. Is it crown land?
  3. Oct 15, 2017 at 6:35 PM
    #4483
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    ill vouch for you on that one haha @Kemosabe he legit hangs back for a bit so he can blast through full throttle :rofl:
  4. Oct 15, 2017 at 6:36 PM
    #4484
    Joe23
    @Kemosabe and given how we kept slowing down in the front for the rest of the pack I can only imagine how harsh it was for some. But slow and steady and just getting spotters really helps.
    Or just be like Eugene and give 0 fucks haha
    Kemosabe likes this.
  5. Oct 15, 2017 at 6:37 PM
    #4485
    Joe23
    Think so.
    Although I would say I don't think any of us are really ready for level 4 trails.
    If I remember right from OF4 they're tough and have no bypasses at all.
  6. Oct 15, 2017 at 6:38 PM
    #4486
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    We can bring chainsaws and make ourself a great secret camping apot! If if someone ask, the spot was already made when we got there:rolleyes:
    Bocsy44[QUOTED] likes this.
  7. Oct 15, 2017 at 6:39 PM
    #4487
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I believe so
  8. Oct 15, 2017 at 6:39 PM
    #4488
    Jake4848
    Jake
    Petawawa, ON
    Not sure what levels are. I'd just go by experience. I'm sure its a full trail system though if everything is that close together.
  9. Oct 15, 2017 at 6:41 PM
    #4489
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Always amused at the high fuel consumption when wheeling. I filled up at the Shell in Parry Sound before and after Ardbeg, at the same pump even. Used 31 L to drive 98 km. That works out to 32 L/100 km or 7 mpg. :laugh:
    tacoma16[OP], Joe23 and Kemosabe like this.
  10. Oct 15, 2017 at 6:41 PM
    #4490
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I was thinking the ones and 2 trails...
    Joe23[QUOTED] likes this.
  11. Oct 15, 2017 at 6:41 PM
    #4491
    Joe23
    4 Difficult trail
    These trails traverse very rugged terrain ( water crossings 24”+, large rocks to 15”+, deep mud, steep inclines and side hills to 30 deg ) low-range 4WD and higher than stock ground clearance is required. Aggressive tread and low air pressure are required. Traction Devices (Lockers or limited-slip) in the differentials (front and rear), lift and larger tires (33”+) are recommended. These trails require above average Off-Road driving skills. Multiple attempts to clear obstacles will be required. There will likely be paint damage and possible vehicle body and/or mechanical damage. Hi-lifts and winches recommended.
    Ardbeg south is a 3.
    3 Standard 4WD trail
    Demanding trails on which 4WD is required. You will encounter a variety of more difficult challenges (loose rocks, large potholes, water crossing depth to 15”, steep inclines 15 deg and large rocks to 10”, 8” mud filled ruts) on these trails. Possible with stock 4WD vehicle, however, recommend traction device (limited slip or locker) in rear differential, aggressive tread and low air pressure. Higher than stock ground clearance is advisable. Low range gears used often. Moderate experience and driving skill advised. Possible paint and/or rocker-panel damage. Recovery gear recommended (Straps/ Hi-lift)
    It would have to be a trail more so for the modified guys. Likely not stock friendly.
    Kemosabe and Jake4848[QUOTED] like this.
  12. Oct 15, 2017 at 6:42 PM
    #4492
    Kemosabe
    Louis
    I like you guys attitude on trails! Around here it is mostly bunch of
    Dudes buying shit boxes, jacking it on blocks, throwing 2000$ worth of mud terrain and jumping in the first mud hole they find! An be fun once or twice, in a rig that is not your haha rather going slow and crawling the trail and camp than destroying everything around, including the rig haha
    Bocsy44 and Joe23[QUOTED] like this.
  13. Oct 15, 2017 at 6:43 PM
    #4493
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    now he tells me :rofl:
    tacoma16[OP] likes this.
  14. Oct 15, 2017 at 6:43 PM
    #4494
    Joe23
    same and possibly the 3.
    4s are a bit much. I wouldn't feel confident going on them. From what I've heard from others in OF4 that have done 4 is that they are extremely difficult for any IFS truck that isn't on 35s with a high clearance rear and aftermarket front bumper cause you need high approach angles.
    tacoma16[QUOTED][OP] likes this.
  15. Oct 15, 2017 at 6:43 PM
    #4495
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    So when everyone is available to make this happened?
    Bocsy44 likes this.
  16. Oct 15, 2017 at 6:45 PM
    #4496
    Jake4848
    Jake
    Petawawa, ON
    I'm up for whatever. It'll probably be the last trail run of the year for me. Until some of us do the black lake loop in the spring next year.
    Taco-Can, Bocsy44 and Norilsk like this.
  17. Oct 15, 2017 at 6:46 PM
    #4497
    Joe23
    I had no clue we were going to be doing the whole thing lmfao.
    If we were to do it again although we now know its possible like when I was talking to @tacoma16 it would be much better to start from the south, camp at that spot we passed in the south on the lake. Then saturday do the rest and get to camp where we camped this weekend. Then just play around a little near the northern portion of the trail on the sunday or just take off in the AM.
    As much as I enjoyed running the trail yesterday I personally think it was too much. was just so drained by the end. Would be better to split it up a little.
  18. Oct 15, 2017 at 6:47 PM
    #4498
    Jake4848
    Jake
    Petawawa, ON
    28th-29th weekend?
  19. Oct 15, 2017 at 6:47 PM
    #4499
    Joe23
    oh I was more so thinking those for next year lol.
    I won't have time to do them this year unless we were doing it this week since I'm off lmao.
    Bocsy44 and Kemosabe like this.
  20. Oct 15, 2017 at 6:48 PM
    #4500
    Norilsk
    Eugene
    The Spooky Run! lol
