Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Dec 2, 2021 at 4:33 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Looks like a precursor to a bobbed bed
    Shveet likes this.
  2. Dec 2, 2021 at 4:51 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    It might just bob itself the way its going
  3. Dec 2, 2021 at 5:29 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I can;t read or spell or speak :drunk:
    Looks healthy to me, needs more pin stripes :curls:
    Shveet, daks and TeecoTaco[QUOTED] like this.
  4. Dec 2, 2021 at 5:41 PM
    tgelata
    Probably at work.
    Hiding under that dirt is enough pin stripes to make al Capone jealous :hattip:
  5. Dec 2, 2021 at 5:57 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Doug's review of the 2022 Tundra shows an interesting design detail - there looks to be extruded aluminum rails between the composite bed and the frame, distributing the load. It should alleviate the wear and subsequent shifting/rattle observed at the Tacoma's bed bolt areas:
    The Tundra also get an electric fuel door popper now, right above the heated steering wheel switch.
  6. Dec 2, 2021 at 6:05 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I just watched that. Our YouTube algorithms are all the same
    Shveet likes this.
  7. Dec 2, 2021 at 7:01 PM
    Norilsk
    Eugene
    we all live in the matrix, nothing is real
    Only took 16 years to figure it out, so happy we get this fixed before 2030 :bananadance:
    Shveet, llamasmurf, Tridet167 and 3 others like this.
  8. Dec 2, 2021 at 7:03 PM
    Norilsk
    Eugene
    I do hope rear disk brakes can be retrofitted on current axle tho, the only thing I'd like to have for ease of maintenance :fingerscrossed:
  9. Dec 2, 2021 at 7:49 PM
    tgelata
    Probably at work.
    *doing a tire rotation
    “Well wheels are off might as well check the rear pads.”
    *sees pads are at like .2 mm thickness*
    “Yep, I’m gonna pretend I didn’t see that.”
    *puts drum and wheel back on*
    maintenance complete :thumbsup:
  10. Dec 2, 2021 at 8:32 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I usually just turn the radio up
  11. Dec 2, 2021 at 8:44 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    It'll be easier to retrofit existing 4Runner rear brakes to your axle, and that's still difficult/costly with the electronic booster master cylinder swap.
    4th gen Tacoma, if it takes after the Tundra, likely won't have provisions for a mechanical parking brake.
    Norilsk[QUOTED] likes this.
  12. Dec 3, 2021 at 4:17 AM
    Norilsk
    Eugene
    I don’t think there is a need to swap it, isn’t it’s design takes the way where it is “adjustable” since we have A-TRAC (within reason of course) and running larger calipers at front and rear calipers at the back won’t affect performance as it’ll simply increase the pressure in the lines? May wear out quicker, but what doesn’t?
    Shveet likes this.
  13. Dec 3, 2021 at 4:59 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Maybe a hybrid approach. Scrap the rear driveshaft and axle. Install a 4link with electric hub motors. Pack the space between the frame with batteries and flat bottom the whole truck. Full torque vectoring for crawling is now possible. Everything is sealed so no maintenance. Motors are brakes. And no driveshaft to get in the way.
    You will also have all the watts for your microwave, Ron pipeil showtime rotisserie, and easy bake oven.
  14. Dec 3, 2021 at 5:19 AM
    Norilsk
    Eugene
    So basically Rivan or a much better looking H4? Sounds expensive, can also electrocute all the fish for the dinner when doing water crossings :anonymous:
  15. Dec 3, 2021 at 5:21 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    gone, like a fart in the wind - only heard once and a sweet smell lingers of the memory.
  16. Dec 3, 2021 at 5:41 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Disturbing...but accurate
  17. Dec 3, 2021 at 5:51 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Even better, your keeping the engine and the FWD. The hybrid approach should cut a lot of cost of batteries. Motors are cheap(ish).
  18. Dec 3, 2021 at 6:24 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Higher fluid volume at the caliper (vs. drum brake wheel cylinder) means noticeably more pedal travel before the brakes engage, so you end up with even shittier pedal feel. I already notice this with the larger 4Runner brakes - it's the compromise of spending <$1000 on 4Runner OE parts vs. $3000 for a StopTech kit actually designed for the Tacoma. The 4Runner MC has larger pistons to match the increased fluid volume.
    Snail81 likes this.
  19. Dec 3, 2021 at 6:54 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    See if you had a Lexus with ventilated seats...
    Snail81 and Shveet[QUOTED] like this.
  20. Dec 3, 2021 at 7:01 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    The booster is definitely needed to swap and get good brakes. I know with my 4Runner big brake upgrade the pedal fee is crap.
    As for rear brakes, based on the rear brake thread a bigger booster is needed.
    I know the tundra or sequina booster is a great upgrade and it’s pretty much bolt in other then.
    For the price of rear brakes on these trucks, it’s not even worth it for the performance gain.
    Tridet167 and Snail81 like this.
