Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Dec 11, 2021 at 3:25 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    If those bottom gussets are that short,
    the stress that normally goes to the front mounting bolts and fairlead will transfer to the back as the plate flexes at the front if the pull force is not straight,
    and your gonna bend your plate the winch is mounted to.
    Curb weight stock is about 2000Kg ... Then add the Russian factors ,so multiply mass by two, in your calculations for FEA.
    somebody and TacoPandaTRD like this.
  2. Dec 11, 2021 at 4:07 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    good catch. I may remake those out of some bigger gussets. With his welds they shouldn’t be too hard to remove :p
  3. Dec 11, 2021 at 4:07 PM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    :rofl:
  4. Dec 11, 2021 at 4:13 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    yeah, we are going to omit part where I install, service and work on gas equipment as my job :anonymous:
    I didn’t tack weld the gussets yet, just there for reference ffsk
    tacoma16[QUOTED][OP] and Snail81 like this.
  5. Dec 11, 2021 at 4:48 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Thank god. We will be able to use those for the rear bumper and parts of the front bumper. Then I’ll have to make something for the rest I guess.
    llamasmurf likes this.
  6. Dec 11, 2021 at 4:57 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Is 110 lbs over the axle sufficient for traction or should it be more?
  7. Dec 11, 2021 at 5:02 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Try it and see. Can always add more. I have never had to add anything but my shitbox is heavy though.
    TacoPandaTRD likes this.
  8. Dec 11, 2021 at 5:12 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I mean ... You technically added several hundred pounds
  9. Dec 11, 2021 at 5:15 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Pretty light in the rear though. Most of the weight is up front.
  10. Dec 11, 2021 at 5:24 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
  11. Dec 11, 2021 at 5:29 PM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    I add a 100-150lbs Leer topper, and 100lbs of winter safety/recovery stuff that I carry always (unless I foresee needing the sq ft). Even when it’s just the topper I find it’s sufficient on most days considering the limitations of Duratracs.
    Snail81 likes this.
  12. Dec 11, 2021 at 5:41 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
  13. Dec 11, 2021 at 5:42 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Accurate
    daks[QUOTED] likes this.
  14. Dec 12, 2021 at 7:08 AM
    TunedUpTaco
    TunedUpTaco Well-Known Member
    Rob
    Dundas, Ontario
    2017 Tacoma TRD OffRoad - DCSB - Auto - Stock(ish)
    LOL - love it. Serious question though: you running studded tires? Thinking about getting them for my fat bike, but $$$$
  15. Dec 12, 2021 at 8:21 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I have them but I haven't used them in a couple years. I don't generally hit patches of ice where I ride (Christie/turkey point/Redhill/ Dundas valley) and if I do, so be it. If I was specifically going to ride on the street/rail trail or a lake then I'd switch over but I run tubeless so it's a lot of work. My studded tires are worth like $400 lol.
  16. Dec 12, 2021 at 9:41 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    I put a 50lb patio stone over my axle for the winter. Also swap out OEM rims for steel rims with winter rated tires.
    ontarioyota and Shveet like this.
  17. Dec 12, 2021 at 10:06 AM
    oostroma
    oostroma (Boomer)
    Ontario
    Fyi, I believe all aftermarket remote starts also shut the engine as soon as the driver's door open.
  18. Dec 12, 2021 at 10:08 AM
    oostroma
    oostroma (Boomer)
    Ontario
    Fyi, my daughter has a 2021 RAV4 TRD OR and has confirmed that although she can start it with the app, she can also start it with 3x clicks of the lock button on the key fob.
  19. Dec 12, 2021 at 10:52 AM
    TunedUpTaco
    Rob
    Dundas, Ontario
    Oh dude, you are right were I am then! I'm in Dundas.
    I ride Christie a lot and also help out with the maintenance there via the HBMBA club.
    We should do a TEC MTB ride at some point :)
  20. Dec 12, 2021 at 11:01 AM
    oostroma
    oostroma (Boomer)
    Ontario
    Has anyone upgrade the ECU with the KDMax Pro yet?
