Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 12, 2022 at 3:49 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    If they go through the effort to steal my truck they can have it. With the way the used market is I’ll be abe to use the insurance money to buy 2 new tundras, build a 1st gen tacoma and pay off my mortgage :blahblah:
  2. Jan 12, 2022 at 5:39 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    After torquing it down, cleaning up, multiple warm up drive around cool down and repeat procedures I checked oil cooler again. Dry as it can be. Problem fixed and Tacoma continues to be trouble free (it may have possible been some anti corrosion fluid too :anonymous:)
    ontarioyota, Snail81, tgelata and 8 others like this.
  3. Jan 12, 2022 at 5:39 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The Milwaukee being 2/3 the length of the other two is reason enough to get it. I got the M12 version (same 250 ft-lb torque) to be able to use an even smaller battery.
    Snail81 and llamasmurf[QUOTED] like this.
  4. Jan 12, 2022 at 5:47 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Ar first I was a little bummed that the M/T's still got a key start....
    Now that it adds some slight delay to a thief I feel a little better.
    Nothing will stop a professional if they really want it,
    you just have to make it more efficient for them to go after the next person.
    Not personal, just business in their minds.
    If they are not using a "man in the middle" attack reading and relaying fobs to initially get in,
    then someone is accessing/hacked the denso or techstream systems and got the fob ID# database to cross reference it by VIN.
    Steel tin to store your keys in is the easiest protection for the first.
    In theory changing out you key fob and using offline techstream to program new ones (not at a dealer) would fix that second issue.
    key fobs use two different IDs, one for far ID and one for passive (when you have to hold the fob to the button when you start with dead fob battery or in the manual key for the immobilizer)
    Then you'd have to move and hide the obdii port on the truck, maybe setup a dummy one to keep them fiddling a little longer and give up without searching for the real one.
    Then if they had the database the M/T guys would have to change their tumblers....
    But then you won't stop the guys with the tow trucks and flat beds.
    Well unless alarms and guard dogs...
    But then....
    Fook it, lock it and make sure my insurance is paid up.
    Officer "why do you keep a baseball bat by the front door?"
    Me: "Oh it's part of the Alarm system"
    Officer "oh really, how does that work exactly?"
    Me: "Well,hmmmm, it makes this clunking sound every time someone gets too close to my truck"
    ontarioyota and Norilsk like this.
  5. Jan 12, 2022 at 5:49 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Pro tip: keep a baseball glove next to the bat to avoid questions by police :thumbsup: Also works for in-vehicle carry.
    Snail81, tgelata, honkonbobo and 2 others like this.
  6. Jan 12, 2022 at 5:53 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Glad your oil filter housing is dry....
    But is your oil cooler still leaking?
    Or am I not keeping up with what has been screwed up?
    You do tend to break a lot of things, maybe I fell off my pencil while taking notes?
  7. Jan 12, 2022 at 5:56 PM
    Norilsk
    Eugene
    Potato potato :brianr:
    but you get the point, now onto continuing fixing other shit that’s broken, aiming to be back on the road by February :sawzall::welder:
  8. Jan 12, 2022 at 6:12 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    He is going to blow it up because he didn’t fix something and then blame toyota for shitty design. Pretty typical….
  9. Jan 12, 2022 at 6:12 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Toyota says it’s normal
  10. Jan 12, 2022 at 6:13 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    No wonder your not married, geez don't know what bits your putting your hands on, and what parts should be dry vs wet!
    Wait wat? You broke more stuff you gotta fix, don't go anywhere let me go sharpen my pencil. Be right back.
  11. Jan 12, 2022 at 6:18 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    I have a feeling someone is warming up a welder to weld up some more penis' on repair welds on a certain someone's frame.
    Every Coffee and greet we will be combing his truck for the phallus finding "easter eggs" to track his repairs and modifications.
    You know every club needs a tradition. Some will get the Phallus Valve Stem. others will get the Phallus frame.
  12. Jan 12, 2022 at 6:27 PM
    Norilsk
    Eugene
    It shall be named Frame of Fame :humble:
    Snail81 and daks[QUOTED] like this.
  13. Jan 12, 2022 at 6:31 PM
    FastEddy59
    Eddie
  14. Jan 13, 2022 at 1:09 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Just had a 4 cyl sr5 come in. Never actually driven one till now. Too bad it’s auto.
    daks likes this.
  15. Jan 13, 2022 at 2:47 PM
    Norilsk
    Eugene
    New set of wheels for Tacoma is here, I promise they look bigger when up close, both 16” :rasta:
  16. Jan 13, 2022 at 4:00 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    >5 bolt steelie.
  17. Jan 13, 2022 at 4:04 PM
    Norilsk
    Eugene
    Tundra axle conversion?
    Shveet[QUOTED] likes this.
  18. Jan 13, 2022 at 5:07 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Your never gonna get married if you don't know what bits can fit where...
    Is that why you were complaining that your last girlfriend got mad, hissed at you and flew out the window in a big huff.
    And you needed that tire repair kit from @tacoma16 to go patch up your relationship?
  19. Jan 13, 2022 at 5:19 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    I live in the bush and when my truck sits in the drive shed that is quite a distance from the house I use the club to deter. I say get one @19Canuck :thumbsup: No chip in my key so no worries there. I can get keys cut easily if I can find blanks. Original key is so worn it won’t turn the ignition anymore. Last time I got keys cut it was under $25 for six at an old fashion hardware store. In two weeks I will be in my new house with an attached garage so I will worry less about the taco.
  20. Jan 13, 2022 at 5:25 PM
    Norilsk
    Eugene
