Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 20, 2022 at 8:51 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    :gossip: I got dual Snorkies too.
  2. Feb 20, 2022 at 9:02 AM
    ToronoTaco
    ToronoTaco Well-Known Member
    Gabriel
    THE BUSH
    4WD prerunner on 33s and a BJ42 Land Cruiser in pieces
    2inch lift bilstien 5125s, JBA ucas, icon add a leaf, lockrite locker in the rear, diffdrop, swapped a 5vz and a r150f, frame swapped it after a bit, tundra brakes
    Hey, does anyone know some shops in south central ontario that specializes in tacomas and what not. I'm in muskoka and my build is nearly done, and I just want to get it done.
  3. Feb 20, 2022 at 9:34 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    TunedUpTaco likes this.
  4. Feb 20, 2022 at 9:48 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    the only spot i know that "specializes" in Tacomas is a Toyota dealership.
    :cookiemonster:
    As many Subaru converts there are, with their infinite number of Subi-only mechanics, that aspect of them did not translate over when they switch to a Tacoma.
    most offroad shops know enough to work on any vehicle so i think that is what you should be asking.
  5. Feb 20, 2022 at 9:51 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    All Subie guys are Tacoma fans but not all Tacoma guys are Subie fans.
    so watching Subie lift kit videos is a normal part of life for us
  6. Feb 20, 2022 at 9:55 AM
    Windigo
    Farook
    '14 Acess Cab
    Thanks that's a relief.... Just had to check:)
  7. Feb 20, 2022 at 11:02 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    600 KM out of a tank! From Orangeville Ontario all the way to Montreal (roughly)
  8. Feb 20, 2022 at 11:05 AM
    Dye22
    Dye22 Well-Known Member
    Squamish
    '15 TRDOR ACLB
    JBA UCAs OME 2.5 in lift w/ heavy duty dakars. 33" ko2s tc bed stiffeners firestone airbags w/ ride rites cmc/pinchweld rear flushmount leds amazon ditch lights apex sliders 0 degree w/ kickout Coastal Offroad high clearance front bumper w/ full tubing Coastal Offroad high clearance rear bumper w/ tubing and dual swingout 100 AH LiFePO4 Aux battery blue sea fuse panel for aux battery rear diff mod breather Mountain Hatch tailgate insert Smittybilt x2O 10k winch Anytime Camera Mod Front and Rear GPS locator brick BAMF Hangers w/ custom crossbrace 2lo Mod by up2nogood yakima access cab roof bars thule hyper xl cargo box amazon roof basket ARB 1250 awning WaterPort Meso Dual Color Dome Light Durobump Front Bump stops
    What are you looking to have done?
  9. Feb 20, 2022 at 3:30 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Just a weee peak at the the amazing, crazy, awesome wheeling we had this weekend.
    :headbang:
    :cookiemonster:
    :fistbump:
    :curls:
    Every single one of us, can learn from Dax. That man knows how to wheel!
    :hattip:
    3JOH22A, TacoPandaTRD, philth and 2 others like this.
  10. Feb 20, 2022 at 3:39 PM
    Windigo
    Farook
    '14 Acess Cab
    No problem we can fix that by putting some 315's on and that should get you down to the 300km mark.
    No thanks needed. Just trying to help :):)
  11. Feb 20, 2022 at 4:22 PM
    ToronoTaco
    Gabriel
    THE BUSH
    I mean Yes, that IS an option. I've engine, transmission, frame swapped it, lifted it a couple inches, jba ucas tundra brake and have one of those lockrite lockers in her rear, like really messed around with it. I just want someone to help iron out kinks or better yet, a shop like justjeeps
  12. Feb 20, 2022 at 5:23 PM
    Windigo
    Farook
    '14 Acess Cab
    don't know if you want to share of not but just curious as to the "kinks"
    Shveet likes this.
  13. Feb 20, 2022 at 5:44 PM
    ToronoTaco
    Gabriel
    THE BUSH
  14. Feb 20, 2022 at 7:00 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I couldn't even start with trouble shooting that. Well at least that clears up specifically what you're trying to do...
  15. Feb 20, 2022 at 7:41 PM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    Snow wheeling south west style. @19Canuck and I have a loop with about 15 km of No Winter Maintenance roads around St Mary's. Today's run was the first time this year we had enough snow to stop us. The snow stopped another group we came across. The big diesel Ram required a tractor to get out. Great run close to home.
  16. Feb 20, 2022 at 8:40 PM
    Windigo
    Farook
    '14 Acess Cab
    don't know if you want to share of not but just curious as to the "kinks"[/QUOTE I have a misfire in cylinder 3 which shakes on occasion, I've replaced the plugs and wires, but I suspect it has something to do with the fuel rail. After I swapped cab harnesses over, the dash doesn't show CEL's or when I shift in and out of 4 wheel. I dont want to throw parts at it. That and I'm sure there is a bunch of stuff I dont know going on
    how did you narrow it down to cylinder #3?
  17. Feb 20, 2022 at 9:07 PM
    Dye22
    Squamish
    '15 TRDOR ACLB
    most modern code scanners will tell you, if not you can always go the old fashioned route and point a temperature reader/gun at the manifold exhaust ports and the problem cylinder will read much lower temp than the others (assuming the others are working fine). Then you can pull the spark plug and that will give you clues about what's going on
    Shveet and Snail81 like this.
  18. Feb 20, 2022 at 9:18 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Love how you called @Norilsk out as if he owed you money
    :rofl::rofl::rofl:
  19. Feb 20, 2022 at 9:34 PM
    Windigo
    Farook
    '14 Acess Cab
    Taking it to a shop will.waste your money. You already have enough knowledge to figure this out.
    Personally I'd start with a compression check of that cylinder and compare the reading with a couple of other cylinders.
    Then I'd switch that cylinders injector to another cylinder and see it the problem moves
    Same with plugs and wires and coil.
    Didn't even ask what engine are we talking about?
    Shveet and Toms2Yotas like this.
  20. Feb 20, 2022 at 9:44 PM
    Dye22
    Squamish
    '15 TRDOR ACLB
    No idea, not OP :p
