Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 4, 2022 at 5:28 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    my issue is that if i want to Run the DD pod lights, i would need to create a new wiring harness since the current one only has 3 wires going to the backrack.
    If i want to use the fancy red backlight feature and anything else, then i'm looking at needing more wires to send back there.
    (Master Grounding, Live for lightbar, upsize live for Pod lights, Live for backlights, and whatever other effect)
    Not all too bad to do but it's a bit of a bitch but will certainly take a day or so to do;
    1. Remove Backrack
    2. Remove Tonneau cover
    3. Remove the old wires and conduit (wires are taped together so i can't use one to pull in more) which have 30 zipties most likely
    4. conduit is also sealed at both ends meaning fun trying to cut open to salvage the conduit
    5. Upsize all of the existing wires to be that of the same, So new wires all together
    6. got to bundle the new wires
    7. Feed into new conduit (might need to upsize) to a 1.5" round
    8. Remove the headboard thing on the front of the bed as the master connecot is mounted there.
    9. wire/solder new master connector as i have a 4 pin version and would like to have the 7 pin so it's in one connector (however the 7pin is rated to 12A where the 4 pin is rated for 20A. so would most likely need to get this guy meaning new mounting solutions. if need to remove the 4 Pin connector, will need to remove old rivnuts)
    10. remount the master connector to the headboard square tube thing
    11. new plugs for all of the lights. This includes front pods and what not since i'd like to keep things consistent.
    12. wire everything up and see if it work
    13. Wire up new master connector to secondary Aux box that is mounted to the headboard square tube thing as well
    14. drill new holes into it and have a new larger grommet
    15. wire wire conduit to secondary aux box
    16. go to the truck
    17. feed wire conduit through frame and butt against the cab mount, fish rest of the wires up into the engine bay via where the rubber mat covering is
    18. fish wires up to rat's nest that is the primary aux fuse box and switch panel
    19. feed conduit up to the back of the truck
    20. remove the old door stopper plate from the back and replace with new one in new location to prevent cable from rubbing up against the cab
    21. zip tie everything in
    22. mount new harness to secondary AUX box since routing is a bitch
    23. bolt the headboard back into place
    24. reinstall tonneau cover
    25. drag the backrack back and lock into place
    26. hope to the Offroad God and patron saint of PC Cabling
    27. done.
    philth likes this.
  2. Mar 4, 2022 at 7:14 AM
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
    We expect a video on this ,,,:hattip:
    RoamingGnome, ODSC1, philth and 2 others like this.
  3. Mar 4, 2022 at 7:20 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    my favorite part, is that you listed "go to truck" in step 16, like it was actual task :rofl:
    tgelata, TacoPandaTRD, ODSC1 and 2 others like this.
  4. Mar 4, 2022 at 7:30 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Unlike some people here that have a garage, my bed room is my workshop
    :anonymous:
    the task of getting my ass up off my chair after tinkering is a feat of engineering on its own.
  5. Mar 4, 2022 at 7:30 AM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Right?
    Then I want to play it at 1.5x speed with the Benny Hill musical backtrack
    daks and Canadian Joe[QUOTED] like this.
  6. Mar 4, 2022 at 7:34 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    side note: Mining Rig? that's quite the power supply
  7. Mar 4, 2022 at 7:39 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Long story with that one.
    It was a donated rig that was meant to go to someone 2-3 years ago but they flaked because they didn't want to spend the $60 for me to ship it and expected me to send it to him for free. This was after I dragged it from new Jersey to be able to make it as cheap as possible.
    So after it sitting around in my room taking up space for 8 months, I figure to spite him i scrapped the rig. the AX1200 there was 10 years old at the point. not risking a fire hazard. i still have it sitting around as a "worse case scenario" though.
  8. Mar 4, 2022 at 7:42 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    :bananadead:
    production costs will come from both of your pockets in the form of membership fees!
    philth and TeecoTaco[QUOTED] like this.
  9. Mar 4, 2022 at 7:45 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    You have the whole rig? what are you waiting for, plug that hoe in
    :boink::curls:
  10. Mar 4, 2022 at 7:48 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i scrapped the rig.
    I took it to Staples
    and put it....
    TacooSaucee[QUOTED] likes this.
  11. Mar 4, 2022 at 7:50 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    well at least make the fire risk someone elses problem
    philth likes this.
  12. Mar 4, 2022 at 7:56 AM
    Downytide
    Downytide Well-Known Member
    21 Tundra TRD Pro
    LT headers, 5.29s, Magnuson
    I think Toyota Canada likes to do things differently just because they can, for example, 2.5gen Tundra TRD pro in Canada has BSM, parking sensor, but you can't have those in US, US Trail edition Tundra had those boxes so I thought was available here, got part numbers and shows up as available, but couldn't order them, same thing with that Army Green cooler, shows up in the system but couldn't order it, then on the new Tundra you can't order tech pack or have certain color options when its widely available in states, but now suddenly you can get one in 2wd.
    daks, philth and 3JOH22A[QUOTED] like this.
  13. Mar 4, 2022 at 8:28 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    You know they make cases that you put the computer parts inside of
    daks likes this.
  14. Mar 4, 2022 at 8:31 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    @Shveet I got a spare if you need
  15. Mar 4, 2022 at 8:31 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    ooooh....
    so that's what they're for....
    somebody likes this.
  16. Mar 4, 2022 at 8:34 AM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Maximum ROI = less expenditures, ghetto is the way
  17. Mar 4, 2022 at 9:56 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    As long as real estate $$ / sq. ft isn't factored in :laugh:
    They sell racks for this, not too expensive:
    llamasmurf likes this.
  18. Mar 4, 2022 at 11:21 AM
    philth
    philth .
  19. Mar 4, 2022 at 2:21 PM
    TacooSaucee
    2020 Off-Road DCSB
    Cracked Windshield
    Not sure how my tailgate bushing got this messed up.
    New vs old
  20. Mar 4, 2022 at 2:26 PM
    TeecoTaco
    SW Ontario
    OK, my Thunder Bay friends...can you chime in here for me. I might need a mission (should you decide to accept it) of informational nature not remotely related to tacomas or Off-Road.
    I've tracked down a car I used to own, sold in 93, that now resides in Thunder Bay. I have details (no address) that I won't publish here but will share via DM to locals
    Wouldn't mind if someone could eyeball something for me SHOULD anything come out of it. All on the up and up, and everything would be arranged by me for both sides
    Very, very preliminary at the moment, just guaging a feel if I have eyes on the ground
    Gracias fellow cunts
    Speaking of which, where is @Joe23 ?
    Joe23, philth, Shveet and 1 other person like this.
