Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 15, 2022 at 10:22 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    i am lifted ~2.5" with icon RXT option 3 in the rear with no shims or carrier drop and no vibes.
    cwisema[QUOTED] likes this.
  2. Mar 15, 2022 at 11:00 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    shims don't affect on angle, you must be talking about carrier drop, YMMW with that, some have some don't. I had without it with my icon leaf pack.
  3. Mar 15, 2022 at 11:05 AM
    honkonbobo
    Eric
    SW Ontario
    they do affect pinion angle, just not drive shaft angle.
    cwisema and Norilsk[QUOTED] like this.
  4. Mar 15, 2022 at 11:11 AM
    Norilsk
    Eugene
    correct, haven't seen anyone worry about pinion angle here, mostly everyone adjusts driveshaft tho.
    cwisema likes this.
  5. Mar 15, 2022 at 11:24 AM
    honkonbobo
    Eric
    SW Ontario
    one TW documented strategy is to make sure your pinion angle is close or equal to your t-case angle.
    Toms2Yotas and Norilsk[QUOTED] like this.
  6. Mar 15, 2022 at 11:34 AM
    Norilsk
    Eugene
    well, I may need to refresh my reading on that and check it sometime when it's warm :thumbsup:
  7. Mar 15, 2022 at 4:56 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    I didn't use them. Has been on for 3 years and no issues. I also kept the overload in
  8. Mar 15, 2022 at 5:28 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    In his defence. When we were riding on centre island he did throw it 10ft away off some rocks.
  9. Mar 15, 2022 at 7:04 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Is there anything I can do with a broken recovery strap? It's a clean sever[​IMG]
  10. Mar 15, 2022 at 8:12 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    How long is the strap? and where did it break?
    could always overlap 2 to 3 feet of the cut and sew it together with some heavier thread. Granted might be more effort than to replace it.
    Make some loops maybe?
    https://www.sailrite.com/How-to-Sew-Webbing-Loops
  11. Mar 15, 2022 at 8:42 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    It's 20'. Pretty close to center or slightly more to one side. It's cheap enough that I don't really care but there's gotta be some use for it
  12. Mar 16, 2022 at 2:54 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I’m not running any shims. The driveline vibes is hit or miss. I say install it and worst case play with the carrier bearing (put some washers to make a drop. Little bit at a time) to help adjust. If that doesn’t work you can add shims later on.
    cwisema[QUOTED] and Shveet like this.
  13. Mar 16, 2022 at 6:39 AM
    TacoRocco
    TacoRocco Well-Known Member
    Niagara Region, ON
    09 Tacoma TRD OffRoad
    OME 2 inch lift
  14. Mar 16, 2022 at 6:54 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
  15. Mar 16, 2022 at 8:15 AM
    TacoRocco
    Niagara Region, ON
    OME 2 inch lift
    If anything kills me, it's work.
  16. Mar 16, 2022 at 4:36 PM
    RoamingGnome
    RoamingGnome Well-Known Member
    Gerry
    Ontario, Canada
    2017 Tacoma TRD OffRoad
    Mostly stock for now...
    We use (and destroy) a lot of heavy nylon straps at work - probably the safest thing you could do would be to salvage some chunks and use them for padding when putting a recovery strap (or ratchet strap) over something with a sharp edge that might cut the strap
    Shveet, philth and ontarioyota like this.
  17. Mar 16, 2022 at 7:41 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Got them directly from them.
    ODSC1[QUOTED] and Shveet like this.
  18. Mar 17, 2022 at 2:03 AM
    philth
    philth .
    100% this.
    When it comes to any sort of rigging/hoisting/tying down/towing, the moment you see even a fray on any strap, that strap/equipment is scrap. The load rating has been compromised. They would be cut up and either used as padding or hucked out.
    How much is your safety and the safety of those around you worth?
    Buy a new strap. Don’t put anyone in unnecessary and preventable danger. Don’t use broken or damaged straps (for their original intended purpose), that’s just silly. Take it out of your kit, and either repurpose it for no load tasks or trash it.
  19. Mar 17, 2022 at 11:54 AM
    Norilsk
    Eugene
    :puke:At Erin Park Yota
  20. Mar 17, 2022 at 2:09 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Buy it
    Canadian Joe and Shveet like this.
