Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Apr 9, 2022 at 1:26 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Let us know when it is :D
    Snail81, Shveet and Zephranthes like this.
  2. Apr 9, 2022 at 2:21 PM
    TunedUpTaco
    TunedUpTaco Well-Known Member
    Rob
    Dundas, Ontario
    2017 Tacoma TRD OffRoad - DCSB - Auto - Stock(ish)
    I tried to research all this, but I don't trust myself, and I don't want to order the wrong parts, so I figured I'd ask the Oracle that is the Ontario BS Thread:
    From what I read, the widest/biggest tire you can fit on a '17 TRD OffRoad (stock suspension) is 265/75/16 or 265/70/17
    But how wide a rim would fit? Say 17x9, with -38 offset, with 265/70/17 tires ?
    Or will that rub? I don't mind putting in spacers, I actually like the 'skateboard' look :anonymous:
    Is there a shop in the Hamilton area that would actually be able to advice on this (and not just pull up tirerack or something like that) ?
  3. Apr 9, 2022 at 2:26 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Technically, 255/85r16 is the biggest on stock wheels. Once you get into offsets, it's a crapshoot
  4. Apr 9, 2022 at 3:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Factory offset is around +30mm. -38mm offset means the centerline of the tire will be about 3" farther out. The tire won't rub the suspension, but will rub the fenderwell plastic. If you like the look, then get your cutting tools ready :)
  5. Apr 9, 2022 at 3:04 PM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    25 Tacoma TRD Off Road
    Bone stock for now
    If you put spacers on with stock tire size, they will rub (mine do a bit). Try to avoid pushing the tire out too much. there seems to be a "hump" in the mud guard that will catch the tire if it's pushed outboard....
    I have a set of 285/75R17 that I'm going to put back on without the spacers to see how they do. With the spacer, they eroded their space into that mudguard hump.
    Been to shitty out to do it in the driveway and I didn't feel like moving the hot rod that's been napping in my garage for the winter.
    TunedUpTaco[QUOTED] likes this.
  6. Apr 9, 2022 at 3:13 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’m running your exact wheel specs with 35x12.5x17. With a 265 and that wheel spec you’ll be having a lot of poke which will give you the issues. A 265 fits on stock wheels with no lift. As soon as you start pushing the wheels out you’ll run into issues.
  7. Apr 9, 2022 at 3:23 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The replacement Amazon front camera also lasted just one year. Time to try a different design. Picked up a Type S P/N BT530027 HD camera on clearance. It's the wi-fi version of the camera used by TRDTaco420, except the video goes to your phone instead of a separate display.
    AM-JKLXY52o6sIAKDbSqRZo0Sn4-TnydxNrrjl-1_1d4b6dea46dc4df389488c446c0f182cdb921253.jpg AM-JKLXZB8mP07uQo0KCJgqkgcD7KVOfJuaQfFfO_ede2f32d6e5304844bc7a30b2391640319c5d7ae.jpg
    Wiring cleaned up. As before, I tapped camera power from the fog lamp connector at the bottom of the grille support. (The fog fuse was swapped out with a 5A fuse to account for the thinner wires.) The Certified P/N 020-6927-2 0.110" wide blade receptacles fit tightly to the connector pins.
    AM-JKLVSsiAcjT09g_qlNkU57Mp1OzYghWCrpiHT_8dc3997412cafc8eeef60988b4b9707a89dbdbb9.jpg
  8. Apr 9, 2022 at 3:25 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Just works off an app? Need to supply 12v power?
  9. Apr 9, 2022 at 3:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Yes and yes. I wired the camera to the fog light connector, to turn the camera on and off with the fog light switch.
    Shveet and tacoma16[QUOTED][OP] like this.
  10. Apr 9, 2022 at 3:32 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Ah neat. Otherwise it’s just getting constant power.
    I have my stock camera in the rear but it leaves a lot of room for improvement. This kind of thing would allow some more flexibility. The stock harness to extend is a bit of a pain. Good to know this stuff is out there. Future is now I guess lol.
    Tridet167 likes this.
  11. Apr 9, 2022 at 3:49 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Nope, still 2022 wifi technology lol. This new wireless camera has a couple of major drawbacks that make it unsuitable as a backup camera:
    1. When you power on the camera or open the app, it takes 20-30 sec for wifi pairing to happen before the live video is displayed.
    2. There's a 1-2 sec lag, ok for crawling in 4-low, not ok when backing up.
  12. Apr 9, 2022 at 3:55 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Dually noted. Thank you!
    3JOH22A[QUOTED] likes this.
  13. Apr 9, 2022 at 7:41 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Well disassembled the grill and put it back together with the other pieces. Looking t it I figure d I needed just a bezel and that main colour matched part. Once apart the main black piece was all cracked to pieces too. It'll all hold up for a while and looks pretty good.
    I have an extra grill (just the middle piece) that I got when I purchased the whole thing from someone. Its got some flaky paint, but if anyone is in a pinch at least they will have a grill. Free for whoever wants it
    Snail81 and tacoma16[OP] like this.
  14. Apr 9, 2022 at 8:43 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    and that was something so hard for me to get my head around coming from the jeep world. With solid axle jeep's poke away all you want. You start poking with IFS and its down the rabbit hole you go
  15. Apr 9, 2022 at 9:27 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Dibs!
  16. Apr 10, 2022 at 5:56 AM
    TunedUpTaco
    Rob
    Dundas, Ontario
    I think I'm just keeping it safe, 16x8 with 265/75/16 , either Goodyear Duratrac or Cooper Discoveres - have not made my mind up there....
    Zephranthes, ODSC1, Snail81 and 2 others like this.
  17. Apr 10, 2022 at 5:57 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    @TunedUpTaco i have a 16" -10mm with a 255/85/16 cooper st Maxx tires. adding a 2 inch lift help but get a heat gun as well and push all the fender plastic into the truck the best you can. Also no more front mudguards and you might need to trim some stuff further. With the SPC uppers i have pushing the wheels forward, no issues but its close.
    Iirc you can get a 0 offset with little issues. But the moment you get into the negatives youll need to start playing around.
  18. Apr 10, 2022 at 6:12 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    somebody, TunedUpTaco, philth and 2 others like this.
  19. Apr 10, 2022 at 6:19 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I like to live dangerously. Princess auto specials. No pin locks on mine. Just the single latching hooks.
    TacoRocco, Snail81 and Canadianguy91 like this.
  20. Apr 10, 2022 at 6:19 AM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    Corvette? Caddy?
