Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. May 30, 2022 at 1:13 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Tell him to shove this BS up his ass, lift does not affect actuator work. Drive line angles do not affect actuator work, it’s way in middle past the axles. Shitty breather location (stock) does, water gets in. So move it up the engine bay.
  2. May 30, 2022 at 1:29 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Wait...they're fixing it, under warranty...what's the problem here?
    To put an addendum on the bold above...
    Should you choose this option, do it when they actually deny the warranty work...if it's still warranted
  3. May 30, 2022 at 2:09 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Kinda what I was thinking.
    Shveet and Norilsk[QUOTED] like this.
  4. May 30, 2022 at 2:09 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Shveet likes this.
  5. May 30, 2022 at 2:12 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    full of shit. Ask him how? The front diff is securely mounted and the only thing would be the cvs affected. I may have a front diff actuator from a second gen with the diff tube you can bring in and ask him how the hell it is affected.
    Shveet likes this.
  6. May 30, 2022 at 2:17 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    the way they are making it out to be a favour rather then doing their job. Yes they are replacing it, but if it fails again it should be replaced again. The lift isn’t affecting it. I would ensure that if the actuator fails it’s a Toyota issue not a suspension problem.
    Shveet and 19Canuck like this.
  7. May 30, 2022 at 4:51 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Now that I know where it is mounted...I agree absolutely zero to do with the lift.
    I called him back and asked him to make sure he saves the actuator as I want to see it.
    He asked why?
    I said because Its my actuator off my truck...lol..he was completely puzzled.
    Guaranteed when I sunk it she sucked up a bunch of water...but I ain't telling him that.
    That just confirms to me zero to do with a lift.
    Shveet likes this.
  8. May 30, 2022 at 5:10 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    There is a breather for it and the unit should be sealed. On the new unit make sure the breather is connected. Water intrusion shows it’s a failure of the stock system that you didn’t modify. Additionally if you are “sinking” your truck, a extension on the breather may be needed. I do believe that it t’s to the breather for the front diff into the engine bay.
    19Canuck[QUOTED] likes this.
  9. May 30, 2022 at 5:18 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Well one never plans on sinking ones truck...lol...but yes, mod needed here.
    Shveet and tacoma16[QUOTED][OP] like this.
  10. May 30, 2022 at 5:19 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Lol let me rephrase, if the probability of sinking it is bound to occur again lol
    Shveet and 19Canuck[QUOTED] like this.
  11. May 30, 2022 at 5:27 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Probability somewhat high.
  12. May 30, 2022 at 6:41 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    7ft chasis lift is a bit much dont you think?
  13. May 30, 2022 at 6:45 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Only way to fit 40’s and be able to turn lock to lock at full stuff without scratching the paint :D
  14. May 30, 2022 at 6:50 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Never seen you this pissed before :rofl:
    :burp:
    Good point!
    Norilsk likes this.
  15. May 30, 2022 at 8:06 PM
    Norilsk
    Eugene
    After they finish and return truck, check and re-torque all the bolts. When Toyota did my rack in Edmonton they forgot to hookup all the wiring to front actuator, zip-tied my P/S lines and were missing other bolts and nuts... :annoyed: I was rushing and going other places, so didn't want to spend more time that I needed to... The service girls were hot, the only reason to visit West Edmonton Mall Toyota... :bowdown:
    19Canuck[QUOTED] and somebody like this.
  16. May 31, 2022 at 2:19 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Anyone gonna do the bj joke?
    somebody[QUOTED] likes this.
  17. May 31, 2022 at 2:44 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    just sucks when service dinks make shit up and screw people out of money.
    So happy you are on here more! It’s been a minute.
    19Canuck and Shveet[QUOTED] like this.
  18. May 31, 2022 at 6:16 AM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    The same reason I took my 8-free services to Collingwood Toyota, reception lady was smokin’ hot. Not hot enough to make me pay dealer prices for oil changes and visual inspections.
    tacoma16[OP] and Norilsk[QUOTED] like this.
  19. May 31, 2022 at 7:14 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks man
    tacoma16[QUOTED][OP] likes this.
  20. May 31, 2022 at 7:27 AM
    Norilsk
    Eugene
    Are you ever going to re-visit no go hole? :D Need to see that chubby leaf pack flex
