Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 9, 2022 at 12:19 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Last week off before I head back to reality :drunk:
  2. Aug 9, 2022 at 12:46 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Huh?
    tgelata likes this.
  3. Aug 9, 2022 at 1:07 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Famous last words :devil:
    MaverickT883[QUOTED] likes this.
  4. Aug 9, 2022 at 1:18 PM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    Sauble Falls? If so, water level is a lot higher than last time I was there
  5. Aug 9, 2022 at 1:29 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Good eye. It’s been raining nonstop for the last 2 days, so it’s up. I’m just up here to drink and relax on the beach for the week (my 19th was yesterday), but I figured I’d go for a little hike today.
    Toms2Yotas[QUOTED] and somebody like this.
  6. Aug 9, 2022 at 2:10 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    @3JOH22A got a question, oh all knowing guru of old.
    where do i start for looking at block heaters for the 3rd gens? I recall there was a recall for one but i might stay the winter up here to see if i can tollerate it
  7. Aug 9, 2022 at 2:18 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I’ve not done one on this Truck but look for one ASAP. My wingers 3rd Gen. unit went out last year & it was a bear for him to find one.
    TeecoTaco likes this.
  8. Aug 9, 2022 at 2:28 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    My truck has a block heater. I think. Never used it.
  9. Aug 10, 2022 at 8:29 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    So I did a bit of digging. The OEM block heater shows $400+ on Toyota's web site. I ordered Philips P/N 3100129. This guy claims it fits 3rd gen, but the manufacturer doesn't include it in its application list. I'll risk it for the price. Install video of similar-looking one on eTrailer:
    Connect the cord to an outdoor timer so it runs 3 hours or so before you start the truck in the morning.
    I plan to splice the power cord together with an onboard battery tender (something like a Schumacher SC1300). Total current draw will be only 5 amps, so it won't even need heavy-gauge wiring.
    Shveet[QUOTED] likes this.
  10. Aug 10, 2022 at 9:29 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    was also doing digging earlier and found the same thing. yeah that "cigarette" style heater goes and clips into the rear of the block under the piston. Was talking to Tyler earlier and he mentioned that Toyota took the mechanics and gaver em a run down as to how to "correctly" install them (ADD THERMAL GREASE) to avoid them burning up and setting fire to the truck. Basically the cigarette style heater is just that, a glorified cigarette plug/ glow plug that lets the heat transfer from itself into the block and warms things up.
    However i'll be going with an alternate style. Much like what Honda/ Subaru does. Basically these hook up to your radiator and warm up the Coolant, which in turn heats up the engine (through the coolant ports).
    there is another style i just started to look at and it goes in-line with the coolant hose and basically warms up through there.
    IMO the cigarette style that Toyota has is kinda meh, since it only clips in, what exactly is stopping water and dirt from getting in while offroading. Better questions is what stops if from dislodging it from where it sits from the vibrations?
  11. Aug 11, 2022 at 3:40 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    if you put a 2" wheel spacer on a truck when turning dose that bring the wheel closer to the firewall/wheel well 2"? dose it work like that?
  12. Aug 11, 2022 at 4:46 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    That is my understanding
  13. Aug 11, 2022 at 6:11 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The hole in the block is apparently nestled in the water jacket, so the cartridge heater is heating the coolant too, but without an extra leak path. Yeah I'd lather it in antiseize to improve heat transfer and reduce corrosion.
  14. Aug 11, 2022 at 6:38 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Will be less than 2 lost toward the firewall.
    At 0 deg trun the diff is 0"
    At 90 deg turn the diff is 2" (not possible but exploring the limits, caster will add some but minimal. )
    At 45 deg turn will be about 0.7*2" = 1.4
    The amount extra the tire will move back will approximately be sin(steering angle) * spacer size. Would still add a few 16th for castor.
    3JOH22A likes this.
  15. Aug 11, 2022 at 8:56 AM
    Windigo
    Farook
    '14 Acess Cab
    thanks that make sense ...
    somebody[QUOTED] likes this.
  16. Aug 11, 2022 at 9:21 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    So square root of half pi at full steering lock?
  17. Aug 11, 2022 at 9:25 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Full Lock turning outward is 38.8deg??
    3JOH22A[QUOTED] likes this.
  18. Aug 11, 2022 at 10:52 AM
    Windigo
    Farook
    '14 Acess Cab
    Shveet, Tridet167, ODSC1 and 2 others like this.
  19. Aug 12, 2022 at 9:52 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Anyone got a good guess how long pencil lake trail takes from 507 to 118? might add it as a detour on my way through the area
  20. Aug 12, 2022 at 10:10 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    For what it's worth I have the factory one and it stopped working after a year or two. Haven't had the recall for it though
