Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 22, 2022 at 3:22 PM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    @oostroma part time CSI
  2. Aug 22, 2022 at 3:53 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Jeez. You’re right. That’s some impressive csi work there.
  3. Aug 22, 2022 at 4:57 PM
    RoamingGnome
    RoamingGnome Well-Known Member
    Gerry
    Ontario, Canada
    2017 Tacoma TRD OffRoad
    Mostly stock for now...
    There is a lesson for everyone - when dealing with "socket head" cap screws put the damn Princess Awfull ball head Allen Key sockets back in the toolbox until you have cracked the cap screw loose - when the ball breaks off it's already turned/stripped the internal hex of the cap screw and it ain't ever coming out - at least if you break a straight allen key socket the little chunk will come back out - even if it breaks off almost flush
    - And if the cap screw seems really stubborn - give it a firm whack with a hammer and pin punch right in the centre of the bolt / cap screw - it will usually shock the rust / corrosion and let the bolt know who's boss...
  4. Aug 22, 2022 at 5:10 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    To add
    If its already stripped SOMETIMES you can get lucky smashing a slightly larger torx bit in
    Zephranthes and tacoma16[OP] like this.
  5. Aug 22, 2022 at 6:16 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    If you have a friend with a welder you can get those out. Just get some new hardware afterwards.
    MaverickT883[QUOTED] and 3JOH22A like this.
  6. Aug 22, 2022 at 6:18 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Looking into an alternator since my voltage regulator seems to be going out (bolts aren’t steady, constantly changing). Any reputable aftermarket brands from rock auto to look at? Planning to upgrade to the 130amp tow package one while I am at it.
    Windigo likes this.
  7. Aug 22, 2022 at 6:20 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    there is an alternator and starter re builder around hear but there all over the place. I'd just take them your old one and tell them you want more amperage and they will rebuild it with more amps
    tacoma16[QUOTED][OP] likes this.
  8. Aug 22, 2022 at 6:22 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    That’s an idea. I was just going to go for the tow package one at 130amps. Stock replacement kinda deal. I just have the 100amo standard. Will require changing to the 140amp fuse too.
    rock auto is looking under $250ish for a new 130amp alternator. Rebuilds cheaper?
  9. Aug 22, 2022 at 6:27 PM
    Windigo
    Farook
    '14 Acess Cab
    Phone: (416) 438-0510
    Scarbrouogh starters.
    I'm last time I was there, years ago any alternator rebuild was $120. if i remember correctly they up the ampreage on my 4runner one for 150. give em a call and see. good luck with it.
    3JOH22A and tacoma16[OP] like this.
  10. Aug 22, 2022 at 6:29 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Thanks! Appreciate it!
  11. Aug 22, 2022 at 6:33 PM
    zuknewbie
    zuknewbie Well-Known Member
    2018 white off-road dcsb
    Try these guys out, been around forever and close to you.
    tacoma16[QUOTED][OP] and Windigo like this.
  12. Aug 22, 2022 at 6:34 PM
    Windigo
    Farook
    '14 Acess Cab
    it closer :thumbsup:
  13. Aug 22, 2022 at 6:36 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    thanks guys
    :cheers:
  14. Aug 23, 2022 at 8:52 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
  15. Aug 23, 2022 at 8:56 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Shveet and FastEddy59 like this.
  16. Aug 23, 2022 at 9:09 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Do you even use brakes?
    Shveet, Zephranthes, Norilsk and 2 others like this.
  17. Aug 23, 2022 at 9:24 AM
    Windigo
    Farook
    '14 Acess Cab
    That's funny
  18. Aug 23, 2022 at 9:31 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  19. Aug 23, 2022 at 10:33 AM
    Windigo
    Farook
    '14 Acess Cab
    jordi992 and Shveet like this.
  20. Aug 23, 2022 at 11:04 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Not impressed rn. :mad: Parts were out for delivery yesterday but looks like they caught a flight to Dallas TX. Hope they bumped ‘em up to first class.
    Norilsk[QUOTED] and Toms2Yotas like this.
