Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Sep 6, 2022 at 10:02 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Canadian Joe likes this.
  2. Sep 6, 2022 at 10:53 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    :boink:
    I'M NOT DONE TRYING TO MESS AROUND WITH THE 2K SETTINGS. IDK why but it refuses to actually stick. the 1080p version looks like hot garbage
    also don't mind the music, i just grabbed a 2.5hr eurobeat mega mix and threw it in there so it's better than silence for 3 hours.
    if you dont want to suffer for 3 hours, i recommend the 12 minute version:
    https://www.youtube.com/watch?v=GGuRsYrgyJQ
    TunedUpTaco, RoamingGnome and Snail81 like this.
  3. Sep 7, 2022 at 4:14 AM
    Windigo
    Farook
    '14 Acess Cab
    It's all good man. Thanks for taking the time to share. share.
    Shveet likes this.
  4. Sep 7, 2022 at 4:48 AM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    Looking to replace the incandescent H4 bulb in my bike with an LED H4. Anybody have a LED bulb success story, or preferred brand?
    My bike pops bulbs like tic-tacs, not sure if its caused by over-voltage or vibration, but hoping an LED is more durable than an incandescent filament.
    Ps. Really happy I blew my headlight 10m rather than 10km from home at 530am today.
  5. Sep 7, 2022 at 5:29 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    too wide for your 255's
    Shveet[QUOTED] and 3JOH22A like this.
  6. Sep 7, 2022 at 6:16 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Brody is trying to sell this for more than Jeff Bezos does: https://www.amazon.ca/LEVELING-2005-2019-TOYOTA-TACOMA-RUNNER/dp/B083VZ27NV/
    Not that I recommend a strut-top spacer lift at all. It'll destroy the stock upper ball joint and the shock stem if you take it on a level 2-3 trail.
    MaverickT883[QUOTED] likes this.
  7. Sep 7, 2022 at 6:18 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Yeah I figured it’d cause havoc. I’ll probably just go the 5100 route.
    tgelata likes this.
  8. Sep 7, 2022 at 7:15 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Gotta say, Russle Toyota in Peterborough did a great job for me. They took the skidplate off, fixed all the fucked threads, and gave me a rundown of what was broken. He recommended I not take the skidplate off because it will likely strip again (retapped threads aren’t as strong).
    Sloweburn and CaygeonRunner like this.
  9. Sep 7, 2022 at 7:19 AM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    If it was the quick lube place that buggered it up, tell Russell that you want it fixed to OEM spec on their dime.
  10. Sep 7, 2022 at 7:21 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    fixing these threads would be a frame swap as i doubt the dealer will rework the weld nuts that the skid attaches to. I would imagine that would be a tall battle to win from the quick lube place
    Which ones in particular are stripped. IF the middle two, no big deal to access and fix.
  11. Sep 7, 2022 at 7:26 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Every one is stripped besides the 1 back, and one metal one. They showed me pictures. I have no idea how mr lube did that.
  12. Sep 7, 2022 at 7:27 AM
    BussinGus
    Frame swap seems a little excessive, lol! I've never looked close enough, so I don't really know what would be involved. Not enough meat to drill and tap one size up? Probably better off doing it yourself anyway...
  13. Sep 7, 2022 at 7:27 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    I think that would involve a frame shop, and frankly, that’s just not worth the hassle in my opinion. If the taps fail (they look well done), I’ll just weld a nut on. Only so much I can do at the end of the day. Definitely going after them review wise and shit.
    BussinGus[QUOTED] likes this.
  14. Sep 7, 2022 at 7:32 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    From what I understand there’s not enough physical metal to do that.
  15. Sep 7, 2022 at 7:34 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    My comment was out of what the dealer would do if they were to restore to OEM. I dont see the dealer sourcing bolts that can be tapped up a size (the process is likely to break off the welded nuts in the frame. 5 of the 7 nuts are all captive inside frame sections. Unless you had a fab shop cut and chop and weld you are not fixing to OEM. Even then all that cutting and chopping will ruin factory coatings which will result in rust issues down the road.
    If the nuts can be busted off their welds then a nut welded on a backer plate could likely be slid into the frame sections and secured in place with another small nut (some hole drilling in frame required).
  16. Sep 7, 2022 at 8:11 AM
    BussinGus
    OEM spec (or better), not 100% OEM. That would include being able to safely torque to OEM spec and re & re parts a reasonable number of times with reasonable certainty that threads would maintain integrity. I don't think that's asking too much. If the dealer's professional opinion is that the threads are compromised to the point that it should not be removed again, I would not be satisfied with the repair.
    The backing plate with a nut is a good idea. I'm sure there are lots of ways it could be effectively repaired that a dealership would never attempt or endorse. I made a living doing things that gave dealerships and manufacturers nightmares.
  17. Sep 7, 2022 at 8:35 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    You can also thread in a stud, either with red Loctite or weld it on, and install the skid plate with a nut instead of a bolt. It's similar in principle to the fuel tank skid mounting.
    All this to get you by a couple of years until you do the JD Fab LCA pivot kit and go to 37s like @Norilsk and @Windigo :stirthepot:
  18. Sep 7, 2022 at 8:37 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Sloweburn, Shveet and 3JOH22A like this.
  19. Sep 7, 2022 at 8:37 AM
    BussinGus
    That's a great idea. Nylocks on a stud and you're done.
  20. Sep 7, 2022 at 8:39 AM
    BussinGus
    Those are ok until they start spinning. Then they're a pita.
    Shveet likes this.
