Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Sep 19, 2022 at 5:58 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    I’m gonna try this when I get home from class in an hour. If it works I owe you a beer (or soda, if you don’t drink)
    Shveet likes this.
  2. Sep 19, 2022 at 5:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^If it doesn't work, you can also try disconnecting that hose from the evaporator housing. It looks like the hose is just pushed onto the outlet on the evaporator housing with no clamps. See if you can reach it by feel and push forward to remove. Put a drain pan under it to catch water.
    MaverickT883[QUOTED] likes this.
  3. Sep 19, 2022 at 6:02 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    I will be sure to rip every hose under my dash off and then blame you when it doesn’t go back together :anonymous::thumbsup:
    tgelata likes this.
  4. Sep 19, 2022 at 6:25 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    So, @3JOH22A, I ended up taking the whole drain tube off and cleaning it. No change. What I did notice tho is there is definitely water inside of the evaporator housing. As soon as I took the hose off, water came out when I turned the fan on, and like, quite a bit. Which is… normal. I think. I’m so confused on this one. Drain tube isn’t clogged at all, like I can see straight thru it when I took it off and held it straight.
  5. Sep 19, 2022 at 7:52 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Does the drippage occur in the footwell when you have the A/C on, or when you go through a rain storm or car wash?
  6. Sep 19, 2022 at 7:54 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Only A/C on. I’ve tested everything I can basically lol. It’s going to the stealership Wednesday. Pray for me lol.
  7. Sep 19, 2022 at 8:02 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^When they bend you over and tell you to bite the headrest, insist on only genuine Toyota P/N 08887-01206 :thumbsup:
    BussinGus likes this.
  8. Sep 19, 2022 at 9:15 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Then all of the above
  9. Sep 19, 2022 at 9:22 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    :rofl::rofl: They’ve been good to me so far. They fixed my skidplate for just cost of parts (waived labour charge). If they keep being honest and find and fix the issue within reason I’ll have no problem returning.
    BussinGus, 3JOH22A[QUOTED] and Shveet like this.
  10. Sep 19, 2022 at 9:22 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Yup. Gorgeous in all directions but those skeeters are fucking killer, never seen swarms as large as these before. Heck I never used a bug outfit before but skeeters are the least of your worries up here.
    There are these littler bastards called "no-see-ums"
    https://en.m.wikipedia.org/wiki/Ceratopogonidae
    Grain of sand is larger then them and thet bite. Hard.
    Will get through traditional skeeter mesh...
  11. Sep 19, 2022 at 2:52 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    no-see-ums are otherwise known as knats or midges,
    lol yeah annoying, but you ain't seen nothing yet!
    The "good" bug netting will keep those buggers out.
    Baking Soda mixed with Witch Hazel,
    put the paste on the bites and it will sooth the bites from those things.
    Same for black fly bites...
    Being a smoker helps as bugs don't like the smoke, but up there does not do much good.
    As you've seen, unprotected areas of skin turn into a bug carpet in seconds.
    Oh you have not lived up there until you've been through a black fly season...
    It's like god took the most evil traits from skeeters and midges and used that for the black fly design.
    And they don't just swarm near wet areas...
    You think the skeeter swarms are amazing....Lol wait for the black fly.
    I've heard of and seen animals and people go crazy from those things,
    and according to the wiki on the them;
    Black flies are a scourge to livestock in Canada, causing weight loss in cattle and sometimes death.
    https://en.wikipedia.org/wiki/Black_fly
    Lol look at the pic on the Wiki... If you get a bunch of people standing in a circle the cloud will get so thick it becomes tough to see people 10' away.
    You won't be able to tell who it is you are talking too.
    You will question your sanity in black fly season. Lol
    Shveet[QUOTED] and BussinGus like this.
  12. Sep 19, 2022 at 3:03 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Yep that's where the evaporator coils are...
    That area should not be cold enough on the outside to cause a lot of condensation.
    Tiny bit is normal if it is a really humid day.
    A lot of water coming out of the drain tube on a humid day is normal.
    It's possible that your evaporator is freezing up.
    That can be cause by lack of air flow (water on the outside of the housing points to that too IF it happens quickly)
    If you are low on R134 (or whatever they are using now) it can also cause the evaporator to freeze up.
    So if the outside condensate happens fast, look for air flow blockages first. (blocked filter, leaves or a mouse in your air box area) or listen if the flaps are moving when you change from AC to heating.
    If it takes over half an hour for the condensate on the outside and your cooling seems weaker or less air flow, look at the amount of refrigerant in your system. (after you confirmed good airflow)
    If after you are driving for a while and it sounds like your blower fan is under water, or you see water on the floor after you turn left.... you still have a drain blockage. Possibly on the port in the tray where the hose connects to.
    LandoFernano, 3JOH22A and BussinGus like this.
  13. Sep 19, 2022 at 3:53 PM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    19 Tacoma TRD Sport Premium
    3" lift. $10K in TRD options. Richie's semi-hidden bumper, and soon his Elka suspension
    My daughter's corolla had a butyl blockage over drain hose hole, so basically the unit was sealed and wouldn't drain.
    once I punctured the seal and got it opened up, almost 4 litres of water came out of the HVAC!
    She bought the car brand new in 2013 and it started pissing all over the floor just last year.
    daks and TeecoTaco like this.
  14. Sep 19, 2022 at 3:54 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Fvcking Butyl
  15. Sep 19, 2022 at 4:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The KTJO4x4 grab handle V2-PKTCMGRAB-C0 came in. Ordered Friday night, shipped out Monday afternoon. All parts accounted for and no cosmetic damage. Unfortunately it shipped via UPS instead of FedEx this time, and brokerage fees were significantly higher. Wonder if I'm the first in Canuckistan with the V2 grab handle?
    With V2, the lower fastener changed from an M6 clip nut to a tiny M3 (?) rivnut, and KTJO4x4 includes a ratcheting cinch gun. The screw seemed too small, so I left the old clip nut in place and used the M6 grab handle screw from my previous 2nd gen, P/N 90159-A0047.
    AL9nZEX14GEr4kKpe0U0LyfVDcJk0On8bTkz9T4Q_3613c43e4f1ef81381fbf175590bb30d71eb0c95.jpg AL9nZEUOv_Hp5maK83S6Ge7Y9-L8AWLnFQnUHa-m_c9f8750f5b96dfa190b2c53f1128105d30e6ae95.jpg
    Installation with the deep-set bosses and short screws is indeed easier than V1. I found a shallow 10mm socket with 3" long 1/4" drive extension was handy for the lower screw. Fitment of the screw covers is flush and tighter than V1.
    AL9nZEV9TfI8P2zb-gQ0uQc5OiMDNA_VnUxhgSyL_4767e5505eb7cb6b46a6cd4e5236b5030501ee5d.jpg AL9nZEW9koO_qpxgSEwTeSbtCIxwDGCIwVqqZhaB_3806420faace2dae4503e5c20f9cc5cbc85fe199.jpg
    Snail81, Sloweburn and daks like this.
  16. Sep 19, 2022 at 4:25 PM
    TeecoTaco
    SW Ontario
    Old pic I know, but I been focusing on Hummingbirds and assorted wildlife lately
    Oil change, full synthetic, Krowned 3 days ago and tucked away for the winter...goes by so fast
  17. Sep 19, 2022 at 5:00 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Did you have the V1 in your truck before?
    How is the colour matching?
    Dealt with a lot of appearance parts, years ago so I have those "Quality Eyes" . stupid things get me twitching like I have OCD. Lol
    Hey that steering wheel is looking a wee different than stock... whatcha got going on there?
  18. Sep 20, 2022 at 5:47 AM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Shveet[QUOTED] likes this.
  19. Sep 20, 2022 at 8:42 AM
    Pure_Life
    Pure_Life Well-Known Member
    Ghanim
    Hi fellas, I have a GRAV Bubbler and Cali Crusher Grinder that I want to sell. They weren't used a lot. I figured I would throw it out here and see if anyone is interested
    $30 for the Bubbler
    $60 for the Grinder
  20. Sep 20, 2022 at 8:58 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Did you notice the photography wizardry in that shot though?
    Shows that we have the right person designated as the photographer....
    Oh yeah, the wizard stuff.
    Notice he put the shaver really close to the camera in depth to that shot?
    He did that so we think he needs a HUGE trimmer for his junk.
    Manfred[QUOTED] and Shveet like this.
