Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Dec 6, 2022 at 8:33 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Made my own when I had my 2nd and 3 rd gen Cummins. I rally don't see why you would need one on a gas truck. But hey it would look pretty cool.
    Shveet[QUOTED] likes this.
  2. Dec 6, 2022 at 9:10 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The ATF thermostat was added for the 3rd gen. It's next to the trans pan, below the ATF-coolant heat exchanger (also added for 3rd gen)
    ontarioyota likes this.
  3. Dec 6, 2022 at 9:10 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Living up North you learn to pay attention to "little details".
    Like if you are parked with the front facing towards the prevailing winds, cover your grill so the snow drift does not end up under your hood.
    Longjohns are your best friend.
    If you are in an area that hits -40 and below, a battery jump pack kept inside the house is a good idea.
    Scrape off the ice on your side windows and seals before you operate the power windows.
    Wax/lubricate the top and side window seals so ice does not freeze the window to the top seals. Or the door closed.
    Spray light lithium grease (not wd40) into your door keyhole, door latches, hood and tailgate latches.
    Don't park in standing water if you are expecting it to freeze up overnight.
    Mold release, Silicone Spray or even in a pinch PAM sprayed all inside your wheel wells will stop or make removal of that frozen brown ice easier.
    Keep snow off the bottom of your door sill, otherwise it melts from the cabin heat then freezes the door closed after you let it sit for a while.
    Keep a set of heavy Snow pants and heavy mitts (not gloves) in your truck at all times.
    The ice is safe to go on 2 weeks after the tourists stop falling through.
  4. Dec 6, 2022 at 9:12 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    added then removed for the later part of the 3rd gen. Every buck saved....
    Shveet likes this.
  5. Dec 6, 2022 at 9:14 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The liquid-liquid heat exchanger was kept. The little aux ATF cooler in front of the rad was deleted mid-2020.
    Yes, every buck saved is 34 million yen in Akio's pockets, before all the supply chain disruptions anyway.
    ontarioyota and Shveet like this.
  6. Dec 6, 2022 at 11:56 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I sprayed fluid film into the door hinges and keyholes. How fucked am i?
    ontarioyota and TeecoTaco like this.
  7. Dec 6, 2022 at 11:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Should be OK if you use power locks and not use the keyholes :homer:
    Keyholes should get a thinner fluid like Teflon lube (same stuff you'd use on the coilover uniballs)
  8. Dec 6, 2022 at 12:42 PM
    Windigo
    Farook
    '14 Acess Cab
    Project "rack ov'r tonneau" slowly comming along.
    TunedUpTaco, ontarioyota and Shveet like this.
  9. Dec 6, 2022 at 1:17 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I'm interested in how this will turn out :D
    Using round tube for the cross bars or square?
  10. Dec 6, 2022 at 1:21 PM
    Windigo
    Farook
    '14 Acess Cab
    I'm also intersted in how this will turn out. I don't even have a plan. lol. making it up as I go along.
    I'd like to use round tubing.
    Shveet likes this.
  11. Dec 6, 2022 at 1:40 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    For door locks, bike chains & anything you don’t want dirt to stick to like WD-40, this stuff IS the bomb.
  12. Dec 6, 2022 at 3:51 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Ya, see...all that is liquid. I'm reluctant to put liquid lubricant in to tumbler locks. Liquid assembles dirt and grime. I'm more inclined to use a graphite powder lube al la https://www.lowes.ca/product/lubricants/3g-graphite-powdered-lubricant-34006
    Don't know what it does for sub freezing conditions however
    If your dusty trail riding, you don't want oil based lube in locks
  13. Dec 6, 2022 at 5:05 PM
    FastEddy59
    Eddie
    No doubt graphite is the best but it was somehow hangin’ on to the keys making my pockets black. Couldn’t figure it out for the longest time.
    TeecoTaco[QUOTED] and Shveet like this.
  14. Dec 6, 2022 at 5:33 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The teflon spray is actually a dry lube. The carrier fluid evaporates after a few minutes, leaving behind a teflon film. It's also easier to apply than powder in a toothpaste tube. I use it in my 5 locks (door, tailgate, tonneau, fuel cap, spare tire) with good results. The spare tire lock gets dragged through mud a few times each year.
  15. Dec 6, 2022 at 5:46 PM
    FastEddy59
    Eddie
    Sometimes nothin’ helps :frusty:
    daks, TeecoTaco and Shveet like this.
  16. Dec 6, 2022 at 5:52 PM
    TeecoTaco
    SW Ontario
    What do you use on a bouncing cooler?
    Heat up the key with a Bic lighter...stoner
    Shveet and 3JOH22A[QUOTED] like this.
  17. Dec 6, 2022 at 5:54 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    ah yes, the it's-so-cold-the-door-itself-is-frozen season :rolleyes:
  18. Dec 6, 2022 at 5:55 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    what do you use on a bouncing cooler?
    Strap it's ass down with a winch, god damnit
    Early in the mornin
    :drunk:
    TeecoTaco[QUOTED] likes this.
  19. Dec 6, 2022 at 6:01 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I used a few empty Plano cases as space filler. Had fun explaining that to the squad of CBSA agents searching my vehicle lol.
    Not enough heroin experience to think about the Bic lighter. Thanks :thumbsup:
  20. Dec 6, 2022 at 7:00 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Full G test is on Monday, slightly nervous
    TunedUpTaco and Shveet like this.
