Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 11, 2023 at 11:14 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
  2. Aug 11, 2023 at 11:15 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    TunedUpTaco, Shveet and 3JOH22A like this.
  3. Aug 11, 2023 at 5:27 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    5 bones
  4. Aug 11, 2023 at 5:54 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    3JOH22A likes this.
  5. Aug 12, 2023 at 2:24 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Tested out 911 Motorsports jack extension accessories. These have a 1.5" bore and fit a turd gen 4Runner OEM jack without modification:
    AIL4fc9xxwUkbx0YNUZgqIxj7xefpnZ9EVzxFkwt_98990bca8fc637b2aae007febb729e39e25ecb5e.jpg AIL4fc8xiCouda-UskkHRLLTPEWecqvQScWKI-RW_e586335e7ca4f1d36ace2f6bed86b5cf76209d39.jpg
    The saddle has cutouts to fit frame rails and round tubes (like sliders). To spread the ground pressure, I'm also using a Reese hi-lift jack base with a few diagonal cuts in the locator ring:
    AIL4fc96BCsMC_nIWarwRSvVqNdY7KuzTx0Es_1X_a86b13f9364120c81055d7426c1d59080643b4ab.jpg AIL4fc9DN9mT-o86IrfFj6yKHLUfoC2h9e3wsCk3_d3a234c5f8265d582a8323b6d3c9f826eca85305.jpg
    The turd gen 4Runner OEM jack has a 3500 lb capacity, 500 lb more than the turd gen Tacoma OEM jack. Only thing to watch for: since the jack's swivel plate is wider than the ram, the 911 extension tube can tilt. You need to position the jack so the extension tube remains aligned with the ram.
    Bill of materials:
    Toyota P/N 09111-60075 jack: https://www.ebay.ca/sch/i.html?_from=R40&_nkw=09111-60075&_sacat=0&_sop=15
    Reese Bulldog P/N 7048400 jack foot: https://www.amazon.ca/gp/product/B011PGV3DU/
    Curt P/N 28272 flat jack pad: https://partsavatar.ca/curt-manufacturing-jack-foot-28272
    911 Motorsports P/Ns JE-P -031Z (saddle) -041Z (6" extension) -042Z (11" extension): https://www.911motorsports.net/Replacement-parts--for-Jack-Extension_p_79.html
    TunedUpTaco and Shveet like this.
  6. Aug 12, 2023 at 4:12 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    That jack is going to look weird mounted outside on your soon-to-probably-be steel rear bumper + swingout for the 4R...
  7. Aug 12, 2023 at 5:02 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Ha! It's for the Taco. And the whole point is to keep it lightweight and mounted in the stock location.
    Shveet[QUOTED] likes this.
  8. Aug 12, 2023 at 7:14 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
  9. Aug 12, 2023 at 7:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^These refills are $15 each at the dealer parts counter!
  10. Aug 12, 2023 at 7:57 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Yeah... But they perform well and it's the first time I've changed them in 3 years and potentially since the truck was new
  11. Aug 12, 2023 at 8:09 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Anyone have recommendations for a cheap bottle jack that won’t kill me? My OEM Tacoma one just gave up the ghost.
    Shveet likes this.
  12. Aug 12, 2023 at 9:53 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^What broke on the OEM Tacoma jack?
    Shveet likes this.
  13. Aug 13, 2023 at 5:57 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Send it to TRD and maybe they'll upgrade the next gen one?
    I mean they did it with the perfectly roasted marshmallow Tundra
  14. Aug 13, 2023 at 6:44 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    The mechanism to make it go up :bananadead: not sure what specifically
  15. Aug 13, 2023 at 8:16 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    A jack needs to be short enough to fit under the axle with a flat tire, yet be able to extend long enough to jack up the frame and get a front tire off the ground. Most hydraulic bottle jacks sold in local stores don't have that kind of travel range. I see two-stage bottle jacks sold online which may work well: https://www.amazon.ca/Torin-ATH80402XB-Double-Welded-Capacity/dp/B09Z37N3BS/
    Before you order, I suggest fully deflating a rear tire and measuring the clearance under the axle, to make sure a 6.7" tall jack would fit.
    TunedUpTaco likes this.
  16. Aug 14, 2023 at 9:35 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Ruh roh. Passenger rear brake looks like something exploded? Brake line seems fine, coming from that wheel only. No brakes.
    honkonbobo and Shveet like this.
  17. Aug 14, 2023 at 9:38 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Wheel cylinder likely. Coincidence with the work that was just done, likely (although they did take off your front end for seemingly no reason).
    Shveet likes this.
  18. Aug 14, 2023 at 9:47 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    need a pair of vice grips? just pinch off that side till you get home
  19. Aug 14, 2023 at 9:56 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    be sure to hit the car wash asap. dont leave brake fluid in contact with any painted surfaces for any length of time.
    Shveet and TeecoTaco like this.
  20. Aug 14, 2023 at 10:01 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Do you carry a spare cylinder like I do? :anonymous:
    Canadian Joe, Windigo and TeecoTaco like this.
