Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Oct 16, 2023 at 8:37 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Snail81 likes this.
  2. Oct 16, 2023 at 11:46 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Windigo likes this.
  3. Oct 16, 2023 at 12:24 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Are you sure the flange bent? Or did the flange nuts take a few hits and loosen? Traditionally that's not a weak area, because the flange is fairly thick.
    The Solo skid is nice because it also protects the pinion seal area. It's easy to bend the dust shield there and make noise. Happened to me in 2020. However, the rear skid attachment stabs into the rear housing at a 90 deg angle. Traditionally, the rear housing is thin sheetmetal and can be punctured, so companies sell a weld-on piece over just the rear cover:
    Turd gen OR has a bigger diff, so this one is more appropriate: https://rcimetalworks.com/product/rear-differential-skid-plate-16-23-tacoma-trd-offroad-pro/
    The RCI skid's left clamp can dig into the fuel tank at full flex. You can even see it on their photo. And it doesn't protect the pinion flange.
  4. Oct 16, 2023 at 2:48 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    1. Ask question
    2. Ignore all answers
    3. Wait for the correct answer from Dax
    Canadian Joe and tgelata like this.
  5. Oct 16, 2023 at 2:52 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    Don't forgot you'll also be loosing like an inch of ground clearance.
  6. Oct 16, 2023 at 2:54 PM
    Windigo
    Farook
    '14 Acess Cab
    yes absolutly realized this but one big hit to the pumpkin or pinion could mean trouble also my diff bottom is so messed up I'm wondering if i can get the drain plug off... should of did a diff skid 2 years ago..
    Tridet167 likes this.
  7. Oct 16, 2023 at 3:02 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    just need bigger tires to keep it away from the rocks, think 40s is a good start...
  8. Oct 16, 2023 at 3:12 PM
    Windigo
    Farook
    '14 Acess Cab
    I'm with you brother, but I cant steer as it is. hahaha.
    Tridet167 and Norilsk[QUOTED] like this.
  9. Oct 16, 2023 at 4:17 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    1. Weld on the Trail-Gear rear housing armor.
    2. Modify the Solo skid mount to fit.
    3. Do a reverse credit default swap with your leveraged derivative holdings.
    4. Profit
    Or just stop hitting your pumpkins. I know Oct. 31 is just around the corner and all :pumpkin:
  10. Oct 16, 2023 at 4:35 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I had to use a die grinder to grind out around the bolt to get the metal out of the way to get a socket on the nut.
    Windigo[QUOTED] likes this.
  11. Oct 16, 2023 at 5:14 PM
    Windigo
    Farook
    '14 Acess Cab
    Not a bad idea
    Thanks for the tip.
  12. Oct 16, 2023 at 7:56 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Yeah it would be more efficient if we just consumed his consciousness into a chatbot that we could use at all hours to answer our stupid questions
    Norilsk likes this.
  13. Oct 16, 2023 at 8:05 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I'm not entirely convinced he isn't AI
    Norilsk likes this.
  14. Oct 16, 2023 at 8:06 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Has anyone ever actually seen him outside of a TW meetup?
    @Norilsk Did you create an AI companion to ask Tacoma shit?
    Norilsk and Windigo like this.
  15. Oct 16, 2023 at 8:50 PM
    Windigo
    Farook
    '14 Acess Cab
    Humans will always be better than AI
    Id like to see an AI use a vacuum or
    Play chess or paint a car or guess what your thinking or dance or do math or be a dog . :angrygirl:oh -oh
    Norilsk and Canadian Joe like this.
  16. Oct 17, 2023 at 8:37 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  17. Oct 17, 2023 at 9:36 AM
    Windigo
    Farook
    '14 Acess Cab
  18. Oct 17, 2023 at 10:31 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Especially the wood from your neighbour @Windigo...
  19. Oct 17, 2023 at 10:35 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    wait, our crazy Lambo Dax? Yeah i seen him a few times out and about lol
  20. Oct 17, 2023 at 10:41 AM
    Windigo
    Farook
    '14 Acess Cab
    yes my neighbours wood, not even humans can chop that, its robots only wood.
    Snail81[QUOTED] likes this.
