Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Dec 21, 2023 at 1:55 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    20 a tire generally. If you order thru a tire shop they throw you a bone on the install/balance usually.
    Shveet and 3JOH22A[QUOTED] like this.
  2. Dec 21, 2023 at 2:10 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Yeah 1010tires is a shop with 2-post lift and tire machines. Mount and balance was free when I bought Subaru wheels and tires there many years ago
  3. Dec 21, 2023 at 5:34 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    That's for 4. OP quoted 5. 5 would be $2140 after tax for just the tires
    3JOH22A[QUOTED] likes this.
  4. Dec 22, 2023 at 9:47 AM
    Days_last
    Days_last Active Member
    '08 4.0 DCLB
    What's up yall,
    I'd like to put some molle pannels in my bed and thought I should consult the oracles and their infinite and mysticle wisdom.
    '08 long boy. Mainly just want the 2 sides, not too concerned with the cab side wall. Saw the rough country kit on Amazon for about 200, seems like a decent price, but definitely open to any cheaper/diy options. Will likely end up cutting out a piece so I can still run 2x6s across the bed to load sheets of plywood and drywall.
    Main things I'll be securing are a shovel, snow brush, first aid kit, Jerrycan (sometimes), hatchet, and a hi lift once I get some sliders on.
    Any opinions, builds, or experience is welcome, as well as any outside of the box ideas. (Or if there's anyone letting there's go:fingerscrossed:)
    Ps, bought a signal booster the other day. Anyone with experience or advice on install would be much appreciated. (Particularly where to mount antenna)
  5. Dec 22, 2023 at 10:31 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I have RA Motorsports full length side molle panels. They're more expensive than the RC but I think also longer and there are other sizes as well.
    Days_last[QUOTED] likes this.
  6. Dec 22, 2023 at 10:40 AM
    Days_last
    '08 4.0 DCLB
    So those only mount in the rails? Id imagine because they're short height wise they still stay rigid with nothing securing the bottom right? I also have a cap and 4 cleats in that rail, do you think it would interfere?
  7. Dec 22, 2023 at 11:12 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I have a softopper with 4 clamps :)
    I'm not going to say it's rock solid, but I've had shovels and whatnot without anything being unstable. I'm not sure if it would be ok with a hi-lift jack on it but I'm not sure you'd need a hi-lift to begin with. You could easily put some kind of spacer at the bottom to push against the sides if necessary. I'll admit I don't have much on them, though.
  8. Dec 22, 2023 at 4:56 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I'm not sure I've seen anyone go over the underside.
    Sloweburn, Shveet and 3JOH22A like this.
  9. Dec 22, 2023 at 9:44 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Things included when you spend $$$$$ for a Limited non-hybrid in the US:
    Temporary donut spare with 18x4.5" steelie
    "Low-angle" CV axles
    Aluminum driveshaft
    Aluminum front diff torque tube
    "Hairy cardboard" front splash guard
    A-Trac that engages automatically without a switch
    Since Limited is hybrid-only in Canada, some of these things may change when we see it in April. But it's like Toyota went out of its way to limit the off-road capabilities of the Limited.
  10. Dec 23, 2023 at 5:56 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    If the tnga tundra is an indication it also has a chance at having 2 different CV lengths.[/QUOTE]
  11. Dec 23, 2023 at 6:15 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    No one buys a limited to off-road with.
    Shveet likes this.
  12. Dec 23, 2023 at 6:20 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    @somebody you just stuck "limited" badges on your sport truck, right? or am i thinking someone else?
  13. Dec 23, 2023 at 6:47 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Saturnine,3JOH22A: I like how you guys put the pic of your truck at the bottom. I'm going to copy you. thanks
    3JOH22A likes this.
  14. Dec 23, 2023 at 6:59 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    no no no, thats def not me. I am not a re-badger.
  15. Dec 23, 2023 at 7:01 AM
    Windigo
    Farook
    '14 Acess Cab
    I just used what I had on hand for now seems to be working,
    Sloweburn and 3JOH22A like this.
  16. Dec 23, 2023 at 7:05 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    You're correct. According to Google Maps, these two Limiteds are just cruising on Hydro Road S, Whitestone, ON P0A1G0
    Next you're gonna tell me no one buys a Lexus to off-road with :cookiemonster:
    Windigo likes this.
  17. Dec 23, 2023 at 7:28 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I'm not saying they can't, I'm saying that that's not the desired outcome. It's like buying white shoes to mow the lawn; that's not the initial intent but it might end up happening.
    Windigo likes this.
  18. Dec 23, 2023 at 8:27 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Yet people buy white golf shoes and football shoes all the time :cookiemonster: Anyway, it's possible some of the aluminum parts will be replaced with steel in the hybrid Limited models, to cope with the higher torque.
    Looks like there's a steel bracket that can be unbolted from the cab mount to increase clearance. The truck shown in TFL's video is on 32s. Might be able to fit 35s without a CMC:
    Sloweburn and somebody like this.
  19. Dec 23, 2023 at 2:08 PM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    With a smaller tank and (from the video) worse milage than I get in my 19 it's already down about 100km in range (500km vs 600km total), those big meats will have you stopping for fuel often.
    Curious how the turbo 4 does for trail/slow backroad economy.
    https://youtu.be/XIsYNm5GW50?si=7naIPBxVcztFUhec
  20. Dec 23, 2023 at 2:36 PM
    Windigo
    Farook
    '14 Acess Cab
