Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Dec 14, 2024 at 5:28 AM
    blackgen2tacoma
    blackgen2tacoma Well-Known Member
    Andrew
    2013 black Tacoma limited
    @tacoma16 could I grab my shirts today if you stopping in Milton. I can meet you whenever. Thanks.
  2. Dec 14, 2024 at 5:40 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Dec 14, 2024 at 5:50 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    that starter is OEM and came off my 2013 after this...
    took it off (which is fork in the eye level fun), took it apart and cleaned it out (commutator and brushes are fine), but it still needs either some new soleniod contacts or just take some sand paper to the surfaces of the contacts so the plunger makes a solid connection.
    that starter should work fine for you. just like CVs, you are usually better off to keep rebuilding the OEM vs getting a cheap replacement. the solenoid contacts are super cheap and easy to get as they are somewhat generic.
  4. Dec 14, 2024 at 8:12 AM
    jordi992
    jordi992 Skidplates reduce clearance
    Jordan
    Burlington, ON
    Red truck
    Light bars, no lockers
    Im not looking forward to removing the starter.
    The car seems to always start by the 3rd try so its fine to get me around town for a week or so.
    The strange thing is i don't think my starter was actually under water. And it started fine probably 10 times after the incident. it wasn't until the engine got all dry in the garage before i had issues.
  5. Dec 14, 2024 at 8:33 AM
    jordi992
    Jordan
    Burlington, ON
    Red truck
    Windigo likes this.
  6. Dec 14, 2024 at 9:40 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Sloweburn likes this.
  7. Dec 14, 2024 at 9:41 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    19Canuck likes this.
  8. Dec 14, 2024 at 10:29 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    I don't know if it will matter. When I needed a starter I went to "starters and alternators" and the guy just picked the one that looked the closest to mine and said " it's a little bigger but should work"
    Talk about a tight fit but it's still kicking years later.
    jordi992[QUOTED] likes this.
  9. Dec 14, 2024 at 11:15 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    tacoma16[OP] likes this.
  10. Dec 14, 2024 at 1:41 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Hey. Just seeing this. I didn’t bring them with me today. Been on the road since 7am.
  11. Dec 14, 2024 at 1:43 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I think I am meeting @jordi992 on Monday but I @jordi992 i am seeing @Saturnine tomorrow. Not sure if you guys want to coordinate something.
  12. Dec 15, 2024 at 4:29 AM
    TunedUpTaco
    TunedUpTaco Well-Known Member
    Rob
    Dundas, Ontario
    2017 Tacoma TRD OffRoad - DCSB - Auto - Stock(ish)
    I'm putting these honkers on the truck, one on the other side as well. I'd like to put a (wireless) switch panel in the truck to control them and any other future lights/attributes.
    Any recommendations for this?
    Also, I'm thinking about putting in a separate fusebox for all additional stuff so that I don't mess with existing wiring - does that make sense?
    I've seen some of the setups here, but there are so many options, I'm not sure where to start.
    Windigo and tacoma16[OP] like this.
  13. Dec 15, 2024 at 4:35 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    not sure about the wireless switches but the aux beam or switch pro stuff is a good all in unit with fuses and switches ready to go. As someone who has reworked their wiring a bunch of times it’s the easiest.
    https://a.co/d/fC7fkPk
    I have always been weary of those systems because it has a mother board that I worry will corrode or have issues. Because of that I use blue sea marine grade stuff. Downfall to it is it’s bulky, has lots more wiring, and won’t be as clean as the setup posted. Many have been using the aux beam style for a while without issue.
    TunedUpTaco[QUOTED] likes this.
  14. Dec 15, 2024 at 4:38 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  15. Dec 15, 2024 at 5:11 AM
    Windigo
    Farook
    '14 Acess Cab
  16. Dec 15, 2024 at 10:01 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^So the 5.7L also needs a manifold air injection system to remain smog compliant. Those valves near the firewall look more interesting to replace than the 4.0L's...
  17. Dec 15, 2024 at 10:03 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    @Shveet has a pretty sweet wiring setup, ditchlights too. He may be able to provide some recommendations.
  18. Dec 15, 2024 at 10:30 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I can’t believe you guys don’t get the Shake Down with ditch lights.
    Removed mine when a Cop moved in at the end of the block & tagged me for an extension cord @-40. I’m putting them back on now but really holding my breath. These are pretty inconspicuous but it’s like a magnet around here for ditchers.
    TunedUpTaco likes this.
  19. Dec 15, 2024 at 11:16 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Wait....
    He gave you a ticket for a damn extension cord?
    FastEddy59[QUOTED] likes this.
  20. Dec 15, 2024 at 11:20 AM
    FastEddy59
    Eddie
    Yup, was still driving my Ranger then. Just got the Tacoma.
