Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Mar 26, 2025 at 10:27 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    Looking for winch line suggestions.
    I think I'm going to make the switch from steel to Synthetic line this year.
    Going onto a gen 2 XRC 9500
  2. Mar 26, 2025 at 10:56 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If we have to, overnight parts from Japan.
  3. Mar 26, 2025 at 1:01 PM
    blackgen2tacoma
    blackgen2tacoma Well-Known Member
    Andrew
    2013 black Tacoma limited
    What nightmare. New control arms and bison off road hardware. Replaced inner and outer tie rods and boots. Replaced upper control arm bushings and rear leaf spring/ shackle bushings.found a cracked leak spring in the rear. Replaced broken spring. Welded in the marlin crawler gussets. Tried to align it not even close. Tried every option no change to toe. Took everything apart and checked part numbers and inner tie rods sent where for a rwd and not 4wd. Replaced and re aligned perfectly without after market uppers. I am glad I checked over everything and didn’t buy uppers because I would still have the same problem -$1000. Truck drives amazing. Thanks for everyone’s help. Check parts don’t assume.
  4. Mar 26, 2025 at 1:10 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Glad you got that figured out. One thing I noticed the YouTube technicians (South Main Auto, Rainman Ray, etc) do often is compare the removed part and new part side by side. It's a good precaution against wrong part received, wrong part mispackaged in correct box, shitty aftermarket part produced with wrong dimensions, etc.
    Did you end up installing Altrom SRT-330? Those are slightly beefier than OEM, but will prevent fitment of Dialed Design (nee Warfab) sleeves.
  5. Mar 26, 2025 at 1:29 PM
    blackgen2tacoma
    Andrew
    yes used the altrom art-330. They Are the correct ones lol. They are a lot thicker than stock. I quickly checked to see if they thread into my outer tie rods and they sent. I work on ford all day and we don’t have a problem with parts because I look up my own parts. We usually have problems when we see new tape on the boxes lol.
  6. Mar 27, 2025 at 6:03 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    :argue:
    Anybody have an idea what this might be worth?
    :hattip:
  7. Mar 27, 2025 at 6:14 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Realistically? It's worth 500 bucks to the right guy. Price at 350 for a quick sale. The paint unfortunately kills the value
    llamasmurf[QUOTED] likes this.
  8. Mar 27, 2025 at 6:15 AM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Tire season is upon us :bananadead:
  9. Mar 27, 2025 at 6:53 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    2nd gen?
    might be worth something to @tgelata
    :p
    3JOH22A and llamasmurf[QUOTED] like this.
  10. Mar 27, 2025 at 7:20 AM
    llamasmurf
    Wes
    Northern Ontario
    Norilsk and tacoma16[OP] like this.
  11. Mar 27, 2025 at 8:06 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I ended up scrapping mine. But I had cut bedsides so not too many people were interested in a hacked bed.
  12. Mar 27, 2025 at 8:15 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
  13. Mar 27, 2025 at 8:17 AM
    Norilsk
    Eugene
  14. Mar 27, 2025 at 8:34 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    I'll have a used set of 5 37s if you're interested.
  15. Mar 27, 2025 at 8:35 AM
    Norilsk
    Eugene
    Wrong wheel size... 18" wheels life...
    17" cost tripple what 16/18" wheels are suprisingly for Tundra/LC.
  16. Mar 27, 2025 at 8:37 AM
    Norilsk
    Eugene
    on another note, are you going for 40s?!
    Windigo[QUOTED] likes this.
  17. Mar 27, 2025 at 8:48 AM
    llamasmurf
    Wes
    Northern Ontario
    Can't help but post pics of my weiner :cookiemonster:
  18. Mar 27, 2025 at 9:14 AM
    Windigo
    Farook
    '14 Acess Cab
    Only if I sell the 37's , if not I'll keep em.
    Norilsk[QUOTED] likes this.
  19. Mar 27, 2025 at 11:32 AM
    Bergie14
    Bergie14 New Member
    Aaron
    2001 4Runner
    Anybody interested in a 2001 4Runner? Located near St Thomas Ontario. Drove it here from Portland Oregon in 2015 and undercoat every winter so very minimal rust to frame and underbody. Back gate was damaged last summer and needs to be replaced. Has about 330,000 miles on it. Religiously did all service requirements and lots of replacement parts like radiator, water pump, fuel pump, timing belt etc. Replaced front end in 2015. Anyway, looking to find it a home. Money less important than it finding its way to somebody who would wanna fix it up or even use it as a parts truck for another 4runner. Thinking $4,000 OBO. If interested please let me know. Thanks! Aaron 226-376-6532
  20. Mar 27, 2025 at 11:40 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    33s
    blackgen2tacoma likes this.
